Thunder Tiger 60/70/90 Raptor 60/70/90 Helicopters |
11-21-2010, 06:43 PM | #1 (permalink) |
What locktite do you use on your raptor 90
So i am currently putting the finishing touches on my 90 ,
i am wondering what kind of locktite do you use on your engine bolts. I currently have the red locktite witch is i think considered the super strength one. Also I was wondering I have seen many birds with their electronics just strapped down with velcro without being wrapped in any sort of foam rubber. What do most of you do ? do you wrapped everything foam rubber ? |
11-21-2010, 10:48 PM | #2 (permalink) |
I use blue loctite. Heard you should use high temp loctite on the muffler but I used blue and double nutted it using longer bolts that stick out allowing for the nuts. The foam thing is for protecting your electronics in the eveny of a crash, correct me if im wrong.
SR120, MCX2, Trex500 CF, Blade 400 ,Trex450XL, Outrage 550. Raptor 30 V2 OS37 Raptor 90SE, OS91 Max SZH (sick heli) AMA# 950209 White Mountain Bald Eagle Squadron Jesus is Lord Happy Flying |
11-21-2010, 11:21 PM | #3 (permalink) |
Foam can be for vibration isolation, as well.
I NEVER recommend the red loctite. I've stripped a number of bolts b/c of that crap. The blue works great! The longer bolts on the muffler with some nylock nuts is a good suggestion.... |
11-22-2010, 07:21 AM | #4 (permalink) |
^^^ +1 No need for red loctite, blue will work just fine. You will spend alot of time cursing and rounding nuts and bolts off if you use red loctite
Raptor 30V2,90SE EXI 450 Pro illicittrendz.com Its better to die on your feet than to live on your knees. |
11-22-2010, 09:30 AM | #5 (permalink) |
I had the nylock nuts on first and after a while the heat gets to them. Im still using them but backing up with a standard nut as a jam nut.
11-22-2010, 12:43 PM | #6 (permalink) |
i use blue on everything
Goblin Urukay Competition Align T-Rex 700 Nitro FBL DJI Mavic 2 Pro |
11-23-2010, 05:21 AM | #7 (permalink) |
thanks for all the input guys !
11-26-2010, 03:42 PM | #8 (permalink) |
Blue works great but you have to clean the part well...extremely well, or it doesn't hold up.
As to the red locktite, if you're stripping the heads, you're not using enough heat to break it loose. I use a propane torch to heat the screw...only for a about 5-10 seconds (depending on the screw location) and it comes right off. You can also use a soldering iron, just takes longer...about a minute. The I did use red on the flybar cage mixing arms...somewhere else but I forget right now. Everywhere else it's blue.
X-cell Fury 90: 601/9251, 8231's Cyc; DS650; OS 91MP-6; Jr Vibe 90; OS 91RJX Pipe; Jr 8231 cyclic, 770 3D/G8900, Prfct Reg. CCPM; T-Rex 600 NP: 6965HB, 425MG Throttle GY 520/9254; OS50 Hyper,MP-5, Prfct Reg; 600E Bstx, nue1910 |
