Belt CP E-Sky Belt CP
Old 10-24-2014, 03:16 AM   #221 (permalink)
Default ARDUCOPTER!!!!
I ended up swaping the pitch and ailleron servos then reversing AIL function and AIL servo. ALL servos move/compensate correctly now. The deed is done. Im ready for a test flight! Well several... lots of back/forth from test hop to laptop. Head and tail gains are controled via MP not TX kind of a PITA.
-Heli Yea! Master of: the living room, mechanical setup and, the obvious!
Belt'ish CP FBL, HDX 500 DFC, New V120D02S FBL, Mini CP FBL, Hirobo Shuttle ZX, 450L w/VX1e, QR-X350PRO FPV, 450L w/APM FPV(in progress) DEVO 10 white w/2km range!
Heli Yea! is offline        Reply With Quote Quick reply to this message
Old 10-24-2014, 07:08 AM   #222 (permalink)
You might be able to do in-flight tuning from the TX, if you have a rotary knob or slider on your TX. See this link:
http://copter.ardupilot.com/wiki/ac_rollpitchtuning/
Also here, it uses in-flight tuning:
http://copter.ardupilot.com/wiki/tra...copter-tuning/
I've used this on my small quad, and works well. For a single rotor heli, it looks like it's pretty much essential.
Helis: Belt-CP, Mini Titan, EXI 450, HK250-GT, HK500-GT, HK600-GT, mSR (all modified/customised). Quads: Q4, nQX, HK250, Custom built 560 Deadcat camera platform. Some planks. DX6i & DX9. And a boat & some HK surface controller thingy.
CyprusDave is offline        Reply With Quote Quick reply to this message
Old 10-24-2014, 12:00 PM   #223 (permalink)
That is exactly what Im reefering to.
Old 10-28-2014, 11:58 AM   #224 (permalink)
I got the 450L tail blade grips yesterday! The build is officially done! Now to find some time to flight tune... Fall is kicking my ass...
Old 10-28-2014, 11:48 PM   #225 (permalink)
Only in Colorado and Washington can one "reefer" anything!
Highspeed
Highspeed1964 is offline        Reply With Quote Quick reply to this message
Old 10-29-2014, 12:35 AM   #226 (permalink)
I doobie leave weed better think about it 4 20 minutes.
Old 10-29-2014, 06:30 PM   #227 (permalink)
Mwaaaa haaaaaa haaaaaa!!!! Love it! Great sense of humor.
Highspeed
Old 10-30-2014, 11:54 AM   #228 (permalink)
Default Proper FBL Blades?
Old 11-03-2014, 10:25 AM   #229 (permalink)
Well I started the flight tuning and got her flying. During round 2 of the tuning I forgot to plug in the RX pack and distroyed my Spinblades.
Old 11-03-2014, 10:59 AM   #230 (permalink)
Oh pants. Sorry to hear that. Too late now, but for next time, do all the early prep, and tuning, with everything as basic and low spec as possible. When you have it near, and your routine is well practiced, you can put all your good gear on.
Regards, Sutty
sutty is offline        Reply With Quote Quick reply to this message
Old 11-03-2014, 11:55 AM   #231 (permalink)
Nothing else broke or stripped. Im going to press onward w/the 335's and hope the can provide the lift to get this rock off the ground. It really flies good already which I was going to show w/a vid, but didnt hook up power to the servos just the vid side. I dont even want to see that. The tail even holds pretune! I did a really good job mechanicly and surpassed requirements beyond the top of the scale. That means this is going to be a super stable/rocksolid platform!! Better than Robert's example???
Old 11-03-2014, 12:07 PM   #232 (permalink)
Default lesson learned
So I'll order another set of the SB's. I defo felt how nice these blades are and even for a 5min lazy hovering session in the alley. I felt zero heft as it lifts this rock of a bird guessing 5+ lbs.
Old 11-03-2014, 12:15 PM   #233 (permalink)
Default More good news.
I will have a new powersupply so I will be able to charge these big packs in minutes! NOT days or weeks like w/the Eskys.
Old 11-03-2014, 03:40 PM   #234 (permalink)
Default DAMN IT!!!! (insert "F" word here)!!!!!
Now what? I pluged in the USB and the damn usb port broke off the FC. F word here too!!!!!! Do I exchange it again? What should I do?
Old 11-04-2014, 06:45 AM   #235 (permalink)
Sadly, not unusual, with this and other flight controllers. I've read about it a few times, and a buddy of mine had it happen with a Naze FC,
Can it be re-soldered?
Old 11-04-2014, 09:50 AM   #236 (permalink)
Nope.
Old 11-04-2014, 10:01 AM   #237 (permalink)
So do you think I can return it again? or Do you think Im screwed and need to buy another?
Old 11-04-2014, 11:45 AM   #238 (permalink)
Why couldn't you return it? Was there any degree of misuse? If you dragged the lead, and forced it, then is it their fault, no. If you were just pushing it in, was it your fault, no. Maybe if we saw some pictures someone might have an idea. I did manage to resolder one of those once, in a Tom Tom sat nav, but I suppose each circumstance is different. In my case the board was totally intact, and it was a relaviely easy job. Clamped it into position and did one pin. Released the clamp, and tweaked it into perfect position, and heated all the other pins in turn, and to my surprise it worked perfectly.
Whatever you decide, maybe you could surround it with hot glue next time? As long as there is nothing you need to get to that is near to it?
Cheers
Sutty
Regards, Sutty
Old 11-04-2014, 01:13 PM   #239 (permalink)
I just plugged it in and MP would not connect so I unplugged it and the port came out. So I assume it broke as I plugged in.
Well I guess I send it back again then due to poor quality. looking like cold solders all the way there is no shine. pins are not broke/bent so not my fault. If I could micro solder I could fix it, but Im no Dilbert.
Old 11-08-2014, 02:27 AM   #240 (permalink)
Cant beleive the SB's have gone already!! Crash magnets I tell ya!!
COPTERBOY DX6i, mSR (SOLD), BeltCP (SOLD), mCPx w solid boom and Rakon Heli Head
T-Rex450V2 w.PRO head, Scorp-8 & 45A V2 ESC, CSM4200/S9257, 3xHS65MG
E-Flite CX2 - All Microheli/Extreme CNC CF Upgrades
TRex600N, Kasama Head, OS50SX
copterboy is offline        Reply With Quote Quick reply to this message
