Belt CP E-Sky Belt CP
Old 12-01-2009, 07:34 PM   #1 (permalink)
Default 11 tooth pinion on a Belt Cp V2?
Anybody replaced the stock 10 tooth pinion, with a 11 tooth pinion on a Belt Cp V2?, What are your comments, on the performance?, is it worthwhile?
Raptor 50 Titan,Align Trex 450 Sport V2, Blade 500X, Blade Mcpx V2,Blade 180 CFX,Traxxas Aton Quad,Blade 230S,Mia Microflight Gyro Copter,Jr 8103, Spektrum DX8,Spectrum DX7g2...
VortechZ230 is offline        Reply With Quote Quick reply to this message
Old 12-01-2009, 09:17 PM   #2 (permalink)
As a matter of fact, I ordered another motor and mount with the 11 tooth pinion yesterday.
Will let you know the difference.
I am not giving up on my Belt, the motor is the only thing left stock.
I honestly believe that it has potential
Clarence
Beam E4 (Beautifully Engineered Action Machine)
Blade mSR (just plain fun)
Kyosho Caliber 700 (550 size electric running on 8s)
CPV2 is offline        Reply With Quote Quick reply to this message
Old 12-02-2009, 06:50 AM   #3 (permalink)
I once put a 11t pinion on the stock Belt CP V2 motor, but mounted in a CopterX with a 150 t maingear, which is even heavier than a Belt. To my big surprise, it flew quiet well for basic stuff. I would imagine it could bog very easily though when trying 3D-like stuff. But it worked in a 900 grams heavy CopterX. This motor is rated at about 200 Watts, which may seem little compared to for example a Scorpion 2221-8 at way over 400 Watts. But don't forget you only need like 100-150 Watts to hover around, also with the Scorpion. These are measured values, no guessing. Even less in a lighter Belt.
Worthwile ? Depends on the use and your level of flying, you will of course outgrow it at some point. But such a pinion is very cheap, so it might be worth the benefit of the extra headspeed, when flying calmly. The headspeed in the Belt should go from a maximum average of 2400 RPM to 2650 RPM with the 11 t pinion. This numbers only apply for full throttle. Will be lower in a hover.
Power and performance ratios are usually not linear. You'll need like 4 times the power to get 2 times the performance, so the stock Belt motor still does a reasonable job. Some people told me it would even not be able to lift off, lol.
Logo 800 - TDR 14S - TDR 12S - Logo 500SE - Logo 400 - Furion 450 6S mini-V - 300X - 150S - mCPX - Schluter Bell Huey Cobra '74 - Aura 4 hotliner - F27D Evo
redbird300 is offline        Reply With Quote Quick reply to this message
Old 12-04-2009, 05:11 PM   #4 (permalink)
Well, I installed the 11 tooth pinion and also threw in a Helimax main gear that I had laying around since I had it apart.
Hovered it for two batteries.
Belt CPV2 is more stable, more responsive.
The Helimax gear took care of a lot of the vibration that I had.
I think I lost about a minute of hover time on the batteries.
ESC and battery temps were a tad lower than usual, about 10 degrees.
Overall for me it was worth it
Clarence
Old 12-07-2009, 05:07 PM   #5 (permalink)
Hey Clarence, good to see it worked out. might try the same, which pinion did you use and where did you get it?
Gaui X5!
Gaui X3!
Outrage G5
Blade mCPX BL | MultiWii Quadrotor
branflake is offline        Reply With Quote Quick reply to this message
Old 12-07-2009, 07:00 PM   #6 (permalink)
Hey B12;
I get alot of my Belt parts from Think RC
http://www.thinkrc.com/spare-parts-e...lt-c-9_41.html
I went ahead and bought another motor and motor mount also, did not want to risk messing up the shaft on the motor trying to pull off the pinion.
They sell the pinions as a set of 4.
All I needed was one.
It took a little convinsing to tap it on all the way(tight fit on the shaft)
Just install it to the same distance as the 10 tooth(maybe just a tad not as far), but when I was done it lined up with the Helimax gear perfectly cause that gear moved up higher when I set mainshaft play even after pressing the one way bearing up about 1 mm higher to contact the upper bearing when installed.
If you want a gear I would be glad to send you 2 of them just in case you mess one up putting it on.
Just PM me with your address and I will send them to you(no charge)
Clarence
Old 12-07-2009, 10:30 PM   #7 (permalink)
Wow...can do!
Between you and Mike/B2theE this must be the friendliest hobby+web forum I've ever found!
Consider PM sent, and send me your paypal addy...Ill at least comp you back for postage.
Brandon
Gaui X5!
Gaui X3!
Outrage G5
Old 12-09-2009, 07:33 PM   #8 (permalink)
B12;
PM sent
Merry Xmas.
