Go Back   HeliFreak > R/C Batteries and Charging Support > Brand Specific Charger and Battery Support > Bantam
Bantam Bantam e-Station Charger Support Forum
Old 04-28-2009, 10:56 AM   #161 (permalink)
It is on the Align box, so does that mean it will also charge the Zippy packs?
Trex 500ESP / Spektrum DX7
flatsman9 is offline        Reply With Quote Quick reply to this message
Old 04-28-2009, 12:38 PM   #162 (permalink)
Yes
RC Accessory is offline        Reply With Quote Quick reply to this message
Old 04-30-2009, 05:05 AM   #163 (permalink)
Does anyone have a solution for e-station for windows on a 64bit operating system. It wont install on my vista laptop. I've tried contacting Bantam but they didn't reply.
Iv'e posted this problem in another forum but still don't have a solution.
Align T-Rex 450SE V2 JR DSX9
Align T-Rex 600 Super Nitro Pro (yellow & Black) Align T-Rex 700N Align T-Rex 600 EFL Pro
Greg1971 is offline        Reply With Quote Quick reply to this message
Old 04-30-2009, 05:07 AM   #164 (permalink)
Sorry, the Bantam program does not run on Visat 64-bit OS's.
Old 07-05-2009, 03:53 PM   #165 (permalink)
Default bantam bc8dx
how big of a power supply do i need to run this?right now every power supply i have tried will kick it off if i try to charge over 5 amps on my 6s 4900packs.then the charger says low voltage input?same thing happens when trying to charge 2 3s 2200 packs over 3amps at the same time but with no message,it will just start over at the beginning screen.thanks for the help.
helitomm is offline        Reply With Quote Quick reply to this message
Old 07-05-2009, 09:01 PM   #166 (permalink)
I use a 13.8V 30 Amp power supply.
Are you getting a Low voltage error or is the unit resetting?
Old 07-06-2009, 04:08 PM   #167 (permalink)
Both,i get the low voltage one when doing 6s and it resets while doing 2 3s at the same time.
Old 07-06-2009, 05:01 PM   #168 (permalink)
What is the voltage and amperage of your power supply? I put a watt meter in between the power supply and charger and charged 2 6S packs (5000 mah) at greater than 1C and was pulling about 19 amps according to the watt meter, voltage was 13.5 Volts.
Old 07-25-2009, 11:36 AM   #169 (permalink)
Exclamation
Hi,
Try with this software http://www.logview.info/
You can choose the language in "English"
(Still have a bug on Windows 7, but hoping it will be resolved asap)
Have fun
Patrick
Patrick74 is offline        Reply With Quote Quick reply to this message
Old 08-13-2009, 02:47 PM   #170 (permalink)
Default Using 2 x BC6 on a feild Battery
Hi,
Does anyone know if i can safely use 2 BC6 Dual power chargers off a 75amp deep cycle feild battery to charge my 6s(3300mAh) & 3s packs (850mAh).
Example:
Use both chargers to charge a 6s each, this way i can get both packs done in 1.5 hours meaning more flying time .
Cheers..
RcHeliVirgin is offline        Reply With Quote Quick reply to this message
Old 12-06-2009, 03:51 PM   #171 (permalink)
What do I need to charge two Zippy 3s 2200 hooked in series as a 6s 2200 using a BC6 charger,( Charging both at same time)
oldgrandpa
oldgrandpa is offline        Reply With Quote Quick reply to this message
Old 12-06-2009, 04:42 PM   #172 (permalink)
oldgrandpa
You need this http://www.rcaccessory.com/bantame-s...6twometer.aspx and the series connector on the pull down menu.
Old 12-06-2009, 05:01 PM   #173 (permalink)
Thanks for your quick reply
oldgrandpa
Old 12-15-2009, 07:46 AM   #174 (permalink)
Default Charging 2 3s Zippy 5000's
Hi Evan,
If you've answered this question before I apologize for the redundancy ahead of time. I have the dual balance board so I charge in series as a single 6s 5000 battery. No issues detecting all the cells and charging/balancing them. The issue I see is that despite the fact that I have the amperage set for 5 amps, the actual current applied never gets close to that. Usually it's around 2.5a yet if I charge 1 at a time the amperage starts off at 5a and obviously goes down from there like normal.
Any idea why it would do that?
Goldstripe is offline        Reply With Quote Quick reply to this message
Old 12-15-2009, 10:49 AM   #175 (permalink)
Read the center column for the likely answer.
http://sites.google.com/site/tjinguy...doing-the-math
- Chris
TJinTech heli...info...news...such
Helis: TRex 450 Pro - Protos - TRex 550e
Stuff: Spektrum DX7 - iCharger 208B - Hyperion G3
TJinGuy is offline        Reply With Quote Quick reply to this message
Old 12-15-2009, 12:49 PM   #176 (permalink)
Thank you TJinGuy! So if I follow the math then for (2) 3s in series I need:
25.2v * 5amp = 126 watts. Manual says max of 50 so basically the only thing it could charge at 5amps is a 5000mah 7.4v (2s) pack or less. That's awful and very misleading considering the manual doesn't state that up front, you have to go to the very last page for that info.
I wonder if that charging max output can be changed in some way?
Old 12-15-2009, 02:27 PM   #177 (permalink)
Yep people need to be informed about these things before they buy a charger and that is why I made the site.
Want to hear even worse? Check out the TP610c. It proudly states that it is rated for 6s and up to 10A but in reality it has a max wattage of 80W. That means you can't even charge a 2s pack at 10A !?!?!
- Chris
Old 12-15-2009, 02:54 PM   #178 (permalink)
Wow, that is bad! I've had the charger over a year so I'm sure it's out of warranty. I may talk to someone (electrical engineer buddy) about how to modify that wattage limitation. Probably not possible but it's worth a phone call.
Otherwise I'll be selling it off I guess. I'm sick of waiting 3 hours for my 2 3s 5000s to charge.
Old 12-15-2009, 03:04 PM   #179 (permalink)
That is why there is so much talk on the forums about higher power chargers. There are some that can output 350W! That will charge a 6s pack at nearly 14A! Maybe it is time to upgrade?
- Chris
Old 12-15-2009, 03:41 PM   #180 (permalink)
Sounds like it is time to upgrade. And I'm not even a heli guy. Well, I sorta am (little blade cx2) but I ran into this problem charging packs for my brushless revo. It's gotta be 3 times worse for heli guys!!
