Old 04-28-2008, 10:01 AM   #1 (permalink)
Default Reading the Cellpro 4s
Hello:
When I plug my batteries into the Cellpro after a flight, they are down to about 12% or so. Is this too low? I thought I read somewhere that it should not be below 20%. Does the Cellpro consider this so that 0% on the Cellpro indicates that the battery has lost 80% of it's capacity?
Thank you
HPSAP: 54%
rig: vibe 50 | swash: ds8717 | tail: g7703d + ds8900g | throttle: hs-475hb | motor: 50 sx-h hyper + mp5 | receiver: ar7100r + 2s1p 7.4v 2000mAh | fuel: 30%
founder is offline        Reply With Quote Quick reply to this message
Old 04-28-2008, 11:45 AM   #2 (permalink)
i try and keep mine at 20%
someone else said that there not that reliable on that guage and you should just see how many MAH your putting back in.
for me the cellpro 20% is close enough
outhouse is offline        Reply With Quote Quick reply to this message
Old 04-28-2008, 11:50 AM   #3 (permalink)
Thanks, outhouse.
In looking at the amount of MAH I am putting back in, I see that one pack has "1.404 Ah added" and another has "1.28 Ah added". How am I to make understand and make use of these figures? What should I be looking for?
HPSAP: 54%
Old 04-28-2008, 01:51 PM   #4 (permalink)
if you have say a 1000 mah pac and you put back 800mah then you hit 20% perfect.
Old 04-28-2008, 02:18 PM   #5 (permalink)
Multiply your batteries MaH rating by .8. That is the most ou should be sucking out of it.
Eric
GAUI500, V30, Full Metal,9254/401+T600Tail, 500mmCarbons
TRex 450SEV2:HS65MG,3400G+DS760, Neu1107/1.5+11T, JAZZ40
Blade CP, ,RotoFly FP, Blade CX,
Other Blingers:
Deering Golden Era Banjo
LG100ZM competition air rifle w/20-50x60 scope (http://www.compufoil.com/images/eric_on_the_range.jpg)
Mathews SwitchbackXT Bow
CompuFoil is offline        Reply With Quote Quick reply to this message
Old 04-28-2008, 04:09 PM   #6 (permalink)
"I see" said the blind man. My packs are 2200mah. The most I should be putting back in the pack then is 1760mah (80%).
As stated earlier, I only had to put 1404mah into one of my packs. I guess this means that 796mah was still left in the pack. 20% of 2200mah is 440mah, so I still had 356mah left to use (796-440).
The Cellpro did indicate that this pack had about ~13% fuel left (286mah). If I would have used that last 13% that Cellpro reported as fuel, the pack would have been left with 510mah (786-286) and still been over 20% (440mah) in the pack. .
I hope I have the right understanding. I did the math for my own edification. If the above is true, then it does appear that the Cellpro does take into account the 80/20 rule of lipo packs. That is, ~0% on the Cellpro = ~20% in the pack.
I am going to test this after discharge and see for sure.
HPSAP: 54%
Old 04-28-2008, 08:21 PM   #7 (permalink)
The cell pro doesn't take into account any rule about lipos. it reads 0-100 percent fuel left and if it says 20 percent that's what it thinks that pack has left. it's that simple. 20 equals 20.
You can also check the voltage of the cells when you first plug in the pack. somewhere near 3.8 volts per cell is in the area of 20 percent left from what my two cellpros show me. a few seconds after plugging in and the charge starts voltage will jump a little and the percent left also can jump somewhat, easily to 30 percent or more after initially showing 20 percent. so it's not an exact science, just a guide.
look for after flight voltage near 3.8 and that the packs are not overheated and your lipos should last a long time.
astroflyer is offline        Reply With Quote Quick reply to this message
Old 05-01-2008, 07:37 AM   #8 (permalink)
dct
One more thing most people don't seem to understand .
Every time we use are packs they age! And no longer have the same mah inside of them,,, they are getting older with every flight.. I have many older packs that are 2200 packs and can't last 4 minutes and only put back 1000mah back into them.. Why ? You ask they no longer have the maternal inside of the battery that will hold the mah or volts.. All batteries do this,,and many IMO don't mark there packs with true size of mah. The 80% rule really only works on (( new packs! ))
**Now doing EASY 3D!! And having a Ball !!**Trex 550e FBL V2 AR7200BX with CC BEC PRO ,And
T-rex 450 Pro, DFC with AR7200BX , Blade 300CFX, and Two, Blade 130X , Blade 350QX .!
dct is offline        Reply With Quote Quick reply to this message