Clarence
Old 12-10-2009, 05:07 PM   #9 (permalink)
You know it's great being a mod round here - nothing to do - everyone's just so friendly
Cheers, Bugster
Bugster is offline        Reply With Quote Quick reply to this message
Old 12-12-2009, 08:35 PM   #10 (permalink)
Update on the 11 tooth pinion that I installed a couple weeks ago on the Belt CPV2.
To bring you up to speed on my DX6i settings:
Normal throttle curve= 0.0/ 75.0/ 90.0/ 95.0/ 100.0
Normal pitch curve with +/- 11 degrees= 46.0/ 61.0/ 76.0/ 88.0/ 100.0
Devils switch throttle curve= 100.0/ 95.0/ 90.0/ 95.0/ 100.0
Devils switch pitch curve= 0.0/ 27.0/ 54.0/ 77.0/ 100.0
I have hovered and moved around for about 5 batteries last week to get the feel for the higher head speed( a lot more stable hover and quicker response from the sticks).
Lost about a minute of battery(that is okay cause it is a give/ take thing)
Today in my back yard, I was doing some punch ups and downs at full throttle(yah, I am getting more comfortable), wanted to check the tail hold of my new GY292 gyro with JR DS3400G tail servo.
Tail held pretty well and had a lot of fun moving that Belt at incredible speeds.
After 2 batteries of that, flew my Beam for 3 batteries(what a sweetheart that Beam is).
Popped in another battery for the Belt and the blades would barely move and noise coming from the heli.
Bearing popped out(the one next to the pinion gear).
Took the motor out and super glued the bearing back in and all is well.
I guess it could not take all of that abuse.
I will not give up on the belt just yet.
It is a forgiving machine.
Will test my repair tomarrow with some good yanking around and up and down.
By the way, I have all of my parts coming for my next project.
EXI 500 build.
Clarence
Old 12-12-2009, 10:58 PM   #11 (permalink)
How are you getting -/+11 pitch on your Belt-CP V2? Not on the stock head I presume...
3Dmuse is offline        Reply With Quote Quick reply to this message
Old 12-13-2009, 12:11 AM   #12 (permalink)
Barzaun;
Well, all I can say is that I had set my stock plastic head to +/- 11 degrees pitch and my clone cnc head is set at +/- 11 degrees pitch using my DX6i tx...
I am going to see if I can go 12 degrees with no binding issues tomarrow.
I have just assembled a stock plastic head all from new parts for a back up head if and when I crash the cnc head.
What are you asking ?
Clarence
Old 12-13-2009, 07:42 AM   #13 (permalink)
Originally Posted by CPV2 View Post
Barzaun;
Clarence
Did you actually measure 11 degrees of pitch? I wasn't able to push the stock head past 9 degree without the plastic O-shaped controlling rods rubbing on the main blade grips. What servos? What lengths on the servo horns?
Old 12-13-2009, 10:37 AM   #14 (permalink)
Barzaun;
Yes, I do own an Align pitch gauge for 300 to 700 size blades.
I have done the direct to swash modification using the Titan servo trays.
I have three JR DS285's on the swash.
Servo horns at 8mm ball distance from center so my rods are straight up and down.
I level the swash and make sure all arms are even and 0 degrees pitch at mid stick.
I go into the DX6i swash mix menu and set the pitch adjustment until I get +/- 11 degrees.
Now as far as potential pitch range, I can get +/- 13 degrees, but get into a binding issue going full left and right.
At +/- 11 degrees it is not too bad, that is why I have stayed with +/- 11 degrees on the stock plastic head.
Although I could get rid of the issue by playing with the aileron swash mix, but I will just keep it as it is.(like I said, my stock head is my backup).
Yes, you got my curiosity up since it has been awhile since flown a stock head, so I put it on this morning and set it up as per the above paragraph.
By the way, the super glue held the bearing in for 4 batteries this morning
Clarence
Old 12-14-2009, 10:20 PM   #15 (permalink)
Darnedest thing happened today...A couple 11t pinions showed up in my mailbox from THE NORTH POLE. How sweet is that?
Well whoever this "S. Claus" is...thanks :o
Gaui X5!
Gaui X3!
Outrage G5
Old 12-14-2009, 10:29 PM   #16 (permalink)
I wonder who that could be
I grew up in the Quad City area about 30 miles from Moline in Whiteside county.
Anything to help a brother out
Merry Xmas;
S. Claus
Old 12-15-2009, 10:57 AM   #17 (permalink)
You grew up over here and then got out? They let us out??
How did you pull it off?
Gaui X5!
Gaui X3!
Outrage G5
Old 12-15-2009, 07:55 PM   #18 (permalink)
It was tactically done on a no moon night, so very dark.
They could not see me sneak over the border
Clarence
Old 12-17-2009, 10:31 PM   #19 (permalink)
I want to try a 11t as well, but am not sure how to remove the 10t pinion. Any suggestions? Thanks.
