Old 01-09-2012, 02:11 AM   #481 (permalink)
Originally Posted by helicraze View Post
Non of the hackers ever played nice with kt really
Hacker Turbine work with Jive in KSA without any issues. I mean that Turbine was first impulse for KT to implement KSA. Turnado work with Jive (without KSA) in all other modes than mode8.
swalko is offline        Reply With Quote Quick reply to this message
Old 01-09-2012, 07:25 AM   #482 (permalink)
I think what HC mean by playing nicely is that just the fact you need ksa mode means you lose some jive features, all motors I ran Ksa mode performed worse so imop if you have a choice opt for a motor that doesn't need it, if its performance you want get a yy wind motor, I'm running 4 of these normal mode
Stolla is offline        Reply With Quote Quick reply to this message
Old 01-09-2012, 07:51 AM   #483 (permalink)
Turbine need KSA, Turnado no.
Old 01-09-2012, 08:56 AM   #484 (permalink)
Never mind
WBFAir is offline        Reply With Quote Quick reply to this message
Old 01-09-2012, 09:09 PM   #485 (permalink)
Mrmel did you contact kt about mode 8 and other motor use???
helicraze is offline        Reply With Quote Quick reply to this message
Old 01-10-2012, 01:35 AM   #486 (permalink)
They reopened yesterday, been closed until now, i tried but they are busy. Will probably talk to them this week.
Im not too sure it matter much which motor though, its rather more about what you do, its a theory that i have had a while, but i need to talk to them...
http://heli.dacsa.net
Old 01-10-2012, 01:55 AM   #487 (permalink)
Hmmm interesting, i can live with we do not recommend (as they want to sell pyro) but if there is an actual technical reason not too then i will not use it.
Please let us know, thanks
Old 02-17-2012, 07:36 AM   #488 (permalink)
Just an update I have now flown 500 flights on the vbar gov with Ver. 11 Helijive I love the vbar gov and bailout works great its safe to say the Pyro and helijive is a bullet proof setup!
Magneto is offline        Reply With Quote Quick reply to this message
Old 02-17-2012, 08:30 AM   #489 (permalink)
I am ready to try the same combination (just waiting on a heat sink to arrive).
Avant RC
Scorpion Power Systems
ThunderPower RC
Kontronik Drives
Justin Stuart is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 03:45 PM   #490 (permalink)
I am unable to set throttle endpoints on my HeliJive using the ProgDisc. After setting endpoints the ESC will not arm with any throttle position. After resetting it with the ProgDisc it arms. If I set the throttle endpoints again it doesn't arm.
I bound my MiniVbar and sats with 100/100 endpoints in my transmitter. I connected the Master cable to my ProgDisc and my ProgDisc to RxB on the MiniVbar. After powering the ESC with a 12s LiPo I waited for the Vbar to initialize and then I pressed the button o the ProgDisc, entered HeliJive mode and set the throttle endpoints.
Any ideas what I am doing wrong?
Oxy2 210 | Oxy3 285 | Oxy4 380 | Logo 480XX | 600SX | 650SX | 690SX | 700 | 700XX | VControl
mahbouni is offline        Reply With Quote Quick reply to this message
Old 04-19-2012, 05:08 PM   #491 (permalink)
Why are U trying to set end points?? It does it when you stick program. Mode 8 vbar mode is fixed and cannot be adjusted
Old 04-19-2012, 05:26 PM   #492 (permalink)
I have never stick programmed a Jive before. I've always done everything with ProgCard 1 & 2 before but HeliJive doesn't work with ProgCard 1 so I used the ProgDisc. I'm not using Vbar goveror yet but will try it once I get the ESC up and running as it was with my PowerJive. I need to buy the rpm sensor too.
Old 04-20-2012, 03:39 AM   #493 (permalink)
Are you saying that you can't calibrate the endpoints to your Tx and that you have to calibrate the Tx to Vbar instead? What about people who don't even have FBL and use a normal Rx?
Old 04-20-2012, 03:41 AM   #494 (permalink)
No, what he says is Mode 8 is made for Vbar, then it's no need.
otherwise it's just like any other Jive.
Have a look at this, it might clear some stuff up.
[ame]http://www.youtube.com/watch?v=c_Wz4KUzjXA[/ame]
Old 04-20-2012, 03:51 AM   #495 (permalink)
Thanks for stepping in. So that part where you pull the jumper out and go to full throttle and back, is that setting the throttle endpoints or is it just resetting to Mode 1?
Can I not do the whole lot in the ProgDisc as I did with PowerJive or do I have to use sticks?
Old 04-20-2012, 03:52 AM   #496 (permalink)
You can do about same with ProgDisc as you could with Powerjive.
Setting Mode 1 with sticks also make it learn endpoints.
Old 04-20-2012, 03:59 AM   #497 (permalink)
OK so why do you think its not arming after I set the endpoints with ProgDisc? Have I missed an important step or am I doing it completely wrong?
Old 04-20-2012, 09:05 AM   #498 (permalink)
You are the only 1 i know trying to set with prog disc. How about doing as per vid and manual??? You cannot select different modes with prog disc
Old 04-20-2012, 09:10 PM   #499 (permalink)
Hey fellas I'm installing my helijive in mode 6.. I set the throttle curve but it won't go into idle up 1 or two. Any ideas? Curve is 40 50 60.. There not set in stone but can't tach cause it won't idle up
kevinbj1 is offline        Reply With Quote Quick reply to this message
Old 04-20-2012, 10:21 PM   #500 (permalink)
Tx Issue?
Is Vbar gov turned on?
Is pinion too small, RPM maxed?
Ohh just increase normal and see if hS increases. That will narrow it down
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
