Go Back   HeliFreak > R/C Helicopters > Helicopter Safety
Helicopter Safety R/C Helicopter Safety
Like Tree7Likes
Old 10-30-2013, 04:40 PM   #461 (permalink)
Originally Posted by Eyeballmike View Post
i was working on my trex 450 at my table reached for a ool ad accidently bumped the high idle switch.within the next two seconds i took a blade tip at full speed to the nipple.that was the last time i worked on it in the house.we now call that one the nipple ripper
Working on helis inside is not the mistake here. So, you haven't addressed the issue by going outside.
Jasmine2501 is offline        Reply With Quote Quick reply to this message
Old 10-30-2013, 05:30 PM   #462 (permalink)
Default Re: Pictures of injuries caused by RC Helicopters
A couple issues.
1. No heli should reach full speed in 2 secs and more like 8+ with soft start.
2. Throttle hold should always be on if not at the fight line and about to take off.
3. Depending on bench work being performed, motor should be disconnected
Sent from my SCH-I545 using Tapatalk
DX9, Mostro 700N 120SRX, HD Cell 500, Blade 450xl 6S, 180 CFX and 130x.
jrwalte is offline        Reply With Quote Quick reply to this message
Old 11-17-2013, 12:34 PM   #463 (permalink)
I've learned a few things here, thank you. I suppose its much more dangerous just getting into your car to get to the field, but wow, what an eye opener.
al93535 is offline        Reply With Quote Quick reply to this message
Old 04-05-2014, 11:10 PM   #464 (permalink)
Wow, what a great thread!
Being a relative noob to the hobby of RC helicopters, I nonetheless have a background as a pilot and know that rotating blades will maim or worse, kill, depending on, of course, size and rotating speed. And a poke in the eye by a prop from something as small as a Proto X quad can, in the least, scratch a cornea.
While the largest bird I have right now is a fixed pitch MJX F45, I am always conscious of the rotating blades of all of my helis. . . . .
Thanks again for the info!
Bassman12350 is offline        Reply With Quote Quick reply to this message
Old 08-26-2014, 03:56 PM   #465 (permalink)
Default Pictures of injuries caused by RC Helicopters
Bringing it in for a landing on a gusty day and lost control about 10 feet out. It went over my head and I ducked down at the last minute.
300 CFX
Kinens is offline        Reply With Quote Quick reply to this message
Old 08-28-2014, 06:24 AM   #466 (permalink)
Ouch! What heli?
matthewcornell is offline        Reply With Quote Quick reply to this message
Old 08-31-2014, 04:22 PM   #467 (permalink)
Flying around my living room and just got a little frisky with the sticks and dove my MCPXBL into my face. Thankfully it wasn't worse.
Tattoonick is offline        Reply With Quote Quick reply to this message
Old 09-09-2014, 01:06 AM   #468 (permalink)
Might as well add my recent mishap to this thread also.
https://www.helifreak.com/showthread.php?t=647112
"In my opinion, the M1 rifle is the greatest battle implement ever devised"
- General George S. Patton, Jr.
SgtGarand is offline        Reply With Quote Quick reply to this message
Old 11-10-2014, 10:38 AM   #469 (permalink)
Yesterday, I got hit by my Blade 180 CFX. Lost orientation and panicked. Turn my back to it and flew it right into myself. Stupid and dangerous.
Ron_R is offline        Reply With Quote Quick reply to this message
Old 11-10-2014, 11:51 AM   #470 (permalink)
Ooo glad that wasn't worse!
Old 11-10-2014, 07:29 PM   #471 (permalink)
Thanks. I really did get lucky. Those small blades spinning at 4200 RPM can do some damage.
Old 11-10-2014, 07:53 PM   #472 (permalink)
Thats the nice thing about Micros! They bite but they don't mangle.
Rick
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
Old 11-11-2014, 09:47 AM   #473 (permalink)
People have killed themselves when a 700 size hit them.
M52 POWER! is offline        Reply With Quote Quick reply to this message
Old 12-10-2014, 02:32 PM   #474 (permalink)
Originally Posted by jrwalte View Post
A couple issues.
Super fast spool-ups have happened causing really nasty injuries:
1) You can have a normal / standard throttle curve starting at 0 with idle ups at flat 80's or 90's.
2) At the bench / field, wherever; with TH disengaged and collective stick at lowest position (0) the heli will not spool.
3) Accidentally flick / bump / miss-handle the IU switch and it WILL almost immediately spool up (from 0 to 80%) in a couple of seconds.
You could also have auto rotation bail-out on your ESC with flat-line governed throttle curves. Even with throttle hold on, if you forget to zero out the ESC; once you get out of throttle hold it WILL almost immediately spool-up to the last rpm range obtained before hitting TH.
In other words: no soft start in either case with very dangerous outcome.
Thinking is difficult, that's why most people judge. - Carl Young.
Felix the cat is offline        Reply With Quote Quick reply to this message
Old 12-10-2014, 05:50 PM   #475 (permalink)
It only takes 30 seconds to take the main blades off. Unless you are setting pitch or have the motor unplugged you should get in the habit of working on it without the blades on. If you set up a lot of governors you will get in the habit of keeping the blades off. Everyone of my helis will spool up as soon as turn off throttle hold. Super soft initial spool up however so you grab the blade and hit throttle hold. My normal idol up 1 and 2 are all the same with different head speeds.
Alees Rush 700 x3, Alees Rush 750, XLPower 520, NX4, 250 quad racers, Tesla Power servos, Force batteries
cajkat1073 is offline        Reply With Quote Quick reply to this message
Old 01-29-2016, 08:27 AM   #476 (permalink)
Apparently no one injured themselves in 2015. That's either great news or time to bump this thread.
Rick
Old 01-29-2016, 10:03 AM   #477 (permalink)
Rick
With registration now in place, 2016 won't have any injuries either! All our problems are solved! Thank god for the FAA!
Old 01-30-2016, 12:48 AM   #478 (permalink)
Originally Posted by ChasHeliCop View Post
I was really not wanting to admit this, but here it goes. Was working on the Heli, thought I had already binded the Dx7, well, I guess not. And I didn't have the Throttle Hold on for some reason. Anyway, my radio started beeping, "low battery" signal, I looked over, saw the display, and reached over and flicked off the radio. Not a good thing to do. I soon discovered turning off the radio unleashed the "BEAST". I don't have pictures of my finger, because I could not hold the camera, bandage at the same time. The finger was much worse.
Usually, transmitters failsafe is what ever all the switch positions are during bind. You must have binded w/ maximum throttle.
facebook.com/AntDX316
It's my responsibility to make sure it works and know what could go wrong despite what everyone else is saying because they do not see what I foresee.
AntDX316 is offline        Reply With Quote Quick reply to this message
Old 01-30-2016, 07:24 AM   #479 (permalink)
Please don't pollute this long running thread with FAA garbage. There are plenty of venues for that already.
Rick
Old 02-01-2016, 12:32 PM   #480 (permalink)
Jokes are no longer allowed on HeliFreak. Got it.
