MSH Mini Protos MSH Mini Protos Helicopter Support Forum |
04-25-2014, 02:16 AM | #1 (permalink) |
Loctite on motor bolts?
On page 31 of the manual, it does not mention that loctite is required when installing the motor onto the motor bracket. Is this a mistake?
DX6i, Jeti DS-16 MCPX BL, Mini Protos 6S, Stingray 500, SG704, SG381, OMP M2 V2 Brain, SK 720, Spirit Pro, Brain2; HW, Kosmik Heli-X, AccuRC, RF 7.5 Transmitter Interface Edition |
04-25-2014, 02:38 AM | #2 (permalink) |
Maybe because the motor gets quite warm and Loctite softens with heat? Anyway, I´m using no Loctite, but spring (locking) washers to give some additional security.
2x MCPX I Gaui »X1« I 2x Mini Protos I Protos I DX8 |
04-25-2014, 03:18 AM | #3 (permalink) |
I guess it would be to avoid getting any loctite in the motor.
I'm not using anything special, in fact I'm only using 3 screws on my 2520-1360, because the 4th one would go right through a wire, and I can't be bothered to shorten it. I check them regularly, and I've never had one back out on me (only 130 flights though). I think the larger diameter means they are less prone to backing out.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE "Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615 FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F |
