Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > NextD - Rave 450 and 90
NextD - Rave 450 and 90 CJY Rave 450 and 90 Helicopter Kit - ND-YR-K001
Old 08-20-2016, 07:53 AM   #1 (permalink)
Default Not getting 6 degrees on FBL Setup
I have just built a Curtis Youngblood Rave ENV 700 kit that I had lying around in my hobby room.
Anyway, setting up with a Spirit FBL unit.
Everything is working well, but I was unable to get 6 degrees in Step 8 of the wizard (Head Geometry)
I went down as far as the software would allow (64) and was only getting down to around 7.2 degrees.
I have checked all the linkage rod lengths and ball locations etc. and I can't see anything I have done incorrectly.
Anyone have any ideas as to what I have done wrong?
Or can I fly like it is?
chrisd1972 is offline        Reply With Quote Quick reply to this message
Old 08-20-2016, 09:33 AM   #2 (permalink)
Would love to help out but don't be know anything about setting up a Spirit. Believe you will have better luck getting this question answered in the Spirit forum.
https://www.helifreak.com/forumdisplay.php?f=373
Good luck with the ENV, Curtis designed a great heli, love how mine fly.
Paul
Agile 5.5 - Q 4125-1100, YEP 120, Brain2 HD FBL / Outrage 550 - HK4020-1390, Edge 120, Brain2 HD
Rave Ballistic FSO - Q 4530-500, Edge 160HV, Brain2 HD / Protos Max V2 - MSH 4530-500, Edge 160HV, Brain2 HD
pctomlin is offline        Reply With Quote Quick reply to this message
Old 08-23-2016, 07:39 AM   #3 (permalink)
7.2 degrees pitch ?
You should be able to get 12.5 degrees pitch up and down no problem. This is measured with the blade 90 degrees to the heli.
And 8 to 9 degrees on cyclic. Measured with the blade in the same plane as the boom.
soXos Strike 7.1 L, Diabolo 600, Logo 600, Kraken 580, Protos 380 Evo
Freeskiken is offline        Reply With Quote Quick reply to this message
Old 09-06-2016, 04:12 PM   #4 (permalink)
The six degrees is with cyclic correct?
The geometry of the ENV was designed around the requirements of the Total G flybarless unit, perhaps optimized is the best word. Where you see this is when you try to use a FBL unit other than Total G and try to set it up. The only one I've seen the problem with was the VBar. The fix was to change some of the balls on the swash and some linkage. I've used the VBar for years and it works great, but you need to optimize the geometry FOR that unit.
Tom M
exfokkerflyer is offline        Reply With Quote Quick reply to this message
Old 09-10-2016, 09:26 AM   #5 (permalink)
I use BD3SX on all my Helis. I have for quite awhile. I have no problem getting 12.5 to 13.5 degrees pitch on my Rave 635. Or the 700 it has the same head. With the stock balls.
Old 09-10-2016, 10:09 AM   #6 (permalink)
Problem was not getting max pitch.
Problem was getting the 6% cyclic pitch.
Moved balls in a bit closer on the horns and it worked.
Old 09-12-2016, 10:16 PM   #7 (permalink)
Awesome glad you figured it out.
