Old 02-16-2011, 04:12 AM   #21 (permalink)
Originally Posted by celm View Post
does this gyro have to be set in rate mode first?
DO you mean on startup ? I like to center the gyro by flicking in between heading and rate mode or you can just keep the tail straight from the rudder stick !
John
Old 02-16-2011, 08:08 AM   #22 (permalink)
I mean setting up he tail in mechanically in rate mode,then bring the heli to a hover and fix the linkage to get ride of drift
Trex 700E DFC V-Bar , Trex 600N , Logo 600 SE FBL V-bar, Logo 600/550 FBL V-bar,Logo 400 FBL V-Bar ,Goblin 500 V-Bar, Blade 130X , Blade MCPx , Blade 500X
celm is offline        Reply With Quote Quick reply to this message
Old 03-04-2011, 02:26 AM   #23 (permalink)
Sorry about the delay in reply - no it doesn't have to be - the GY 520 was MUCH better setting up mechanically but the GY701 - like its 611 predecessor doesn't seem sensitive to this - probably not a bad practice to do anyway so you can even up the amount of tail authority each way though again with sophisticated piro rate regulation on the 701 this is much less necessary.
John
Old 03-30-2011, 11:57 PM   #24 (permalink)
Default gy701
pls help me to set up my dx7 to gy701 my bird is t-rex 600N le
jogarce
jogarce is offline        Reply With Quote Quick reply to this message
Old 04-20-2011, 07:51 PM   #25 (permalink)
Will this gyro/governor provide full functionality when using a Spektrum radio?
RotorsRus is offline        Reply With Quote Quick reply to this message
Old 04-23-2011, 02:31 AM   #26 (permalink)
Should do, as long as you have channels that you can allocate to the gyro and gov/switch, much of the setup can be programmed on the amp module. Seven channels would do it with gov switched on with throttle stick position
John
Old 04-23-2011, 09:16 AM   #27 (permalink)
mecuriell, as i understood the directions, the gov can only be switched on/off with a switch if you are using sbus anyways. correct?
thanks
rob
i have some helicopters and a box to control them with
satellites es pro tractus!
keep calm and don't panic
guitarherowanab is offline        Reply With Quote Quick reply to this message
Old 04-30-2011, 07:11 PM   #28 (permalink)
also, im using the 8fg with it. i cant figure out how to get the rpm's to switch with my flight modes. did i hear you mention there is another video on that?
thanks for the info
rob
Old 04-30-2011, 07:59 PM   #29 (permalink)
figured it out. i didnt have the rpm lead plugged in. is it normal for the rpm's displayed on the unit to be 1 or two rpm's off what is on the radio? i.e. it says 1950 on the radio and 1949 on the unit?
thanks
rob
Old 04-30-2011, 09:39 PM   #30 (permalink)
The gov can be switched on and off with stick switch or condition with sbus as well as with a dedicated switch. My rpm is the same on tx and 750, I think there is a way to set them the same if they differ but haven't got to that bit yet!
John
Old 04-30-2011, 11:02 PM   #31 (permalink)
what is a good throttle percentage to have the gov come on in normal mode. i have mine set at about 40%.
thanks
rob
Old 05-01-2011, 01:44 AM   #32 (permalink)
I like 40% gives good control of spool up/down, manual suggests 20%
John
Old 05-11-2011, 02:06 PM   #33 (permalink)
What gov gains are you guys using?
Steve
Trex 450SEv2/HS65-MGs cyclic/Spartan Quark/DS520 tail
Trex 450ProV2 DFC/CGY750 FBL/DS410s cyclic/DS520 tail
Trex 500ESP DFC/CGY750 FBL/YGE-120LV ESC/DS510s cyclic/DS650 tail
Blackout 330/OpenPilot Revo with FatShark 600mW VTX, Futaba 8FG 2.4GHz
Steve Evans is offline        Reply With Quote Quick reply to this message
Old 06-10-2011, 06:36 AM   #34 (permalink)
While we are talking about the 701. If I'm using a JR 11X radio, can I use a switch to turn off and on the governor? Or is this just an option with 8FG. I have one on order BTW
browndog is offline        Reply With Quote Quick reply to this message
Old 06-10-2011, 09:37 AM   #35 (permalink)
i believe it is only able to be turned on/off via a switch if you are using an s.bus receiver.
Old 08-17-2011, 11:45 AM   #36 (permalink)
can this gyro be used with Hitec Aurora 9 ?
Thx
evoIX is offline        Reply With Quote Quick reply to this message
Old 08-17-2011, 04:20 PM   #37 (permalink)
Thx
Yes shouldn't be any problem
John
Old 08-30-2011, 02:48 PM   #38 (permalink)
im planning on using a 701/gov combo on my newly aquired velo 90, using a 6008hs rx, non sbus, are all the features like headspeed etc still programmable by my 8fg like my cgy750?? or will it be limited??? and its only gonna be one xtra wire isnt it?? ot is it 2 extra wires???
Thunder Tiger UK Team Raptor G4 FBL
sponsored by
Rapicon fuels, Optipower, Model Heli Services, Thunder Tiger, EvoRC
http://www.youtube.com/user/squeakypete1?feature=mhum
troubledpetey is offline        Reply With Quote Quick reply to this message
Old 08-30-2011, 10:57 PM   #39 (permalink)
i believe the only thing that isnt possible without s.bus is turning the gov on/off with a switch. all the other functions are available. there are a total of 4 cables between the receiver and unit without s.bus, and 1 with s.bus
Old 09-20-2011, 11:29 AM   #40 (permalink)
I have been using this thing for a few months now and love it (Just the gyro, not the gov)... just started playing with the advanced features and surprised nobody has done a write-up on tweaking those settings. Maybe I will once I get a handle on all the features.
~SAB~ Goblin 700 ~Compass~ Warp 360 ~Blade~ mCP X (BL)
AMA# 977012
**Team BOCA Bearings**
BaconRaygun is offline        Reply With Quote Quick reply to this message
