Old 04-20-2010, 04:15 PM   #1 (permalink)
Smile SPARTAN VIBRATION ATTEN KIT ON THE 3G SENSOR
Hi Friends, I test today this kit on my Trex 500 3G and works amazing, no more slow drift in the tail, I can increase my gyro gain, FBL works muh better and stable.
If you going to use this kit put the tick 2 side tape in the sensor, put the metal plate and the foam in the bottom, use the Align velcro to get the sensor firm, I got the sensor on the bottom platre and the receiver in the plastic receiver mount.
works so amazing in inverted flights on windy day.
If you got problems with the 3G sensor this kit can help you a lot, works a lot better than the Align 2 side tape.
In this store link you can see the kit or buy it, I live like 12 minutes close to the store Great service!!!
http://www.espritmodel.com/index.asp?PageAction=VIEWPROD&ProdID=7157
Here is the Test, Enjoy!!! :glasses2:
[ame]http://www.youtube.com/watch?v=Ji-9IAhQ2OA[/ame]
BonewJunior is offline        Reply With Quote Quick reply to this message
Old 04-21-2010, 06:03 AM   #2 (permalink)
Can you just clarify how you have mounted : thick foam then plate then thin foam then sensor. I want to use this on my e700 !!!!
marktheheliman is offline        Reply With Quote Quick reply to this message
Old 04-21-2010, 07:18 AM   #3 (permalink)
Hey! junior is you'r trex500 have the plastic gyro plate?
dale-pabajo is offline        Reply With Quote Quick reply to this message
Old 04-21-2010, 11:42 AM   #4 (permalink)
Hey Dale-Pabajo The 500 got the plastic gyro plate, I use them for the receiver, the manual say to use this for the sensor but this plate is flexible and when I go full throttle the elevator move a little.
Hi Marktheheliman, Here are some Pics!!! Hope this can help
Old 04-21-2010, 02:53 PM   #5 (permalink)
Thanks as soon as i get my spartan anti vibration kit i will set up as you have many thanks for the pictures.
Old 04-21-2010, 08:01 PM   #6 (permalink)
Well ok since you mounted it down there it should be cool.
what I wanted to say is yes that plastic gyro plate is very flexible.
and I also mounted my Skookum in the same location as you did.
dude I finally got my part's for my 500 and gave it a test this morning hovered just graet,bought an Align DS520 servo to replace one of my Savox 1357 and it is true what thay say Savox makes Align servo's.
Old 04-21-2010, 08:14 PM   #7 (permalink)
Thats so Nice buddy, Enjoy your 500 Dale-pabajo.
You are welcome Marktheheliman
here are some videos doing 3D with the 500 3G, spartan vibration kit for the 3G sensor and turnigy 6S 3300mAh 30C.
you can see the big diference in this videos, so stable, movements are amazing, I don't need to fight the machine in the 3D, I love the 3G.
Enjoy the video Guys!!!
Old 04-21-2010, 09:31 PM   #8 (permalink)
Now where? have I seen this before?
jondabear is offline        Reply With Quote Quick reply to this message
Old 04-23-2010, 10:19 PM   #9 (permalink)
Old 04-27-2010, 03:22 PM   #10 (permalink)
Let's post this here as well..
I got to try it today! There was some wind (maybe 4-5 meters/sec?) and I had practically no problems with this setup. The minor problems that I had is that this helicopter has insane power! Well, compared to 450 PRO anyway. I was running the 500 with 500M and Hyperion VX G3 35C 3300 mAh battery. I started with the aileron and elevator gains at about 12 o'clock, and it seemed may a tad shaky so I increased aileron gain to about 1 o'clock. I also decreased the gyro gain from 40 to 35.
I have a Kontronik Jive 80LV.
I made sure the cable stays in place by using some tape:
Two broken Trex 500 ESP helis, one unfinished Outrage Fusion 50, and one MSH mini protos in the mail.
Heechee is offline        Reply With Quote Quick reply to this message
Old 04-27-2010, 09:08 PM   #11 (permalink)
Nice and Clean Heli Heechee, I got my 3G gain like 1 o'clock to and I love the response, gyro gain in Normal mode (48%), ID 1 (46%) ID 2 (44%), the 500M Got Power, My TC on ID1 90, 85, 85, 85, 90 and on ID2 100, 90, 85.5, 90, 100, -/+ 12 and Woks Amazing on 3D, The Spartan Vibration kit Works very well on the sensor.
[ame]http://www.youtube.com/watch?v=Awrf48U9UsI[/ame]
Old 04-30-2010, 07:32 AM   #12 (permalink)
Default Re: SPARTAN VIBRATION ATTEN KIT ON THE 3G SENSOR
Got à spartan kit in my toolbox. Just fitted the sensor like yours. Very curious. Mine was flying fine on reciever tray, except for the tail. Gain was to low and bounced à bit.
Will post results.
Result; sux tail holds better but it's waggy. Gain 68% (spektrum).
Gonna try add delay, then remove velcro.
Align T-Rex 500 3G FBL || Spektrum DX7 || View my current 3G settings here:http://3g.doelauw.nl/?s=1277838222
doeLauw is offline        Reply With Quote Quick reply to this message
Old 04-30-2010, 03:16 PM   #13 (permalink)
I wonder what I am going to use to mount on my 450 Pro, which is nearing completion. I have Spartan foam and metal plate for my spare Quark. I am thinking just one thick Spartan foam, then strap it down, since this is a smaller 450, and the 3G sensor already has a metal plate in the bottom. If that doesn't work well, I will experiment to find a better solution.
n808 is offline        Reply With Quote Quick reply to this message
Old 05-02-2010, 11:41 AM   #14 (permalink)
I don't see a reason to 'strap it down'. Mine is set up as in the photo above. No bondage of any kind.
I'm a happy customer. Today I flew one pack in a relatively brisk gusty wind. A friend measured the wind with a portable meter, and we got readings as high as 6-7 meters / second (13-16 mph). Sometimes it was relatively calm. 500 handled quite evenly, some unexpected upwards/downwards movements, but not that much. I didn't notice any unexpected tilting as such. Credit also belongs to Kontronik Jive, no doubt.
I flew some circles and eights, pretty slowly, so nothing fancy.
Old 05-08-2010, 06:44 AM   #15 (permalink)
Default SPARTAN VIBRATION ATTEN KIT ON THE 3G SENSOR
Using only the thick pad and no strap works great now. Low tail gain but holds nicely. Think it's becouse sensor is much closer to the center.
Old 05-08-2010, 09:02 AM   #16 (permalink)
this is how I mounted my vbar after many issues with other tapes.
GOBLIN 700 SPEED-KOSMIK200-700XF-NEO-BK CYCLIC AND TAIL
TREX 700E-NEU KDE 1917-12 PINION-NEO -JR 8717 HV CYCLIC-MKS990 TAIL-ICE 160-KDE UNIVERSAL MOUNT W/PINION SUPPORT
EatMorePizza is offline        Reply With Quote Quick reply to this message
Tags
align 3g sensor
