Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 90 Nitro
Outrage Velocity 90 Nitro Outrage Velocity 90 Nitro Helicopter Factory Support Forum
Old 11-20-2011, 06:58 PM   #1 (permalink)
Default Main gear issue
Hi all, 1st build on an Outrage 90, not a bad build. My problem is it would seem the main gear with the one way hub has the ablility to slide down towards the tail gear. I started to hear this odd noise on it's madien and found this...I've attached a few pics to try and show the problem. Any tips would be great as to why this does this?
Thanks guys.
ID:	268204   Click image for larger version
ID:	268205   Click image for larger version
-you can't FIX stupid-
AMA# 935732
Altec is offline        Reply With Quote Quick reply to this message
Old 11-20-2011, 07:44 PM   #2 (permalink)
If I am right, the bearing in the hub slipped out in your case (see pic 1 for the right one).
The lower bearing block can be adjusted up & downwards. In my case, it needed to be at its highest position to eliminate any play of the main & drive gears, and to ensure that the bearing seats in the hub completely. (see pic 2)
After you rebuild it, I bevlieve you will find that the main gear & pinion are at the same level (see pic 3)
Hope this helps.
Stanley
ID:	268223   Click image for larger version
ID:	268224   Click image for larger version
ebulahan is offline        Reply With Quote Quick reply to this message
Old 11-20-2011, 07:52 PM   #3 (permalink)
I though it was because the lower bearing block moved down as well however I did not have any up and down play on the main shaft. The one way sleeve was tight between both blocks but it looks like there is nothing to prevent the hub from sliding down on the sleeve..
AMA# 935732
Old 11-20-2011, 08:59 PM   #4 (permalink)
It is because the bearing does not seat in the one way hub completely. Take out the bearing and see if there is something inside the hub preventing the correct assembly. Then put the bearing back into the hub. The internal diameter of the hub could be little bigger than the bearing's outer diameter, which could make it hard to put them together. Do not use hammer or you might not get the bearing out again...
Old 11-20-2011, 09:30 PM   #5 (permalink)
I can push the bearing back in fine and in doing so moves the main gear back where it's supose to be. It will all sit flush and everything is perfect. However once the heli hovers for a few min it slides back down on its own.
AMA# 935732
Old 11-20-2011, 09:44 PM   #6 (permalink)
Uh, it shouldn't be like that. Did you have the main shaft bearing blocks wrong facing? The middle bearing block should face down and the lower block should face up.
Old 11-20-2011, 09:48 PM   #7 (permalink)
Yip I checked 3 times. The one way sleeve fits perfect in-between both bearing blocks and has no lateral play.
AMA# 935732
Old 11-20-2011, 09:57 PM   #8 (permalink)
I will have a look at mine when I go home and see if there is someway to sort it.
Old 11-21-2011, 02:53 AM   #9 (permalink)
After checking mine, I am guessing the problem is your hub. Normally, the shoulder of drive gear (pic 1) should withstand the hub bearing (pic 2), thus the hub cannot slide down on the sleeve. Is there anything missing in the hub? I've encountered some parts assembled by factory that accidently missed something.
ID:	268265   Click image for larger version
Old 11-21-2011, 08:22 PM   #10 (permalink)
I made a video...better shows what's going on. And nope, checked several times for missing parts.
[ame]http://www.youtube.com/watch?v=twDsmF3TPCI[/ame]
AMA# 935732
Old 11-21-2011, 10:55 PM   #11 (permalink)
Can't you just Loctite that top bearing into place?
skinart76 is offline        Reply With Quote Quick reply to this message
Old 11-22-2011, 05:23 AM   #12 (permalink)
That's what I'm leaning towards...but not sure if that would be a proper fix.
AMA# 935732
Old 11-22-2011, 08:13 AM   #13 (permalink)
Uh sorry to inform you that YouTube has been blocked and banned here in China for some political reasons...But I understand what the problem is.
It should be the solution. At the very begninning I thought that some part like washer or bearing were missing in the hub because I belived that those parts completely filled up the inside of the hub to prevent the slide. But I was wrong. Based on my inspection, the part that keeps the distance between main and drive gear is the LOWER BEARING in the hub. As the shoulder of drive gear withstands the lower bearing, the main gear cannot slide down towards the drive gear. So basically, as long as the lower bearing is fixed by CA, problem will be solved. To be more safe, CA the upper bearing in the hub as well.
Old 11-22-2011, 03:14 PM   #14 (permalink)
Heres a link to the vid in case you wanted to see it... http://ededicatedplus.com/gear/
Yes I looked at again last night and I would have to CA the bottom and top bearing in place to prevent the one-way hub from sliding down. I just find it odd (that I can see) that I'm the only one with this problem.
AMA# 935732
Old 11-23-2011, 12:35 AM   #15 (permalink)
I've seen the vid and the problem is the same as what I thought. I am glad that the solution was found out finally. Good luck and happy flying.
Cheers
Old 11-26-2011, 03:43 PM   #16 (permalink)
Well I got 3 flights on her now, got the v-bar dialed in and man she flies great. I did use bearing thread lock on both the upper and lower bearing of the one way hub. So far so good, no movement. Thanks for help
AMA# 935732
Old 11-27-2011, 06:22 PM   #17 (permalink)
Nice! Glad it's worked out.
