Old 06-14-2014, 06:29 AM   #101 (permalink)
Is the belt slipping or your one way? Big differense and same result?
scott s is offline        Reply With Quote Quick reply to this message
Old 06-14-2014, 06:36 AM   #102 (permalink)
Belt is slipping, one way slipping would not make black powder everywhere around the pinion.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 06-14-2014, 06:43 AM   #103 (permalink)
check your front idler pulley for frozen bearing and/or deformed pulley. You guy's havvin so many problems and I have none! Time to step back and take a real good look IMO. Running it govorned should NOT make a bit of difference.
Old 06-14-2014, 06:46 AM   #104 (permalink)
post some up close photos.
Old 06-15-2014, 11:04 AM   #105 (permalink)
Doing my first pinion change on this thing and went to reference the MSH instructions to make sure I did it right, but it has no directions on pinion install. I forget how to do it - I have a new 15T and Y support here.
Green loctite the bearings inside the pinion? Then green loctite/CA onto the motor shaft? or no? I don't want to seize up this OWB by doing it incorrectly.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
DCflyer is offline        Reply With Quote Quick reply to this message
Old 06-15-2014, 11:37 AM   #106 (permalink)
You don't need any green loctite on anything, unless you want to lock the OWB.
Just put the bearings in the pinion, and the the pinion on the shaft, the small washer on top of the pinion, and then the Y support with bearing.
Make sure the OWB spins the right way before setting the belt tension and locking the motor and Y supports in place.
Old 06-15-2014, 01:24 PM   #107 (permalink)
Sweet thanks man
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 06-17-2014, 11:13 AM   #108 (permalink)
One more thing.............do I need to reprogram my YGE's govstore (spooling it up to max throttle etc) when swapping a motor or do I just need to get in there and change timing/PWM and be good to go?
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 06-17-2014, 01:10 PM   #109 (permalink)
You need to redo Gov-store
Old 06-17-2014, 02:37 PM   #110 (permalink)
Ok, and as a follow up question.............can the govstore be done with the motor disconnected from the drivetrain or should I have the belt around it? Obviously the blades removed.
I did this a long time ago, but can't remember the process now.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 06-18-2014, 10:08 AM   #111 (permalink)
You can do it either way. If you are going to keep the motor engaged I would remove main and tail blades. I had a slightly too high gear ratio and lost a tail blade doing the gov store full throttle. Not Fun!!!
maarset is offline        Reply With Quote Quick reply to this message
Old 06-18-2014, 02:42 PM   #112 (permalink)
What let go when you lost a tail blade? To date I have set up Gov Store on all my helis with mains & tails on, but I run lower gear ratios.
Mini Protos, Voodoo 400, Protos 380, Protos Leggero 700 & 700X, Diabolo 700
Chris Nifty is offline        Reply With Quote Quick reply to this message
Old 06-18-2014, 02:53 PM   #113 (permalink)
I find I get better results when I do the calculation run-in with blades on, so long as the heli is not ubber over geared that is, if it is over geared I error on the side of caution and do the run-in sans blades.
On a "new build I do a calculation run-in no blades, then add them, get my trim flight and all other setups done, then I re-do the "store" step again...
Fly... crash... rebuild... repeat... Fly hard my friends! Team Lynx Mini Protos
Trexwilly is offline        Reply With Quote Quick reply to this message
Old 06-18-2014, 10:35 PM   #114 (permalink)
Ok got it.
Govstore at 4.0v/cell with belt on for some load.
Then tuning flight if I ever get this tail assembly on
Then redo govstore
Unplug BEC
Program card on
Then ESC on
activate govstore
unplug program card
unplug esc
cycle power - plug esc back in
low throttle with linear throttle curve at 100/100 endpoints
6 beeps counting off cells and then a chime signaling its ready for govstore spool
spool up to full throttle and hear the "hesitation"
spool down and unplug
Anything i'm missing here? Do I have to redo govstore if I swap pinions?
I don't have to redo my endpoints again do I? I guess I might as well.........
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 06-19-2014, 06:47 AM   #115 (permalink)
If you alter the gearing, yes you have to redo Gov Store. When I complete a new build, I just enable regular Gov, then spool her up to a reasonably high throttle with only the mains removed and check for vibes. If all good, I set Gov Store, install the mains, chuck in a battery @4V per cell and go outside and spool her up to 100% and wait for the tail kick.
Old 06-27-2014, 08:38 AM   #116 (permalink)
Been busy, but was able to install the 2520 last night. Have some fitment issues.
Question - those of you that did this swap, what did you do with the motor wires to get good fitment? The issue is that the motor wires aren't really that long so when I try to slide the motor forward, the wires from my YGE will not go down into the airframe because the motor wires aren't long enough, causing the connectors to make a very tight "U-turn" down in the airframe. They're as far forward as the can go it seems.
Therefore, I can't slide my YGE up into the frame any farther without clearance issues (its in the nose cone under the battery tray), and this in turn creates fitment issues for the canopy.
Why is there always such limited space to work with on these machines? How did you guys get your motor and wires in there cleanly and how exactly are your YGE's mounted?
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
Old 06-27-2014, 12:02 PM   #117 (permalink)
My YGE is mounted caps up, with the motor wires going outside the frame.
