Old 03-09-2013, 05:02 PM   #481 (permalink)
Originally Posted by sp00fman View Post
The YEP is really big and heavy, but the nice thing is it has an 6Amp BEC with 5,5V output. Will have to side mount it. That is the compromise i had to make for the price.
i mounted mine like this, very good CoG with different batteries, btw great ESC
affiliated with my wallet.
BLHeli with locator beacon now!
honkytown is offline        Reply With Quote Quick reply to this message
Old 03-10-2013, 07:20 AM   #482 (permalink)
One of the bearings in tail block pulleys started screaming on Friday, so I changed them both today. This is one hell of a strange heli... A year of flying and this along with head dampers is all the maintenance you have to do. Unlike anything I've flown before
Tom
RCHN#233 | Lynx Heli Innovations Team
Goblin 700
Carbon |
Protos Max | Goblin 570
baui2000 is offline        Reply With Quote Quick reply to this message
Old 03-10-2013, 07:49 AM   #483 (permalink)
+1 I hv yet to change my damper after more than 1.5yrs and still good even after few soft crashes. Did once change the upper main bearing (after gone rough)
Mini Protos fbl - BX+95i, KDSQ fbl(rjx clone) - BX+8910, Ming Da(M3D) 600 fbl - BX+1290mg
infra77 is offline        Reply With Quote Quick reply to this message
Old 03-10-2013, 01:50 PM   #484 (permalink)
Another way to install YEP60/Himodel 60 ESC (just a T plate of carbon).
A really good ESC !
SAB Goblin 380 / Xnova 2820-890kv / Yep 90Lv / Beastx v3 / Tgy 306g Hv / BK DS-5005HV
Blade Nano CP-X BL
Rcx 250
Spektrum DX9
michalss is offline        Reply With Quote Quick reply to this message
Old 03-10-2013, 03:18 PM   #485 (permalink)
As I´ve not flown anything else I would find it strange to do more. I´m spoilt forever.
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8
dr dremel is offline        Reply With Quote Quick reply to this message
Old 03-10-2013, 03:52 PM   #486 (permalink)
Default What did you do with your Mini Protos today?
Staring at it for 15 minutes straight. Looking upward prevented me from drooling.
It is on the closet until wify gives the green light for the build process.
Previous owner seems to had a nasty crash. The tail-blades look pretty eaten up and judging from the leftover bad bearings and thrust-bearing in the box tells the main head also took a beating. I found both the boom supports to be cracked in the middle. I think i can epoxy it back to strength. Prev owner diddnt notice that and told me he "test flew" it before selling, to make sure the heli is ok. My thoughts were like: ."ffs, don't touch my heli! "
Love the Fusno canopy that came with it. Also the stock one is supplied, but need the ear fixed. Lucky me, I think its an easy fix. I think the canopy accounts for half the price i payed for this empty kit (but with SAB blades)
ID:	402363   Click image for larger version
MSH miniPRÔTOS & PRÔTOS 500 a better way to fly
GAUI
Hurricane 425 night rig & 550 the monster
sp00fman is offline        Reply With Quote Quick reply to this message
Old 03-10-2013, 08:14 PM   #487 (permalink)
Was warm enough. Did 2 packs... Just hovering around. Blood pressure dropped.. it was a good day. Need new blades though.. my yard is too full of trees.
Mini Prôtos 6S Stretch - DS95/DS95i, Mini V-Bar, YGE60 VBAR Ready
CrashAddict is offline        Reply With Quote Quick reply to this message
Old 03-12-2013, 01:44 PM   #488 (permalink)
I would like to see a video of you trimming the trees with your minip... If you have one
A lot of RC stuff:
Heli's, Quads, FPV gear, Tools, Chargers, Transmitters
jmisuraca is offline        Reply With Quote Quick reply to this message
Old 03-12-2013, 02:49 PM   #489 (permalink)
Default Nope..
No video's. Happens on panic landing attempts. It is better to hit a tree lightly then try and avoid it and crash it into something else faster.
When the weather gets better, I am going to try and fly at this field near my house where the State tore down a rental property. THe driveway is still there so it has a good take off and landing spot.
