Align 3G FBL System Align 3G FBL Flybarless System Software and Hardware Support |
11-01-2012, 12:26 AM | #1 (permalink) |
Lost control mid flight but I was doing everything corectly!?!?!
I was flying my trex 600 efl with a 3gx and futaba 6j radio and all of a sudden it would respond to any cyclic commands only collective and rudder so I landed it immediately after fighting with it some time in the air that was scary seeing $1000 fly around with no control and a 50+ inch rotor Spanish going anywhere it wants to I couldnt pinpoint what happened all batteries were fully charged and I turned everything off and then back only and test flew it again very low to the ground and everything worked fine again, what happened?
11-01-2012, 12:32 AM | #2 (permalink) |
Does the 3gx still have that reset mid flight issue?
Use been reading up on how people have had it reset in mid flight for no reason does this still happen or has it been fixed?
11-01-2012, 01:04 AM | #4 (permalink) |
sounds like typical 3GX weirdness.
CopterX 450 Black Angel FBL "Night Rig" | ZYX v4.0 PRÔTOS 500 FBL "Sky Whip" | Robird G31 Audacity P6 FBL "Phoenix" | MSH Brain | 12s Goblin Speed | iKon |
11-01-2012, 01:59 AM | #5 (permalink) |
I wuld make sure all wires are pushed all the way in the RX and 3GX..Then make sure non of the wires aren't cut from rubbing on the frame...If all looks good then get a better FBL system....
Team Align |
11-01-2012, 08:13 PM | #6 (permalink) |
How's it powered? Most likley that's the problem.
Align 450Pro 3GX, 500ESP/DFC 3GX, 500L, 550 DFC MicroBeast , Velocity 50 Vbar OS55 HZ-R, D380 DFC D420, G500 Sport Microbeast, All HW V4, X5 stretch 220 Flame Emax Bullet Force V2 VTX |
11-01-2012, 08:29 PM | #7 (permalink) |
The 3GX needs 6.0v and should have two power inputs and then check voltage like this. It will brown out and then glitch at 5.2v.
Scroll to the bottom of the page of this link. A check for our power supply http://www.vstabi.info/en/node/78
