Old 08-13-2012, 07:17 AM   #1 (permalink)
Default New DFC Conversion Issues
Just converted my 500 ESP which was setup with the stock Align FBL head (it was flying perfect with absolutely no issues) to the new DFC head and DFC swash. My first concern was how hard it was to fit the ball links from the blade grips to the DFC Swash, I was like the arms on the blade grips extended to far out. Both ball links had to be snapped on (to the swash) at the same time, and to remove them I have to actually unscrew the balls from the swash first then pop the links off. Is this normal?.
The second issue was the heli would porpoise while in fast FWD flight. I had to drop my Vbar gyro gain from 70 to a very low 42.
But last and most important is the extreme vibration that is saturating the Vbar logs. (Never had any vibrations with the old FBL head no matter how hard I flew). I isolated the vibration down to the blade grips, I can spool up the heli with everything installed on the head with the exception of the feathering shaft and blade grips and I have no vibrations. Note: When the feathering Shaft and Grips are installed the grips are smooth as silk with no binding.
Any suggestion would be appreciated before I go back to the stock FLB head and swash.
ID:	340107   Click image for larger version
ID:	340108   Click image for larger version
Trex 700N, 700E, 600E, 500E all Vbar 5.2 Pro FBL
Dji F550 WKM Data Link 900MHZ
DJI F450 Naza/GPS FPV 5.8 vtx
TBS Disco w Core Naza GPS FPV 1.2 vtx MT Tiger motors
02deuce is offline        Reply With Quote Quick reply to this message
Old 08-13-2012, 07:25 AM   #2 (permalink)
Do you have a digital scale? Try weighing each grip to see if there are similar weight. Could be a balance issue
Trex 600cf - DFC, BeastX, KDE Kit
Copter X 450Pro V3 - DFC, BeastX, Edge 350
MCPx - Hp06v2, Hp03
DX6i
SEBBY is offline        Reply With Quote Quick reply to this message
Old 08-13-2012, 07:29 AM   #3 (permalink)
For me the ball links are a pain to pop on and off. Ball link pliers dont really fit to good in the dfc swash.
Slow & Steady!
nmdesertracer is offline        Reply With Quote Quick reply to this message
Old 08-13-2012, 07:32 AM   #4 (permalink)
Yes I do have a digital scale, and that is on my list of things to do today.
Old 08-13-2012, 10:11 AM   #5 (permalink)
Weighed both arms and they are the exactly the same.
Old 08-13-2012, 04:15 PM   #6 (permalink)
1- Even if it is new, it is possibel for the feathering shaft to be out of spec, or I think I heard nce, even bent. Check it out.
2- I have the 1gen Align head, and when reasseembling it, I have had to push using a hex drier on the retaining screw the grip inward to even them out. This is also a good way to cure a grip if it seems nothcy verus the other grip.
Are you using Vstabi express or Pro? If pro can you post a vid of the vibe analys. I suggest a vid becuase it allows one to see the maxvibes during the spool up process.
torpedoarmed is offline        Reply With Quote Quick reply to this message
Old 08-13-2012, 05:33 PM   #7 (permalink)
the dampers are stiffer so you may need to up the head speed to reduce the nodding
Dave
Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro
MutliWiiCopter Scarab Stealth Armour,Scarab Stealth Reconn V3, Scarab TriiKopta, Scarab Octa, Scarab Vampire
Deet is offline        Reply With Quote Quick reply to this message
Old 08-24-2012, 03:56 AM   #8 (permalink)
I'm also having the same issue. I believe that mine, same as your DFC head is defective. I've changed all moving parts to new ones and no use. The vibration is going from head, since when it spins down the whole heli wobles and shakes. Without blades, everything seema normal. I know its not the blades, since I balanced them and changed to new 3rd pair!
Trex 800Pro DFC, Trex 500Pro DFC, Blade 180CFX
DerClown is offline        Reply With Quote Quick reply to this message
Old 08-24-2012, 05:54 AM   #9 (permalink)
Have you tried pushing really hard side to side on each blade grip to see how much end float there is, maybe if there is as much as mine it could be causing a bit of vibration. Check out my post.
https://www.helifreak.com/showthread.php?t=447177
phillhague is offline        Reply With Quote Quick reply to this message
