Like Tree10Likes
Old 11-06-2013, 11:15 PM   #201 (permalink)
Looks Great Garfield.
Your is my Bread and Butter.
Compass Field Rep/KBDD Team pilot/Experiencrc.com
sewerfly is offline        Reply With Quote Quick reply to this message
Old 11-26-2013, 07:28 PM   #202 (permalink)
Default TRex 550 Night lights
ok here is my first night flyer. I ordered the Night Magic blades today
Name:	550 night.jpg
ID:	467978   Click image for larger version
Name:	550 night2.jpg
JT
Trex 500, 550 & 600
Gob 700 & 700 KSE
JTAnimal is offline        Reply With Quote Quick reply to this message
Old 11-26-2013, 09:52 PM   #203 (permalink)
Looks like a good one
Old 12-15-2013, 01:28 PM   #204 (permalink)
Default not a heli, but it was night time : )
Roman Candle battle with the Night Planes... (6 min 15 sec)
Peaks-n-Valleys is offline        Reply With Quote Quick reply to this message
Old 01-16-2014, 04:38 PM   #205 (permalink)
this one fits here too. My KDS 450Q with lights
Flickr: http://tinyurl.com/danny-flickr
Name:	450Q nattkittad 02.jpg
ID:	479591   Click image for larger version
Name:	450Q nattkittad 03.jpg
ID:	479592   Click image for larger version
Name:	450Q nattkittad 04.jpg
550E, X3 | BeastX, YGE, DX8
http://dannesholk.se/rc.shtml
Danny_Swe is offline        Reply With Quote Quick reply to this message
Old 01-20-2014, 08:38 AM   #206 (permalink)
Banned User
Post
Just finished up another set of my crazy 12v night blades. These are Edge 603mm for the 6HV.
They are powered by home made 3s 240mah packs. Under a load the pack voltage dropped to under 12v within 4 minutes so it looks like these are good for one flight only.
Weight is 163 and 164 grams each so I've some balancing to do. I forgot to get the actual weight before I started. I think they are around 130 grams or so.
Hobbyking claims those 120mm long lamps are 3 watts each. Bunch of BS if you ask me because ebay says those small circular lamps are also 3 watts and they only have 6 chips each vs what looks like 48 chips visible on the long blue lamp.
I like having leds on the tips so the only thing I could think of is 3 1210 leds in series. In the second pic you can see a 10 ohm 2 watt resistor. Despite this the green led lamps leveled off around 130F in a 70 degree room. The longer ones were a steady 100F.
kavic5150 is offline        Reply With Quote Quick reply to this message
Old 01-20-2014, 11:12 AM   #207 (permalink)
Default Post your Night Rig Pics and Videos
Very nice Kavic.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0
PRÔTOS 500 FBL "Sky Whip" | Robird G31
Audacity P6 FBL "Phoenix" | MSH Brain | 12s
Goblin Speed | iKon
Dr. M is offline        Reply With Quote Quick reply to this message
Old 01-25-2014, 09:55 PM   #208 (permalink)
This was a very satisfying project. Did about 3 weeks worth or research and the build took about a week. Being a nitro makes this ideal with the long flight times. I ended up getting a catalyzed clear coat for the blades and canopy. Because of the current winter weather advisory I have yet to fly, but as soon as I can I'll be out there freaking out the neighbors. Big thanks to Jason O'Connell and the video series from Gus Petraits!
Sent using Otto correct.
This is gonna cost me.
aburkhardt is offline        Reply With Quote Quick reply to this message
Old 02-04-2014, 07:42 AM   #209 (permalink)
and
and
4li3n is offline        Reply With Quote Quick reply to this message
Old 02-04-2014, 08:55 AM   #210 (permalink)
That's pretty awesome.
Team Synergy Field Rep, Rail Blades
Rodney Kirstine is offline        Reply With Quote Quick reply to this message
Old 02-04-2014, 10:48 AM   #211 (permalink)
More and more night Gobblers. Nice!
Goblin Speed | iKon
Old 02-05-2014, 11:05 PM   #212 (permalink)
Looks like ROBO HELI
Old 02-18-2014, 10:10 PM   #213 (permalink)
Gaui X2 diy night blades, 5 smd leds. Green blue on top and blue,red, and purple on bottom.
