Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Like Tree7Likes
Old 11-24-2015, 07:14 PM   #241 (permalink)
It's OK even for 3d as well
fazy is offline        Reply With Quote Quick reply to this message
Old 11-24-2015, 08:02 PM   #242 (permalink)
Thanks!
Gaui X5 FES, Blade 230S V2, iX12
MAAC Member
Bluebell is offline        Reply With Quote Quick reply to this message
Old 11-25-2015, 05:54 AM   #243 (permalink)
Those are what I used when I had my X5 flying. I did tend to be hard on them though.
Scorpion Power Systems
Michaelinpr is offline        Reply With Quote Quick reply to this message
Old 11-27-2015, 06:13 PM   #244 (permalink)
That's great. RotorQuest has a great deal/price on them.
Thanks!
MAAC Member
Old 01-28-2016, 08:24 AM   #245 (permalink)
I got 2 new Gens Ace 35C 4400 mah packs and highly recommend them! They fit the formula canopy with battery fence perfect with no alterations. COG is spot on now. Voltages and IRs look great before and after flights.
I mounted the battery so the wires are in the top front.
No bogging and it's like a new heli. I guess my 2 year old packs were finally getting tired.
GAUI R5 V2,RAW 700, GLOGO690, RAW580, RAW420all VBAR
VControl, DX9, DX7s
Accurc and RealFlight 8
C #773
Heli$ is offline        Reply With Quote Quick reply to this message
Old 02-26-2016, 06:56 AM   #246 (permalink)
Perfect thank you , I was looking to see if those Gens ace would fit . I have just ordered the battery fence as well.
flyswatter40 is offline        Reply With Quote Quick reply to this message
Old 02-26-2016, 07:48 PM   #247 (permalink)
Gens ace 3800 25c fit perfect with or without battery fence using the non formula canopy.
Size of pack= 138.82L x 42.62W x 51.9H
Gaui X7 w/Vbar, Miniature Aircraft Tempest w/ YS 91, Gaui X5 w/ Vbar, JR Vigor w/ YS 61, Gaui X3 w/ Vbar, Blade 180 CFX, Spektrum DX9
19trax95 is offline        Reply With Quote Quick reply to this message
Old 03-03-2016, 08:44 PM   #248 (permalink)
If anyone gets their hands on a Turnigy Graphene 4000 45c or 65c I'd be real curious to hear if it fits under the older pod / boom canopy..
Protos Max V2 770, Logo 550 SX v1, 2x Gaui X5 FESs, 2x Plastic Protos 500s, Protos 500 flybar, Trex 500 ESP FL, Protos 380, Trex 470L, Gaui X3, Trex 450 Pro V2 FBL, Trex 450 Pro flybar w/ Futaba GY520 - Skookum SK540s, a Brain and a Vbar.
Carpetbombing is offline        Reply With Quote Quick reply to this message
Old 03-08-2016, 07:32 PM   #249 (permalink)
Default Revolectrix 4400mah fit
I was able to get my Revolectrix 4400mAh 6S Lipo - 70C Silver Label to fit under the Formula canopy.
- Weight: 650g
- Dimensions: 55T * 44W * 134L mm
- Charge Rate: 1-3C Recommended, 6C Max
http://www.store.revolectrix.com/Pro...ance-Connector
Gaui X4 II-Spirit RS | Gaui X7-Spirit RS | Gaui R5 V2-DEMON AXON | Soxos Strike 7.1-Spirit GTR
JETI DS-14 | JETI DS-16 Gen2
iscripter is offline        Reply With Quote Quick reply to this message
Old 04-11-2016, 01:01 AM   #250 (permalink)
It's time for me to get a couple new batts for my x5. I'm liking the Hyperion 4200mah 35c. The weight is perfect for me, as I'm a tiny bit tail heavy with a 634g gens ace 4000mah 25c.
Anybody have anything good to say about Hyperion? They can be had pretty cheap.
