Go Back   HeliFreak > R/C Helicopter Support > Gaui Helicopters > X5
X5 Discussion and support of the Gaui X5
Old 07-28-2014, 04:41 PM   #1 (permalink)
Default CC Ice 2 80HV ?
Hi,
Does anyone know if this will work for the X5 and will it fit in the bottom?
Or do you really need at least a 100 amp ESC?
Using stock motor, bls 251, savox 1258 cyclic, mini v, 2 sats
cRash_landing is offline        Reply With Quote Quick reply to this message
Old 07-28-2014, 04:53 PM   #2 (permalink)
I was able to squeeze a CC Edge 100 in between the frame halves....just barely. I think the 80HV is close to the same dimensions, but that would be easy enough to cross reference....it needs to be at least as narrow as the CC Edge 100.
However if you're running 6S I think it would be wise to go with a 100A controller. I think you can get away with the 80HV if you're running 12S.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
Old 07-28-2014, 04:59 PM   #3 (permalink)
Default Re: CC Ice 2 80HV ?
+1 on the Edge 100 (full, not Lite) just barely fitting between the frames. Did mine recently. If yours is thicker, you will run out of width quickly.
Are you going 12S? I don't fly that hard, and only 2300 governed, but I've had a 130A spike already. On 6S, 80A would be somewhat small. Fine on 12S, though.
Sent using Tapatalk.
Old 07-28-2014, 08:44 PM   #4 (permalink)
I ran an 80hv for 2 years. First year on 6s and 2nd year on 12s. It never failed. Stuck it to the side of the frame under the gear
Specter 700 x 2--Diabolo UL--Compass 6hvu--Logo 600--oxy5+, oxy5, Oxy3, oxy2, SAB Mini Comet
Cajun Aircraft
B.Ewing is offline        Reply With Quote Quick reply to this message
Old 07-28-2014, 09:48 PM   #5 (permalink)
Thanks for the reply's
Are you guys running the CC 100 in gov mode? How do you like the gov?
Old 07-29-2014, 05:24 AM   #6 (permalink)
Yes, currently using Set RPM, on the latest FW (4.19?). It seems pretty good to me, but I'm no expert.
I may try my iKon's governor in the future, but I'm not looking to further-complicate things at the moment.
Old 07-29-2014, 10:33 AM   #7 (permalink)
Excellent, that's good to know.
I've run the Castle gov on other helis and it's really good for an ESC based governor. But if I have a flight controller that has external governor functionality I prefer that...Mini VBar on my X5 and Ikon on my 450X running through Castle ESCs. The Edge series ESCs make that pretty easy since they have that AUX output for the RPM signal as well as the "external governor" throttle mode.