Powered by a 1s 50mah pack with a sh-plug to charge and turn on. This forum help me 100%
So here is a pic and a short vid, i still need to mount some leds on the tail boom for orientation.
Gaui X2 night blades test (0 min 38 sec)
fusionsx00 is offline        Reply With Quote Quick reply to this message
Old 02-21-2014, 08:05 AM   #214 (permalink)
Converted my Logo600SE to a night rig due to little use.
Logo 600SE converted to SX head and gear
BLS253
BLS251
Jive 120HV
Pyro 700-45
Radix 690mm night blades
Edge 105mm night tail blades
LED's running off a 3s lipo with a 20A brushed ESC to control the brightness
Synergy E7 ~ Logo600SX + 600SE + 550SX ~ Synergy N7 + N5C ~ Mini P ~ Trex 450L
beans07 is offline        Reply With Quote Quick reply to this message
Old 04-02-2014, 07:31 AM   #215 (permalink)
Default Easy night setup: works great for me!
Decided to share my setup. Trex 550 DFC stretched, BD3SX.
I did not go too far setting up fancy controllers. Just main LED (warm yellow) in a shape of arrow (canopy side) and straight line (tail). Cross if looking from the front. Perpendicular red line canopy side, 2 red lines tail direction if looking from the bottom. 3S battery power supply. I run it at 11v to reduce amount of light. As it does not consume barely anything battery keeps same voltage for many flights.
My main blades RT 530 are small round battery operated, start when spooling up. Same with tail blades. No charging. Just replace when needed.
My flying experience was so great I stopped flying day time. Started with careful hovering, today performed whole sky loops and all I can do in 3D. Sound, power, looks, finally stars and Australian moon: just amazing!
I have a great spot next to my home. A cricket club field with 24h lighten barbecue area. Easy to setup and make few steps into the darkness. Love whole thing, just wanted to share!
ID:	499541   Click image for larger version
ID:	499542   Click image for larger version
ID:	499543   Click image for larger version
ID:	499544   Click image for larger version
ID:	499546   Click image for larger version
TSA 600E Pro BD3SX
Kasama Dune BD3SX
TRex 550E DFC Stretch BD3SX
DX9
Boris the Blade is offline        Reply With Quote Quick reply to this message
Old 04-10-2014, 05:25 PM   #216 (permalink)
Following the excellent tips in this "dark" area of HF, I've set-up my beater, a Tarot 480 Sport for some night action.
It's only lacking a bit of lighting in the tail section, but it works OK as it is.
Got figure a way to keep the Camera from having the auto focus working during the flight.
[ame]http://youtu.be/3F_S1Xc90Sg[/ame]
XL Power 520(soon to become a 480), Warp 360 , Tarot 360Sport, Logo480 LowRpm , Logo 500
T500 AP
Luigi_tuga is offline        Reply With Quote Quick reply to this message
Old 04-11-2014, 05:05 AM   #217 (permalink)
Nice!
You just have the canopy's red and green the other way around... normally it's RRR (right red return), so the red should be on the left side... joking
Oxy 2X-VertWarp 360Blade 450XBlade 450X NightflyerGoblin 500 ♦ 2 X mCPX v2 ♦ night fly mQXLadyMQXnano QXnano QX FPVInductrixDX8 G1
Coco66 is offline        Reply With Quote Quick reply to this message
Old 04-11-2014, 06:59 AM   #218 (permalink)
Originally Posted by Coco66 View Post
Nice!
Thanks!!
Now i know why my chaos wasn't tight enought
T500 AP
Old 05-10-2014, 07:31 AM   #219 (permalink)
Default my 1st night heli
Hi, i have been following the night flying forums and have now done some night flying with my 450X with night blades i made. After a few changes i have a setup I'm sort of happy with. Big fun to be able to fly at night - thanks to all the helpful posts.
Video to come of Hamish Scott flying my 450X night rig for the first time as soon as its uploaded.
3DehoverHF is offline        Reply With Quote Quick reply to this message
Old 05-11-2014, 08:19 AM   #220 (permalink)
Hamish Scott Blade 450X - night flying my heli (1st time he's flown mine at night) (0 min 33 sec)
Quick 30 sec video of mate Hamish Scott flying my 1st night rig attempt Blade 450x.
