Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions |
08-12-2014, 06:02 PM | #161 (permalink) |
Diabolo 700(yellow Black)
90° dampering Scorp 4535- 4+4 YY 560 KV @ 19t pinion Scorp Commander 160 Opto Scorpion Competition 4500 Packs & Scorpion performance 4500 Packs Linus HV² BEC MKS HBL 850 MKS HBL 880 Spartan Vortex VX1n MS Composit Rapid 710 FBL Rails 116 @ silver 26 pulley |
08-21-2014, 06:07 AM | #162 (permalink) |
MiniCopter Diabolo:
Scorpion 4525-520 Ultimate Kontronik Power Jive 120 HV HeliCommand HC3-SX Torq-9180 HV Cyclics x 3 Torq-9188 HV Tail x1 Rail 716/106 Blades 2S Lipo Unregulated Futaba RX/Telemtry
Helicopters Don't Fly - They Beat The Air Into Submission Logo 500SE Minicopter Diabolo 700 Banshee # 45 700 LE and 850 |
10-17-2018, 08:56 PM | #163 (permalink) |
Diabolo ‘18 700
Pyro 700-45L MKS 575SL Jive Pro 120 w/ Telme Neo Rail 716/116 R2 Buffer Lunsford Aluminum screws Red tail pulley 16T pinion Diabolo ‘18 BE 800 w/ tri tail Pyro 800-48L Xpert R2 K160 w/ Telme Neo Xblades 806/116 R2 Buffer Red tail pulley 19T pinion Triabolo BE 700 (soon to be a 800 w/ tri tail) Pyro 750 Xpert R2 K160 w/ Telme Neo NHP 680/Radix 110 R2 Buffer Red tail pulley 18T pinion
Henseleit’s / Diabolo’s / Kontronik / VBCE Last edited by Spencerkey; 10-19-2018 at 04:20 PM.. |
10-19-2018, 03:43 PM | #164 (permalink) |
Just realised I never posted my setup here after finally settling on components... and then I changed a few things around more recently. The current setup is:
Original version Triabolo 700 NHP 690 mains and 110 tail Dekker Pyro 700 / 530 Kv Jive 120HV (originally had a K160 on it but discovered that amp draw was really quite low) R2 Prototyping cap pack as a buffer RJX fs 0521HV servos on the swash Fut BLS276SV on the tail Spartan VX1N 13 tooth TDR pinion for low headspeed on 12s
HD Cell 750, RJX Vector, TDR, TDSF, Kasama Dune and Faifa, Minicopter Triabolo 700, Beam Avantgarde, JR E8 leggero, Suzi Laos, Shape 9, Shape S8, Rave 450, TRex 500, Raptor E700, Compass Warp, Steam 700, Spirit, Spartan, Jeti. |
10-30-2018, 01:23 AM | #165 (permalink) |
I used to have a Diabolo set up with a Pyro 750 running 14s with a 115 amp Jeti Mezon and had no issues. Like Trillian I had Kosmiks and found the amp draw to be low enough that it was not needed. This leads me to question are the high amp Kosmiks really needed? I see at the beginning of the thread that many people were using other smaller ESC's without incident. Then people start to change and most are using the higher amp ESC's. Is this overkill just because or are others doing something I am not that causes higher amp draws? I know speed runs cause higher but what else am I missing.
I ask because I am returning to flying after about four years off and am planning on going the Diabolo route again and am trying to decide if I was missing something before and was just lucky even though my amp draw was well under 100 given my mild 3D/sport flying?
You can't reason with crazy people! |
11-02-2018, 09:53 PM | #166 (permalink) |
You'll see no higher peaks now than you did 4 years ago with your flying. The push to higher esc nominal ratings has been driven by progressively harder 3D and certain speed models that were overamping and causing the K200 to run a bit hot.
The one thing to be aware of if you happen to choose a JivePro120 which replaced the PowerJive while you were gone is that because the esc has such a fast processor, it will pull back power at 160amps or more peak when the PowerJive wouldn't "see" them before they had already passed. Identical current specs, but JivePro is much "smarter". Ben Minor |
11-03-2018, 12:46 PM | #167 (permalink) |
Ben
Thanks for the reply. You confirmed what I was thinking. I looked back in my records and found that my KDE 700 motors on both my Goblin 770s had average amps of 40-50 with spikes up to around 200. I switched these out to Pyro motors when I switched over to a Diabolo and Triabolo but as my memory serves I believe the amp draw was no more with these two motors. My flying style has not changed so think I don't need to go crazy with high end ESC's. If I get crazy later I can alway upgrade if needed.
05-03-2019, 04:08 AM | #168 (permalink) | |
I'm not sure that is the good ratio Gear. It's for the 700. The 700 UL is a 600 stretch. Then, the main gear is 210 and not 196...... Simon
GOBLIN 380 - 420 - 500 - 500 SPORT - 570 - THUNDER SPORT / LOGO 480 - 690 / OXY 3 - 4 VBAR CONTROL TOUCH - NEO - KONTRONIK AND YGE ADDICT |
05-03-2019, 10:45 AM | #169 (permalink) |
CHC Benefactor
You realize the 700 UL is not 7 years old like the post you quoted and the 600 also did not exist back then as well?
