Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > Hurricane 550
Hurricane 550 Discussion and support of the Gaui Hurricane 550
Old 11-03-2013, 09:27 AM   #1 (permalink)
Question Trex 500 main hub on hurricane 550?
I dont like the narrow hub the hurricane has, and i can't find a FBL-head that works with 12mm thick blade roots together with a 8mm mainshaft.
I have a spare Trex500 center-hub i bought just to see if i could make it work instead of the Gaui part.
The extra width is a plus for me. It will space the grips further apart, but it is only adding a slight delta. The grips are actually too close together now and not lining up perfectly.
I want to use the stock plastic grips, but need to find a shaft and bearing combination to make it all work together.
I have not owned a trex500 and now finding out the strange way they put the head together with stepped feathering shafts and fs sleeve. I wonder what the benefits are of this design.
I have no additional parts except the hub. So would need a shaft and dampners, perhaps change the bearing size in the grips to accept a different diameter fs.
Anyone know a combination of parts that is close or would work fro me?
MSH miniPRÔTOS & PRÔTOS 500 a better way to fly
GAUI
Hurricane 425 night rig & 550 the monster
sp00fman is offline        Reply With Quote Quick reply to this message
Old 11-03-2013, 11:01 AM   #2 (permalink)
HF MR Support
...how about X5 head parts....I have a Hybrid X5 Flybar head with stock 550 washout /arms/swash....I seem to remember other peeps using them for FBL
Gaui 550(Need GOT ONE!) / KK2.1.5 steveis pro/ZMR250 / Alien 450 camera ship / HJ 450 all W/KK2.1.5 Steveis pro Estes Nano/ Hubsan X4 / Syma X1
AMA 953414 CONTRIBUTOR, TEAM LAVAQUAD
PTcaflyer is offline        Reply With Quote Quick reply to this message
Old 11-03-2013, 06:12 PM   #3 (permalink)
Its a shame X5 bits are so expensive. I got this RJX 500 FBL hub for $8.
The X5 does have a 6mm feathering shaft like the trex500, and uses and bigger bearings in the grips than the hurricane. So would need the grips also,
I thought for a moment the trex500 has a 8mm thick feathering shaft in the middle, but i was mistaken. seems to be 6mm
The X5 featheringshaft could bring me pretty close to fitting it. Ill try to fins some reasonable priced grips.
GAUI
Old 11-03-2013, 06:26 PM   #4 (permalink)
HF MR Support
...All the ones I have are 8mm....All Flybar stuff though
The center hub is 34mm and 12mm bore for the feathering shaft
T Rex 500 feathering shaft is 6mm x 68mm between the thrust Brgs.
Old 11-03-2013, 06:46 PM   #5 (permalink)
Don't know how to help you, But if you can't get this to work the Stock FB head can be made FBL easily.
http://www.empirerc.com/fes-upper-sw...st-p-3981.html
Plus
http://www.empirerc.com/fes-main-gri...ps-p-3980.html
and you get a good FBL head with Gaui parts.
Sorry, for the US web sites, but I don't know of any local to you, but I assume you can find something like these near you.
Gaui Hurricane w/ 530mm blades & Robird G31
Walkera Super CP
Walkera Devo 10 w/ Deviation
SQRT(-2) is offline        Reply With Quote Quick reply to this message
Old 11-03-2013, 07:07 PM   #6 (permalink)
Thanks, but I already have those parts fitted. It works but i found the stock hurricane hubs to bend easily, and new ones not spinning 100% true. The plastic hub ends are slightly flexible. Together with the silly small dampner O-rings and the way they are spaced so close together makes the whole assembly so flexible. If i grab both blades and rock them a bit they flex quite a bit. Making the pressure higher on the damponers fixes it a bit for one flight, than back to sloppy. Im afraid i start to deform things.
A lower hub will also make the heli look much better.
GAUI
Old 11-03-2013, 08:49 PM   #7 (permalink)
HF MR Support
...You are welcome to any of the X5 head parts I have....Let me know
Old 11-04-2013, 12:04 PM   #8 (permalink)
Sweet. Will do if i get stuck.
I'm going over several manuals of different brands. Logo500 maingrips might work, but will need an odd size 6x14x4 bearings set to get it to work.
RJX X-Tron 500 manual is next.
edit:
RJX has smaller grips.
Trex550 & 600 will need the 6x14x4 bearings.
GAUI
Old 11-05-2013, 12:51 AM   #9 (permalink)
X4 rotor yoke with X5 grips might just do the trick.
I don't need the latest and greatest. I just need more time to fly what I have.
Align 450 Sport V2, Gaui 200, Gaui 425 x 2, "HeadHunter 500, Gaui 550, all Flybar'd
Jerrymac is offline        Reply With Quote Quick reply to this message
Old 11-05-2013, 03:01 AM   #10 (permalink)
Someone did that years ago - I can't remember his name now (aussie guy) should be inhere somewhere if you search ...
Old 11-05-2013, 03:28 PM   #11 (permalink)
I read that thread. Together with the chopped down main mast topic it was sort of my inspiration. I have a Hurri425 with a 500 FBL head on it and its so nice, but the thicker 520mm blades wont fit the grips.
Getting all the X5/X4 parts would be for another months budget. Just got a nice metal tail suffs to sort out the problem that has been haunting this heli for over a year.
Tried about anything to get rid of the vibe: https://www.helifreak.com/showthread.php?t=557594
Im off for some tinkering on it now, Hope to get it ready for a test run tomorrow.
GAUI
