Old 04-22-2015, 09:20 AM   #1 (permalink)
Question Logo 600 SX question – Wobble on spool up/down and Head speed
Finally after months of sitting on my build table. My 600 SX maidened yesterday. Few questions for you guys with more experience
1.)
Heli does wobble dance on the skids as soon as I start to spool up and then quickly smoothens out. Same is the case with spool down, right before the rotors are about to stop it does the skid wobble dance and then smoothens out to come to a complete stop moments later. Is this normal for a 600 SX? I bought this heli used. Since then I have upgrade to V2 frames, New Main Bearings, New Main Shaft, New Fathering Shaft, New Thrust Bearings and head dampeners. The main blades are also perfectly balanced
2.) I am flying 2200 HS with 600 mains and 105 tails. Its 12s Pulse 3700mah setup. The helis flies awesome but I would like for the heli to be bit more aggressive and responsive. May be this smooth/soft feeling is the “Logo” way that I just need to get use to with. Is any one flying more then 2200 HS with 105 tails? Is 2250 a safe head speed for this bird with 105 on the tails ?
3.) What tail gain are you using in V-bar settings?
4.) What head gain are you using in V-bar settings?
Thanks..
Last edited by cbrkhan; 04-22-2015 at 01:39 PM.. Reason: Corrected Head Speed to 2200
cbrkhan is offline        Reply With Quote Quick reply to this message
Old 04-22-2015, 09:53 AM   #2 (permalink)
How tight do you bolt your blades on?
pgleesonuk is offline        Reply With Quote Quick reply to this message
Old 04-22-2015, 10:27 AM   #3 (permalink)
Tight enough where I can hold the heli sideways and blades will not move. If I gave it a small bump then they will move.
Old 04-22-2015, 12:37 PM   #4 (permalink)
2100- 2200 is pretty standard on the 600. Try bumping your HS up to 2200 or so.
Diabolo 700UL / Logo 700 / Oxy 5 / Goblin 500 / Oxy 2 FE / Blade 180CFX / mCPxBL / nano CPS / V-Bar NEO / V-Bar Control / uBrain / DX7
3D Dave is offline        Reply With Quote Quick reply to this message
Old 04-22-2015, 01:41 PM   #5 (permalink)
Sorry, I am flying 2200. I have corrected the main post as well
Normal: 1950
IUP1: 2100
IUP2: 2200
Old 04-22-2015, 03:49 PM   #6 (permalink)
On 600 blades you still can go higher but maybe try more pitch allso.
How much pitch do you have today?
Logo 600SX
Warp 360
Chase 360
Exo 500
Mr.Andersen is offline        Reply With Quote Quick reply to this message
Old 04-22-2015, 04:04 PM   #7 (permalink)
maybe the head dampners have to settle a bit. It should change after a few flights...
We don't stop playing because we grow old; We grow old because we stop playing!
LOGO700(2) - LOGO690SX - 700XXTREME - GOBLIN380 KSE - VBARCTRL
galensk is offline        Reply With Quote Quick reply to this message
Old 04-22-2015, 04:31 PM   #8 (permalink)
I am flying 12 degrees of pitch.
Old 04-22-2015, 05:00 PM   #9 (permalink)
Maybe you can try 13 degrees of collective and see if that makes it more aggressive, keeping same headspeed. Also try playing with Vbar Agility and Style sliders to make it more responsive.
For the wobble, is your blade tracking spot on? And does it make any difference if you tighten the blades a bit?
Andreas M.
Compass 7HVU
Logo 600SX V2
Blade 450X
Heli.Maniac is offline        Reply With Quote Quick reply to this message
Old 04-22-2015, 06:09 PM   #10 (permalink)
Tighten the blades...
MikadoUSA Tech Support
Laughingstill is offline        Reply With Quote Quick reply to this message
Old 04-25-2015, 04:58 PM   #11 (permalink)
Finally some good weather yesterday. Tightening the blade grips eliminated the wobble
I must say, this heli flies amazing. It's my first mikado and I am loving it
Old 04-25-2015, 05:20 PM   #12 (permalink)
What blades are you using?
Jim Hansen is offline        Reply With Quote Quick reply to this message
Old 04-25-2015, 05:21 PM   #13 (permalink)
Stock edge blades
Old 04-25-2015, 05:34 PM   #14 (permalink)
So the plan for this 600sx is to be my main work horse. I plan to always have it in my car and fly every chance I get. I am using stock scorpion 450 kv motor with pulse 3700 12s setup and 12T pinion.
Do you guys fly your helis back to back? I never do ... I usually have at least 2 helis .... I alternate and fly one while the other one cools down.
I am thinking of changing that hobbit because of always having to carry two helis .... Instead fly back to back ...
The newer motors should cool down to operating temperature when back in the air and airflow should cool the ESC down as well
What are your thoughts?
Old 04-25-2015, 06:08 PM   #15 (permalink)
In the winter, I don't think about it and just fly back to back. But in the summer when it is hot out, I wait around 5 minutes for everything to cool down a bit. Usually by the time I have loaded the next pack in the heli, my five minutes are almost over so it is not keeping me waiting really.
I say for learning, flying 1 single heli per day is the way to go. That way you don't have to adapt to different setups and can concentrate on learning new stuff. Have fun with the new heli
Andreas M.
Compass 7HVU
Logo 600SX V2
Blade 450X
Old 04-25-2015, 06:25 PM   #16 (permalink)
Yes with my Nitros and Electrics
Old 04-25-2015, 07:03 PM   #17 (permalink)
I am not a beginner. 3 years experience and probably 25 helis in 3 years. Current fleet size is 9.
In winter I don't care about back to back flying as well. All that I am trying to prevent is having to carry two helis with me all the time
I am more of a opportunistic flier..... I hardly ever get any time to fly.... Having the heli always in the car can mean a flight or two when I have a few minute or a flight when leaving work
Old 05-02-2015, 12:03 AM   #18 (permalink)
Now that my 600 is flying awesome ...... Time to work on making it a little more aggressive. I love it so much that if I can make it a bit more aggressive, I am buying another 600sx
1. I read some place (cant seem to find it again) that washers can be places in the head to make the dampeners a tad stiffer that also help in prolonging dampener life. Any one know the part number of these washers?
2. Bumping Pitch from 12.0 to 12.5
3. Does any one increase the default Cyclic Ring? I guess the default is 85
4. I plan to play with pitch first ..... if that does not do the trick. is 2250 a safe head speed with 105s on the tail?
Old 05-04-2015, 09:36 AM   #19 (permalink)
Not on the new SX head
Go to 14
Leave it at 85
All day, even with 14 degrees of pitch….
Hope this helps...
Old 05-04-2015, 09:51 AM   #20 (permalink)
I fly all my helis back to back.
Mark
Dusty Shelf queens: TDR2, TDR, Protos Max, Logo 550SX, Protos 500, Jeti DS-16, etc....
mkovalcson is offline        Reply With Quote Quick reply to this message
