300X Blade 300X Helicopters Information and Help |
10-04-2014, 10:40 AM | #1 (permalink) |
300X weights
For grins I thought I'd post the weight of my 300X --with battery. I didn't notice another recent thread. Main reason was I just spent some time with reducing the AUW of my TRex 250 (292 g with pack) and also noticed the recent announcement by OXY and Microheli on their "300" size helis (250mm blades). At least to me, the OXY seems a bit heavy, but time will tell if that matters or not.
My 300X has a Don's Wicked motor (heavier than stock) Talon 25A ESC (lighter than stock) Blade CF Main Blades Standard Stock Eflite 3s pack The rest of it is stock (DS76 servos, AR7200BX, etc. So total weight comes out at 487g. |
10-04-2014, 01:37 PM | #2 (permalink) |
Mine has
Parkfly motor Talon 25 Cheap cf blades (lighter) Lynx slant gear, owb, dfc head, tail blades and tail fins Hyperion 1100 mAh 3s pack stock servos and fbl controller Weighs in at a little over 461g, flies great at that weight. |
10-05-2014, 02:53 PM | #3 (permalink) |
I have a full lynx build with kst servos pushing 600g rtf!! It flys sweet tho.
Team MSH USA - Cyclone Blades MSH Prôtos 380 Brain 2 MSH Prôtos Max V2 Brain |
10-05-2014, 05:09 PM | #4 (permalink) |
The Airetic
I really thought this thread would be more popular. C'mon gentlemen! Spill it, don't be embarrassed. There's plenty of guys around here that like fat girls too!
Free Agent....With standalone opinions. |
10-06-2014, 08:41 AM | #5 (permalink) |
Stock frame w/brace
Hyp 3585 / talon 35 5065 cyclic / 306g tail Lynx tail, head, swash, mg/owb, plastic blades Fiberglass canopy 565g with pulse 1350 - it's all muscle??? Flys great IMO but I am no stick banger.
Go fly one! |
10-06-2014, 10:24 AM | #6 (permalink) |
Mine is definitely the super heavyweight in this bout.
Gaui X5F 6S (VBar), Lynx 450X-L 6S (Ikon), Lynx 300X-L 4S (Ikon), Blade 180CFX 3S (Ikon) Lumenier QAV400 4S (Vector), Lumenier QAV250 3S (Naze32/CleanFlight), CYE Stingray 500 4S (TG Multi) AMA Member, HCAM Member |
10-06-2014, 02:51 PM | #7 (permalink) |
MH frame
TGY 306 servos Typhoon 2218 yep 40 CF Boom Lynx Swash, hub and grips Lynx tail Super skids Lynx canopy CF blades MH gear and OWB AUW=615g I didn't really like flying this much as it tended to drop very fast when coming off the collective... but I've just replaced the 13t with a 14t pinion... It now flys great at 3700 and up to 3900.
Anything worth doing, is worth doing badly. |
10-06-2014, 04:14 PM | #8 (permalink) |
Closed Account
I'll weigh mine later today. Its mostly lynx now.
10-09-2014, 12:19 AM | #9 (permalink) |
Closed Account
428 grams with no battery
Lynx frame Lynx tail Stock servos Lynx motor Lynx one way and gear Talon 25 |
10-09-2014, 09:51 AM | #10 (permalink) |
It seems some are posting weights with pack and some without so, for those that don't have this bird in front of them, a 3s 1350mah pack for it would be around 117g with an EC3 connector.
Go fly one! |
10-09-2014, 01:40 PM | #11 (permalink) |
The Airetic
I agree. AUW is a much better representation.
10-09-2014, 06:23 PM | #12 (permalink) |
Closed Account
Going to be different based on the battery used. Different C rated batteries weight different amounts and then different brands will weigh different too. Some of us also fly 1500mAh batteries.
10-09-2014, 10:47 PM | #13 (permalink) |
Just got mine back together today
621g rtf!! Feels as floaty as my rex 500 tho with the 275mm blades and 2213-14 powering it
10-10-2014, 03:06 PM | #14 (permalink) |
And so it will be heavier. No crime, but batteries add weight just like other components. They also can add flight time, and potential of higher current draw, if the setup tries to pull it.
10-10-2014, 04:32 PM | #15 (permalink) | |
The Airetic
My interest in this thread is really about how many total grams people are slinging around in the air.
10-10-2014, 06:45 PM | #16 (permalink) |
I just ordered some 1300mAh 4S packs so mine's about to go up a little more on the scale. Oh well, it's a sickness. I'm going to pump this beotch up to around 3800 RPM on 245mm CF blades and see what it can do. Hopefully the tail will hold better than with the plastic 275mm stretch setup.
10-10-2014, 11:42 PM | #17 (permalink) | |
TP packs? Stock blades? I'm staying stock length as well. Our machines will def be on the heavy side with 4s and the 2920. Did you ever run it at 3600rpm on stock length to see how she does? Just wondering. I haven't maidened on 4S yet since i'm waiting on a Lynx mainshaft to arrive. Not risking it on stock shaft with this kind of power. I suspect mine will be in the 650g range as well. I'll post findings in next few days.
OXY5 MEG / 12S RAW KSE / 14S TDSF / 6S OXY rep |
10-11-2014, 09:15 AM | #18 (permalink) | |
To answer your other questions, I'm using Turnigy Nano-Tech 1000mAh 4S 45C packs right now. If they fit OK I'll be switching to Nano-Tech 1300mAh 4S 45C packs once they arrive. I have been flying with the 275mm Lynx plastic blades, but after this crash last weekend due to tail blow out I'm going to try it with 245mm Lynx CF blades to see if the tail can hold on better. If it does, great. If not then I'll have to go back to the drawing board.
10-11-2014, 10:42 AM | #19 (permalink) | |
Aren't you tail heavy with the stretch and 1000mah packs?
10-11-2014, 09:55 PM | #20 (permalink) |
Just weighed mine. Looks like Nelson still has me beat. I'm at 631g AUW.
CFX frame Lynx carbon boom (stock length) Lynx vertical & small horz fin Lynx Ultra Tail Lynx landing gear Lynx Tail servo mount Lynx OWB hub & main gear Lynx slant 13T pinion Lynx heavy duty belt Lynx tail pushrod Lynx head block Lynx spindle Lynx main shaft Lynx lower frame supports Microheli ESC mount Lynx ball links Lynx canopy supports Lynx fiberglass Protos style canopy Lynx turnbuckles Lynx dampeners Boca bearings in main blocks and motor Blade carbon tail blades Edge 253mm mains Scorpion battery strap Savox SH-0263(cyclic) & SH-0264(tail) Talon 35 Scorpion 2216-14 4S TP 1300mah 70C pack Beastx DSMX sat All servo/esc leads shortened
