Old 08-24-2012, 07:33 PM   #1 (permalink)
Default Dips / Tilts to the right
Hi. 16 flights on the 300 and the last 3 flights, I have noticed once per flight a un commanded tilt / dip to the right maybe 15-30 degrees (looking tail in) The helicopter pops right back into a normal hover, after the tilt. Should I be looking at (maintenance) or something else.
Blackanthem is offline        Reply With Quote Quick reply to this message
Old 08-24-2012, 07:50 PM   #2 (permalink)
My heli did this once, after I removed the zip tie on the beastX.
I wasn't sure if that was the real reason, or maybe it just initialized poorly that one time.
After that, I put the zip tie back on, tight. The rest of the batteries flew just fine.. I'm going to experiment with this a bit and just use the 3m 411 tape to mount it, as others have indicated this may work better than the thick padded tape.
On edit:
I just read another thread, which had a post from hubschauberpilot from a while ago:
DO NOT REMOVE THE CABLE TIE FROM THE AR7200BX !!!
I have done it, and soon encountered a permanet drift/roll to the right at higher speed (even with carbon blades).
The beastX obviously needs to be strapped to the (weak) frame on this little light heli !
Current fleet is getting smaller.
Blackout Mini-H, WarpQuad 230, Blade 200qx, Nano QX, UM F-27q Stryker, UM P51 Mustang, F4F Wildcat, DX6 radio.
Previous fleet: mcpx, 300x, 350qx,450x, qav400, DX7s
InFocus is offline        Reply With Quote Quick reply to this message
Old 08-24-2012, 08:05 PM   #3 (permalink)
I have read here, that the sticky tape that comes with the 300X could be influenced by heat. It has been in the 90's the last few times I have flown it. I do notice a very slight tail "wag" in the helicopter.
Old 08-24-2012, 10:11 PM   #4 (permalink)
It's been my experience that the stock tape is much too soft when the temperature is high. Maybe that's why it works well in Germany (and Illinois) but pretty much sucks everywhere else. All my BeastX units are much happier mounted with thin 3M tape.
Chris Boultinghouse
JustPlaneChris is offline        Reply With Quote Quick reply to this message
Old 08-25-2012, 02:22 AM   #5 (permalink)
I had the exact same problem. I'm not talking about drifting or anything, mine was an uncommanded sudden tilt to the right - scary. Nearly crashed it once.
Fixed mine by remounting to the boom support using different thinner mounting tape. I'm not using a zip-tie
Blade 180CFX | 300X
MSH Mini-Protos 3S, Spirit FBL
Parkmaster 3D, Funjet, Sbach 3D, FrSky Taranis, FPV260 Quad, Pheonix Sim
stevebaker is offline        Reply With Quote Quick reply to this message
Old 08-25-2012, 04:56 PM   #6 (permalink)
Hi again. I am trying to see where the vibrations are coming from. One thing I noticed is that when the main rotor blades are extended. Holding the helicopter tail in, holding the blades near the grips, I can get a up and down motion, that looks like play. As an example, if you were to pick up the helicopter by the blades, near the grips, it would not be solid, the blades would move up. If I am not making sense I can post a video.
450X | 450 3DX | 300X | 130X | Mcpx BL | Mcpx | SR | 350QX | Mqx | Nano Cpx | Nano Qx | 120 SR | And one DX8 to rule them all.
Old 08-25-2012, 05:26 PM   #7 (permalink)
we've had some of the hottest weather out here in the midwest for some 20 years. I know for a fact that the tape they use is quite sticky. The stiffness is debateable!
I seen on youtube, fwiw, A guy using velcro to strap on his beast x. Said it would shake a bit causing unwanted corrections without it.
I wish the controller was on top, and I may still go that route, but I believe it's fine where it is and a lil covered from a crash, just don't undo the tie or the frame and the controller will get together and cause problems, that's what I get.
Happy flying ....Brad
Trex 550e v2,BLADE 450X ,130X NEVER! McPX BRL, 120DO2s, McPX, Stryker , Edge 540qq,UMX BEASt, Crak Yakx2,
YAK 55M 35CC,A.W. yak 54 20CC,3dhs 330sc 57inch, ALL ON MY JR9503
bradharvy is offline        Reply With Quote Quick reply to this message
Old 11-25-2014, 05:31 PM   #8 (permalink)
So here is what I found after a lot of playing with mine. I removed the main rotor blades and spooled it up. I noticed that only at medium head speeds I had significant vibrations. Then I removed the tail blades and spun it up again. The vibration was gone. Replaced tail blades and spooled it up again. The vibration was less, but still there. After looking carefully at my tail boom I noticed it was bent very slightly. Almost could not see. I bent the tail boom back and now the vibrations is almost gone, and it no longer rolls right. I think the cause was that the boom was bent just enough to allow the belt to rub against it causing vibration.
bsjohn84 is offline        Reply With Quote Quick reply to this message
Old 11-25-2014, 06:31 PM   #9 (permalink)
If there is some up and down play on the mainshaft, loosen the alloy ring that sits on the top bearing. Pull up on the head and push the ring down and tighten the grub screw. You should be able to get rid of it.
Blade 450X - Savox, Scorp 2221-8 13t Slant Edge Lite50
Blade 450X (3D) - Hitech Servs Std ESC and 420 Motor
Blade 300X - Savox Servos, lynx tail, OWB, Talon 35, Hyperion 2213 3585 14t std main, DX6
andycrazy is offline        Reply With Quote Quick reply to this message
Old 11-26-2014, 08:40 AM   #10 (permalink)
The RROD (Right Roll of Death) phenomenon is nothing new to the 300X. Over the years the consensus has generally been that the vibrations which cause it must be of a frequency significantly higher than is likely to be generated by the main rotor mechanics. And the areas most likely to generate such high frequency vibrations are the brushless motor and the tail rotor mechanics. It's unlikely that a belt rubbing would be the root cause although that would cause other problems like destroying the belt and static buildup.
The fixes that most often worked are as follows.
  1. Replace the main motor. Poor tolerances in the stock main motor will cause the shaft bearings to wear out resulting in high frequency vibrations in the beginning and a complete bearing failure eventually.
  2. Replace the tail rotor hub/grips assembly. The stock tail hub assembly is sometimes poorly balanced and so people have had good results by switching out for an Align 450 tail hub and grips to reduce vibrations from the tail.
  3. It's possible to over-tighten the screws in the stock plastic tail case such that some warping can occur. This causes the bearings to become slightly out of alignment and results in vibrations from the tail. Only tighten them down to the point where they are flush and don't wrench down on them.
In my case it was definitely the 320H motor. It started doing the RROD thing after only a few flights and the bearings gave out and seized within a dozen flights. After replacing the motor I never saw the problem again in the two years I've owned the heli.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon)
Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi)
AMA Member, HCAM Member
Nelsonisms is offline        Reply With Quote Quick reply to this message
