Old 09-17-2012, 01:11 PM   #181 (permalink)
I'm still flying my original tail bearings, probably 50+ flights, including one gear-stripping tail strike, and another "blade-trimming" tail scrape that required blade replacement. Never had the tail apart. No problems still.
There must have been a bad batch of these.
Blade 200QX, Align T-Rex 450 Pro 3GX,
P-51, SU-26XP, Carbon Cub, Cessna 182,
F/A-18, Blackjack 29, Slash 4x4
hydro_pyro is offline        Reply With Quote Quick reply to this message
Old 11-10-2012, 07:29 AM   #182 (permalink)
Firstly, Hi to all- it's my first post after reading lots on here.
I've had the same tail problems and after replacing multiple bearings and most things in the tail setup- I was concerned it was a balance problem.. I think found the real culprit, the hub the grips screw into. It's just not staight, like a bent feathering shaft. I thought this would happen in a crash (there have been plenty..) so bought a few spares and at least 50% of them were out of true. The arms are so short that any slight bend in them would create a real bearing muncher. Hopefully just a bad batch from align.
The bearings are so tiny, over tightening the grip screw could easily damage them.
I'm also using the blade 400 pitch rod and fittings- it's a thicker carbon rod than the trex and the fittings have just shoulders so the rod slides through really easily- the servo is boom mounted.
cjarv is offline        Reply With Quote Quick reply to this message
Old 12-04-2012, 06:48 PM   #183 (permalink)
http://www.oomodel.com/tarot-tl45034...k-p-63945.html
Not even that one is immune to problems!
2 flights on mine and one of the bearings sitting towards the hub seized. The rest?....look like they have been used and abused! :@
Need NEW bearings!
AMA #976001
HELIS: TREX 500 (6s), Trex 600 ESP (12S) & Trex 550 (12S): ALL FBL
PLANKS: Hangar 9 Pulse 60, Alpha 40 & Great Planes Revolver
nieves50 is offline        Reply With Quote Quick reply to this message
Old 12-07-2012, 08:45 AM   #184 (permalink)
I thought this might be part of the problem, but I could never be sure if it was bent or not - it's hard to see. It wouldn't take much of a bend to put all the load onto one spot on the bearing. And those outer grip bearings are so tiny...
Blade NanoCPx
Walkera V120D02s
T-Rex 450 Pro V2 (iKon FBL, Castle Ice Lite 50)
DX8
FFF_Ferret is offline        Reply With Quote Quick reply to this message
