Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > NX4
NX4 Discussion and support of the Gaui NX4 Nitro Helicopter
Old 11-20-2014, 07:27 PM   #1 (permalink)
Default NX4 Stretch and ys50 build
adding a ys50,x5 boom and 520 zeal blades,heres a start.
7HV,Trex 700N,Suzi Janis 800,500 DFC ,NX4 Warp,all on HC3SX, 230s
mmracecars is offline        Reply With Quote Quick reply to this message
Old 11-20-2014, 08:11 PM   #2 (permalink)
subscribed, looks good man. stock gear and pinion ?
___________________________________________
Gaui X7 / NX4 / X3
s76 mech is offline        Reply With Quote Quick reply to this message
Old 11-20-2014, 08:31 PM   #3 (permalink)
Default nx4
for now,that should get me around 2550 hs with the 520 blades.feels pretty light,so far its been pretty simple,the t-10 motor mounts fit perfect,i had to ream the stock cutch adapter to 9.5 mm to fit the shank on the ys crank,i trimmed the stock fan shroud around the head,i ordered up a trex 600 shroud,and I think I should be able to get some better coverage around the head by combining the two together.
Old 11-21-2014, 12:07 AM   #4 (permalink)
I,
I have the same project. Very good job.
What's your flight time ?
Motor isn't to hot ?
Jc
godjc is offline        Reply With Quote Quick reply to this message
Old 11-21-2014, 01:07 AM   #5 (permalink)
Well at it again I see eh Mike. Its cold outside but I know your going to hover in the back yard!!!
Goblin 380...650-700n..700e....Synergy E5s
Guiwee is offline        Reply With Quote Quick reply to this message
Old 11-21-2014, 05:22 AM   #6 (permalink)
Default nx4
Originally Posted by godjc View Post
I,
Jc
should have all the remaing parts and try it out next week
Old 11-22-2014, 12:12 PM   #7 (permalink)
Default getting closer
Old 11-22-2014, 06:17 PM   #8 (permalink)
Any exhaustive list of the parts and the modifications you needed for the conversion ?
Flydynamics is offline        Reply With Quote Quick reply to this message
Old 11-22-2014, 06:45 PM   #9 (permalink)
Default stretch/50
so far it been pretty easy-
the t-10 mounts put the 50 in perfect,i just trimmed the fan shroud around the head ,ive ordered a trex 600 shroud ,ill see if thatll fit with some mods or cut a few pieces off it for some more coverage around the head.,the x5 boom ,tt ,pushrod ,tail fin should just bolt on with no mods.the zeal 520 blades will fit the grips with a 4mm to 3mm bolt spacer(ill either ream the grips out later or add x5 grips with the correct 4mm bolt).the clutch adapter had to be reamed out to 9.4mm,which I bought at a local tool supply for 28 bucks(I have accses to a lathe,which made that easy).
the remaining parts will be here mon.
question-
-with stock gearing head speed will be max at 2550,will that be enough?
it feels def lighter than my trex 550.
-does the fan pull air from the bottom of the engine or push it down across the head
Old 11-23-2014, 09:16 AM   #10 (permalink)
up into the fan, down through the shroud across the head, out the bottom.
Gaui X7 / NX4 / X3
Old 11-24-2014, 07:05 PM   #11 (permalink)
Default x5 boom and 520 blades
Old 11-25-2014, 02:43 PM   #12 (permalink)
That's sweet mike!! I don't know how you do it, I would need a second job just to fund this hobby at your rate,lmao. Looks awesome!! Yeah I'm jealous!
kane601 is offline        Reply With Quote Quick reply to this message
Old 11-25-2014, 02:57 PM   #13 (permalink)
Default Nx4
Spend almost every weekend at work, that's why
Old 11-25-2014, 05:55 PM   #14 (permalink)
Ahhhh, that's cool that you have that option.
Old 11-26-2014, 01:23 PM   #15 (permalink)
How is your COG? If it's good what size battery did you put up front? This looks great. If it works out would you be willing to ream a clutch hub for me? Let us know how it goes.
squeely531 is offline        Reply With Quote Quick reply to this message
Old 11-26-2014, 04:57 PM   #16 (permalink)
Default nx4
squeely ,its a bit tail heavy as far as CG goes with a 1450 life up front,not sure if anything bigger will fit.should have it going soon,ill let ya know how it works out,doing the clutch hub for ya ,no prob.
on another note,ive never paid attention to CG on any of my helis,just for the hell of it I just checked my other helis and there all tail heavy,except for the 700n ,which is nose heavy,all will hover hands off for a bit(upright and inverted).ive let some of the hardcore smack 3d guys in my club fly my helis ,and have never had anyone even mention a cg issue with them.so does the fbl compensate for the cg imbalance,or is it some only a real pro would notice.ive payed around with my goblin with the cg off in both directions,and it seemed to fly the same to me.?
Old 11-26-2014, 09:58 PM   #17 (permalink)
I notice the CG most when doing hard piro moves. If it's off a little it will cause a wobble when you get into the collective hard. You would notice it during piro pitch pumps.
Old 11-26-2014, 11:33 PM   #18 (permalink)
I,
Test Gaui NX4 with engine OS 55HZ,muffler Power Boost and Rapicon 30% (5 min 58 sec)
JC
Old 11-27-2014, 05:32 AM   #19 (permalink)
Default nx4
Very nice godjc,
what hs and blade size was that,kinda wondering ,ive almost have mine done and want to know if ill need to change the pinion.
Old 11-27-2014, 06:19 AM   #20 (permalink)
I,
It's not mine, it's spanish pilot.
I will have my motor this week-end.
on my NX4, i'll use GAUI Stretch kit ( 215088 ) for mount 473 blade & 2500 T/M head speed.
Jc
