Old 10-01-2014, 01:24 AM   #1 (permalink)
Default SAVOX frequency ?
Hi, what frequency should I use for a SAVOX 0262MG on the tail please ?
The specs on their website are 200-250 and there are 167 and 270 available on the AR7200.
Higher or lower ? What is the impact of the frequency ? Speed / response ?
Dawiev is offline        Reply With Quote Quick reply to this message
Old 10-01-2014, 02:45 AM   #2 (permalink)
I've been trying to confirm the same thing for a HS-0257MG cyclic servo. I've read anything from 165Hz - 333Hz !!
I'd go for 200Hz I think!!, but that's for my cyclic servos!!
If you go too high, you'll burn out the servo prematurely
For the HS-0262MG, some are using 270, some using even 333 without trouble. I can't seem to find a definitive answer.
Nano CPX x 3, mCPX-BL x 3,130X, 180CFX, Lynx 450X-L, T-Rex 250 DFC, T-Rex 450L, T-Rex 500, KDS Chase 360, SAB G380, G500 Spt, BT650, BT700-T, BT700 Spt, XLP520
"More the Knowledge Lesser the Ego, Lesser the Knowledge More the Ego" Albert Einstein
Miracle Boy is offline        Reply With Quote Quick reply to this message
Old 10-01-2014, 02:59 AM   #3 (permalink)
Hi, Red flashing = 165 . Red solid = 270. Blue solid = 560 Hz.
I'll try Red flashing first.
Old 10-01-2014, 06:51 AM   #4 (permalink)
avox SH-0262MG Super Speed Metal Gear Micro Digital Servo-savsh0262mg
Savox SH0262MG Micro Digital Servo
List Price $36.99
Map Price $30.99
You save $6.00!
Stock StatusOut of Stock)
Product Code: SAVSH0262MG
Add to cart
Add To Wish List
Description Technical Specs
This is the Savox SH-0262MG Super Speed Metal Gear Micro Digital Servo.
Features:
Over-spec refined design out performs ordinary micro size servo.
The metal case design looks awesome and allows for cooler and smoother operating temps.
Metal gears form a solid framework for precise control and operation.
Strict production and quality control of plastic components.
Our servos are totally green – from materials to production, these servos are environmentally friendly.
Ideal for tail servo for 250/450 class heli's and park flyer airplanes.
Dimensions(mm): 22.8X12.0X25.4
Weight(g): 13.6
Speed(@4.8V sec/60): .08
Torque(@4.8V oz-in): 11.1
Speed(@6.0V sec/60): .06
Torque(@6.0V oz-in): 16.7
Gear: Metal
Bearing: 1BB
Case: Aluminum
21 Tooth Spline
Frequency: 200-250hz
Pulse Width Frequency: 1520
renefigueroa is offline        Reply With Quote Quick reply to this message
Old 10-01-2014, 10:40 AM   #5 (permalink)
Sounds like a safe bet
Old 10-01-2014, 08:05 PM   #6 (permalink)
I run my SH0262MG on 270hz. There is a thread on the 300x forum. page 5 Servo Summary post number 19. I also run the SH0264MG at 270hz, neither get very warm.
Blade 450X - Savox, Scorp 2221-8 13t Slant Edge Lite50
Blade 450X (3D) - Hitech Servs Std ESC and 420 Motor
Blade 300X - Savox Servos, lynx tail, OWB, Talon 35, Hyperion 2213 3585 14t std main, DX6
andycrazy is offline        Reply With Quote Quick reply to this message
Old 10-02-2014, 12:02 AM   #7 (permalink)
I received the following directly from Savox.
To answer your questions:
1520 US pulse width, 250 - 333hz for orange servos and 200-250hz for the black line.
Their first message wasn't *exactly* clear. A response to "these servos are black and orange."
Your servos are 250-333hz. Any of our servos that have the orange band are classified in that hz rating. Alternately a servo such as SC0252mg is a perfect example of our 'black' line with the 200-250hz rating.
LizardMan is offline        Reply With Quote Quick reply to this message
Old 10-02-2014, 05:42 AM   #8 (permalink)
Humm, interesting!! does this only apply to tail servo's?
I have the orange banded 0257 cyclic servos. IFAIK, they should be set up to run at 200Hz, which is bellow the 250 - 333 Hz range, obviously.
MB
Old 10-02-2014, 10:07 PM   #9 (permalink)
https://www.helifreak.com/showthread.php?t=492617I
use this info all the time
Jaybird
I love to Fly every day
over 1000 flights on my 450X
jaybird111 is offline        Reply With Quote Quick reply to this message
Old 10-03-2014, 02:44 AM   #10 (permalink)
Thanks for the link Jaybird111
I'll bookmark that!! VERY handy!!
MB
Old 12-08-2014, 09:00 PM   #11 (permalink)
Jaybird
Old 12-11-2014, 01:02 AM   #12 (permalink)
I recently put a 0262 in the tail of my 450x with MSH Brain FBL and I could not get the tail to behave. I went nuts trying to iron out vibrations that never bothered this machine before.
Out of desperation I switched from 250 to 333hz.
Problem solved, and it runs cool.
Ted
HeliWobbles is offline        Reply With Quote Quick reply to this message
Old 12-11-2014, 07:42 AM   #13 (permalink)
Think I'm going try the 0264 on the 450X at 333. I got it at 270 but it does not hold as good as my 0262s on the 450 3d conversion and 300x, they are amazing though set at 270.
