Go Back   HeliFreak > R/C Helicopter Support > Minicopter Joker/Diabolo Helicopters
Minicopter Joker/Diabolo Helicopters Minicopter Joker/Diabolo Helicopters Discussions
Old 02-14-2014, 05:36 PM   #1 (permalink)
Default Diabolo S setups
Hey guys would love to see your setups with this thread
Diabolo S #6
Diabolo
TDR
N7
crash at 42 is offline        Reply With Quote Quick reply to this message
Old 02-14-2014, 06:59 PM   #2 (permalink)
Thought a new thread best for this
I'll kick off:
14S TP 4400 G8 packs
HC-3X FBL driving 255HV servos
DH 696 mains probable Rail 95 tail
Kosmik 200 with Optipower Ultraguard backup
Pyro 850 Comp but not finally decided on this yet, toying with 4535 LE or even 4525 Ult
John
Old 02-14-2014, 07:40 PM   #3 (permalink)
Mine will start as a 12s setup, well, because I already have everything(except motor). It will be as follows:
Batteries to be determined. Time for an upgrade
X-Nova 4530-500
Jeti Mezon 130a w/Optipower Ultraguard
BLS451's on cyclic
BLS 251 on tail
DH 711's
Beast X(AR7200BX)
the plan is to eventually swap it over to 14s and upgrade to the Kosmik 200.
_____________________
JRAY is offline        Reply With Quote Quick reply to this message
Old 02-14-2014, 07:50 PM   #4 (permalink)
Awesome keepem rolling in
Diabolo S #6
Diabolo
TDR
N7
Old 02-15-2014, 02:12 AM   #5 (permalink)
12s 5000 Mah 45C Gensace
Pyro 750-56 Comp
Kosmik 160 + fan
BLS 451 Cyclic
BLS 251 Tail
Beastx
Jlog 2.6
Linus buffer pack
Pinion to be confirmed - assuming 20T
DH 711 blades
William Blake Team Kontronik
TDR1, Banshee 850 # 22
Diabolo 700
wblombard is offline        Reply With Quote Quick reply to this message
Old 02-15-2014, 04:23 AM   #6 (permalink)
14s Gens Ace 4400 65c
Xera 4530-450 serial #7 of 10 made
Kosmik 200 with custom heat sync/ fan
Torq 9180/9188
Vbar Silver pro w/ Bluetooth
22T pinion
2s Buffer pack
DH 711's
craigdieselmac is offline        Reply With Quote Quick reply to this message
Old 02-15-2014, 05:48 AM   #7 (permalink)
HF MR Support
12s 5000 mAh 60C Gensace
Pyro 750-56 Comp
Kosmik Kool 200HV
2S 800mAh buffer pack
BLS 157 HV x 3
BLS 256 HV
VBar silverline Pro
DSMX sats
Pinions : 20, 21, 22
Blades choice currently undecided from the pool of:
Spin Blade Matt black 700
DH 711s and 691s
SAB 720s speed blades
Scott Gray 710s
Plastic tails
Lynh
TommyBear is offline        Reply With Quote Quick reply to this message
Old 02-17-2014, 05:50 PM   #8 (permalink)
My Setup. Just got the box today!!!
14s 4400 Thunder Power G8
3x BLS 273SV
1x BLS276SV
Futaba CGY 750
Cool Kosmik 200
Pyro 750-56 Comp
DH-711 Blades
Richard Zappe
Team Kontronik USA PeakAircraft
Wh1teAfr1can is offline        Reply With Quote Quick reply to this message
Old 02-22-2014, 08:11 PM   #9 (permalink)
My friend (#38) just asked me what motor to use for 14S and Kosmik 200
I did not know if to say the Pyro 750-50 or the 800-48.
Aiming for 2600RPM, What would be the difference in performance if any between those 2 motors?
Santiago
Team Minicopter www.PeakAircraft.com
Team Kontronik
Scorpion Power Systems - Bavarian Demon
plankdriver is offline        Reply With Quote Quick reply to this message
Old 02-22-2014, 08:39 PM   #10 (permalink)
I'd say 800-48 comp
Sent from my GT-I9305 using Tapatalk
Darcy Brown- ZenRC Field Rep
RED! Goblin 500, Quantum 4120-1200, BK Servos, from www.zenrc.com.au
ORANGE! Goblin Speed, Kosmik Kool 200HV, Pyro 850-50L, BK Servos, Brain
NevErSn0w is offline        Reply With Quote Quick reply to this message
Old 02-22-2014, 10:10 PM   #11 (permalink)
Why?
Old 02-22-2014, 10:12 PM   #12 (permalink)
Cause..lol
Old 02-22-2014, 10:19 PM   #13 (permalink)
I think youd burn out the 750
helicraze is offline        Reply With Quote Quick reply to this message
Old 02-22-2014, 10:37 PM   #14 (permalink)
Yep, youll burn out the 750, 800-48 is okay!
Old 02-22-2014, 11:18 PM   #15 (permalink)
I hope the 750-56 Comp wont burn out....I honestly doubt it though
Diabolo 700
Old 02-22-2014, 11:22 PM   #16 (permalink)
HF MR Support
You will be fine William, I will let you know my progress.
Quick comparison
Pyro 750 is 47 gm lighter than the 800.
The 56 has the lowest internal resistance as well and has proven itself at world speed records using 14S on Team TDR.
Lynh
Old 02-23-2014, 01:20 AM   #17 (permalink)
The pyro 750-50 Comp is what Gerd recomended in the begining.
So now is not enough motor?????
Team TDR used the 750-56 last year at the IRCHA speed cup because they were restricted to 12S.
If I do the math 14S will put the 750-56 way over the 25000rpm they recommend.
Team Kontronik
Old 02-23-2014, 01:26 AM   #18 (permalink)
The unlimited class was 14s and I'm pretty sure Oliver used a pyro 750-56
Richard Zappe
Old 02-23-2014, 03:29 AM   #19 (permalink)
HF MR Support
Santiago
This is where Kosmik is your best friend. On 14S the 750 -56 with 20t is at the sweet spot of 2600HS at Kosmik preferred 80% throttle.
This is what I intend to do if I can get my hands on some 7S 4400. They are as rare as hen's teeth ATM.
Lynh
Old 02-23-2014, 04:08 PM   #20 (permalink)
This is what I intend to do if I can get my hands on some 7S 4400. They are as rare as hen's teeth ATM.[/QUOTE]
Revolectric has 7s 4400mah
70c also available
Diabolo S #6
Diabolo
TDR
N7
