Old 04-09-2014, 01:40 PM   #1 (permalink)
Default How to set rate on 206b in cycle mode?
I see settings for everything but charge/discharge rate when setting up a charge to discharge cycle for breaking in some new packs. Where are these rates set, and is there one setting for both or do you specify a rate for charge and discharge separately??
Go fly one!
Dustin Mustangs is offline        Reply With Quote Quick reply to this message
Old 04-09-2014, 04:07 PM   #2 (permalink)
Default Re: How to set rate on 206b in cycle mode?
Set a rate for Charging. Set a rate for Discharging. To be safe, also set Storage, if it does not match one of the other two.
The charger should use the charge current, and the discharge current, when cycling. As well as the discharge voltage target, as I recall.
Sent using Tapatalk.
Gaui X5, iKon, Edge 100, CC BEC Pro.
Tarot 450 Pro FBL, Mini VBar, Ice Lite 50.
BL mCP X, Nano QX, FrSky Taranis, iCharger 308Duo.
RedOctobyr is offline        Reply With Quote Quick reply to this message
Old 04-11-2014, 09:20 AM   #3 (permalink)
Thanks, that did the trick. For the record, changing any charge rate changes them all (including storage) and same for discharge. Set any one (two) of them where you want before setting up your cycle which is where you set all other parameters including target voltages.
Go fly one!