Playing with gravity one heli at a time Dancing with gravity one flight at a time |
05-05-2019, 11:47 AM | #170 (permalink) |
Perhaps I'm in late?
05-07-2019, 03:58 AM | #171 (permalink) |
CHC Benefactor
Never too late for a Diabolo. Gerd has not been idle so lots of options now
12-22-2019, 04:46 AM | #172 (permalink) |
.... just to bring the thread back to life:
Diabolo '18 700L, Black Edition: Egodrift Tengu 4525HS 550, Pinion 18T BLS 471/BLS 276 Hobbywing 130aV4 AR7700/TM1000/j-log S32 VBar NEO VTX 717, RT 116 aluminum screws (non critical places) red tail pulley, rigid head, battery tray TOW 4.9kg with 4400/45C battery Ciao Michael
our hangar: minicopter helis, YGE/Spirit/Futaba BLS/Jeti Last edited by Rabid121; 12-25-2019 at 10:25 AM.. |
12-22-2019, 09:49 AM | #173 (permalink) |
Very nice 👍
Sent from my CLT-L09 using Tapatalk |
01-12-2021, 06:50 AM | #174 (permalink) |
Just ordered my first minicopter 700 last weekend. I got the 550 around Christmas and now have to have a 700.
Diabolo 700 Black Edition- Rigid head- Tri tail/silver pulley- 19t pinion Main Blades- vtx 697 or 717. Will try them both and decide which ones i like more. Tail Blades- Rotor Tech 106 Motor- Pyro 750-56l comp Esc- Kosmik cool 210 hv-i Servos- Cyclic-Futaba bls272 Tail- Futaba bls276 Fbl- Vlink Neo Batteries- 5100mah 12s maniax Target headspeed- 1950 |
01-12-2021, 12:29 PM | #175 (permalink) |
Nice 👍 you're gonna love it!
Sent from my SM-G981B using Tapatalk |
01-15-2021, 03:49 PM | #176 (permalink) |
A friend of mine flies a Diabolo 700. I never really paid much attention to it until this summer when I gave it a close look and was quite impressed....enough so that I decided to order one. Since I already have a few 700s, I decided on the Diabolo 600. It's complete and ready to fly. Just need the snow to go away and the temperatures to go up!
Diabolo 600, Classic canopy with carbon fiber windshield, black Diabolo decal and Tenax rear canopy mounts. Skids and head with follower arms are from the UL. I'll be starting off with a 20T motor pinion. KDE 600XF 530 kv motor 12S 3300 Thunderpower and Gensace IKON2 Jeti REX 7 receiver KDE R2 cyclic servos Futaba BLS276SV tail servo Rotortech 610U main blades Rotortech 105 tail blades Kontronik Jive Pro 120HV with a heat sink 2S lipo backup in parallel with Jive Pro BEC
Protos Evo 700: Goblin 700C : Diabolo 700 SE: Oxy 5 Meg: Goblin 570 : Diabolo 600 : Mini Comet : Oxy 2 : Futaba 18SZ : Jeti DS-16 : Jeti DS-24 : Kontronik Kosmik, Jive Pro and Kolibri: Scorpion Tribunus: MSH Brain 2 : BK Brushless : Xpert R1 and KD |
03-16-2021, 11:28 PM | #177 (permalink) |
I built a Diabolo 600 in the fall so now I have decided on a Diabolo 700 BE. It will have.
Egodrift 4530HS-510 motor Scorpion Tribunus 200amp ESC VBar Neo MKS HBL599 Servos ProTek 270 SBL R2 Buffer Revo 715mm Main Blades Rail 116mm Tail Blades
soXos Strike 7.1 L, Diabolo 600, Logo 600, Kraken 580, Protos 380 Evo |
03-22-2021, 12:53 AM | #178 (permalink) |
You have this ready by the June FF? Really looking forward to seeing this!!
...Once upon a time there were Nitros, flybars & frequency pins...Shawn |
03-23-2021, 10:24 PM | #179 (permalink) |
I hope to have it ready for June. It on route now. I have all the electronics. My custom canopies will be a while.
08-29-2021, 05:01 PM | #180 (permalink) |
Let's go I bought a Diabolo 700 Black Edition again 👌🏻🤙🏻
Setup *MKS HBL 575 SL cyclic *MKS HBL 880 tail *Xera 4530 530kv (rewound as a xnova 4530) *YGE 205 V2 Black Edition or YGE 135 Aureus *Vbar neo vlink pro *DH 711mm blades (for now) *NHP tail blades *SLS 12s 5000mah 65/130c Verstuurd vanaf mijn AC2003 met Tapatalk |