I've owned one and it puffed after only 1 season. It was a little 25c 2s 1800mah rx pack. Not exactly a confidence booster.
I fly sport/mild 3d. Just want something that won't bog...
Current Fleet--Goblin 770, Goblin 700, Goblin 500, Goblin 420, Oxy 3 285, All Vbar
Old Friends--Trex 700n, Trex 600n, Trex 700L, Compass EXO, Gaui X5, Blade 450x, Blade 180cfx, Blade 130x, Blade mcpx, Walkera 4#6
fluxcapacitor121 is offline        Reply With Quote Quick reply to this message
Old 04-26-2016, 11:09 AM   #251 (permalink)
I can confirm that the Glacier 4400 45C packs fit with the battery fence.
Gaui X5 Formula (Hobbywing, RJX servos, Neo)
Gaui X5 Formula (Hobbywing, RJX &, BK servos, Neo)
VControl Phoenix Sim
cygnar23 is offline        Reply With Quote Quick reply to this message
Old 06-18-2016, 01:06 PM   #252 (permalink)
Default GAUI X5 Battery Database
Gens Ace 4400 35C fit with battery fence. I positioned the battery vertically to get more free space in the front.
Thunder power 4400 55c doesnt fit at all... If u want to use it, you must modify battery plate - raise the front part to 1cm, and you will be able to easily put the battery length of 155-160mm ( i checked it out with my hood!!! )
Quality3011 is offline        Reply With Quote Quick reply to this message
Old 06-18-2016, 04:50 PM   #253 (permalink)
Could you please post pics of raising the battery plate to fit longer packs?
Synergy E7se | Mikado 690SX V2 | Goblin Black Thunder T | Gaui X3 | brushless mCPx
VControl | MKS & KST Servos | Pulse
Heli-X8 | Lynx Team Pilot
prokyon is offline        Reply With Quote Quick reply to this message
Old 06-18-2016, 06:52 PM   #254 (permalink)
Lightbulb
I have not yet had the time to make this modification. When the battery does not fit, I started to think how to solve this problem.
I put underneath the banana plug (thickness of about 1 cm), then I attached the battery.
After that I came to the conclusion: raise the front to 1 cm - will be able to set a longer battery!
I hope this information will be useful to you.
ID:	657925   Click image for larger version
ID:	657926   Click image for larger version
ID:	657927   Click image for larger version
ID:	657928   Click image for larger version
Old 05-07-2017, 07:16 PM   #255 (permalink)
Gens ace 22.2V 25C 4000mAh
It will fit to my formula canopy with battery fence?
25C is low?
I found a great deal for 48€
Thespius is offline        Reply With Quote Quick reply to this message
Old 05-07-2017, 10:06 PM   #256 (permalink)
25C is low?
Do you have link to these or post dimensions?
The original GensAce 25C 4000's fit my FES X5 with room to spare. They were true 25C and in some cases actually 30C. If so then they are fine. Any lipo over 35C on the lable is kind of BSing you anyway.
Old 05-08-2017, 12:17 PM   #257 (permalink)
The battery is at GensAce site.
http://www.gensace.de/gens-ace-4000m...tery-pack.html
Old 05-10-2017, 02:47 AM   #258 (permalink)
I can confirm the Scorpion 4000mAh 6S 40c will fit to formula canopy with battery fence.
Old 05-10-2017, 02:49 AM   #259 (permalink)
Please someone can tell me if this battery fit the formula canopy with battery fence?
Old 05-10-2017, 01:05 PM   #260 (permalink)
The gensace your looking at are:
138x43x50 / 620grams
I have glacier 4000mah/30c
137x42x49 / 613grams
The glaciers fit with plenty of room with a Formula canopy and battery fence. You could also compare your gensace against other batteries in this thread.
Agile 5.5, Logo 550sx, X5, Goblin 500, Oxy 3, Trex 450proV2, 250DFC #309
nflanagin is offline        Reply With Quote Quick reply to this message