Old 03-12-2013, 11:26 PM   #490 (permalink)
Full damage analysis on my used purchase. My jolly what has this dude been smoking while assembly and flying.
Besides the obvious cracked supports struts, the tailboom is bend, one tailshaft bearing gritty, too short bolts in tailblades, Small bearings in pinion and Y-arm are shot, so I modified the Y-arm to accept larger bearing. Stripped nut on jesusbolt (plied it right off with my fingers ), jesusbolt is S-shaped. Two mainshaft bearings gritty, Swash follower arms tightened so hard so it crushed a bearing. Wishbone arm really tight on swashfollower arms. still needed to be sized properly. Some scraping on the bottom of the mainshaft , because the bolt that goes in the maingear snapped in the crash and it seems the motor was still running.
Had to flush the swashplate ball with contactcleaner to remove some sort of thick yellow residue (WD-40 leftover?) and lubed with teflonspray.
Good thing i stocked up on bearings beforehand, and there are some spares in the box i got with it. Ordered a new boom and pinion bearings and added a few spares like featheringshaft and tailshaft,Head dampners. Forgot to order extra main grips .
Still have to disassemble the tail and main spindle assembly. The grips on the mains are tight, so i wonder what I'll find in there.
This heli will sure be glad with his new owner. its gonna purr so sweet when i'm done !
GAUI
Old 03-13-2013, 12:24 AM   #491 (permalink)
Thanks for reminding me never to buy second hand heli's, haha
[B]TT E820 - Kosmik 200, Scorp 5035 TT G4.1(x2) - OS 91 3D Speed, Hatori
MSH Brains + JETI DS-16
rossk is offline        Reply With Quote Quick reply to this message
Old 03-13-2013, 05:18 AM   #492 (permalink)
If the price is right I see no problem in used purchases. Just be prepared for the worst. Another Protos saved, and the rebuild is part of the fun!
Old 03-14-2013, 11:30 AM   #493 (permalink)
Few more great flights this morning... Getting more and more risky with it, flirting with disaster. When the mini is set up perfect it just begs to be pushed. So much fun
Synergy E7
Synergy E5
Prôtos mini 450
Sharkbait is offline        Reply With Quote Quick reply to this message
Old 03-21-2013, 10:57 PM   #494 (permalink)
Thanks to msh-direct I'm already back in the air, but learned the hard way to goop servos into fbl unit... The Heli won't fly like intended when rudder servo unplugs mid flight.
Synergy E7
Synergy E5
Prôtos mini 450
Old 03-22-2013, 04:36 AM   #495 (permalink)
concerning rudder servo:
... tried the wellknown mks ds95i at the tail for the first time - its awesome.
... hopefully it stands the beating as long as the good old 9257 (about 75 hours flighttime... ... and the only reason for replacing it was a broken wire, not the servo itselfs...)
macem is offline        Reply With Quote Quick reply to this message
Old 03-23-2013, 12:52 PM   #496 (permalink)
My mini went down in a gym yesterday. I clicked throttle hold pretty quick but it was still a hard encounter with the floor. Damage assesment - a speck of reflective sticker peeled off one of the blades and some blue paint stuck in landing gear bolts Four more packs of half piro flip practice followed... I wonder how much luck do I have left
Tom
Goblin 700
Carbon |
Old 03-31-2013, 06:36 PM   #497 (permalink)
Default Mini P
In a tree,,
Old 04-01-2013, 02:46 PM   #498 (permalink)
In a tree,,
Atleast your name is appropriate!
branmuffin is offline        Reply With Quote Quick reply to this message
Old 04-01-2013, 03:56 PM   #499 (permalink)
Default Hee Hee!
Yes, Can you beleive there was no damage? I flew it for an hour after that. Those are those HK360 blades. Not a scratch on em. I just had to pull a few bits of tree out of the belt and clean the green stuff off the blades with Windex and it was back in the air. Great training heli. I love it.
Old 04-03-2013, 04:28 AM   #500 (permalink)
... and what do you think about the hk-blades? six dollars or so... a pair !!! every time i come back from the hk360 to branded ones i dont notice much difference... macem
