Finless Bob's Helifreak Tech Room Finless Bob's Helifreak Tech Room - Tips and how-To Videos |
05-17-2006, 09:31 AM | #1 (permalink) |
Team Taco VP
430L motor fix
This was posted on my Gallery on RR and I pulled it out of a Google search Cache. I am posting it here for all to have.
______________________ Did your Align motor come apart? NOTE: You do not need to do this mod if the motor has "silver" end caps! The gold end caps are glued on but the silver ones screw on and the blue motor can is threaded! Just pin the top and bottom ends to the can. Super easy to do. Tired of your motor coming apart? After having two of my motors come apart even after gluing one myself, I decided a fix was in order. By the way, the reason my own glue job came apart the second time was because the top bearing failed!!!!!! I have a theory on why. I think the out of round main gear puts uneven loads on that top bearing which may cause it to fail early. So watch your mesh tolerances.... My opinion anyway. OK, so here is the fix: 1) Drill two holes through the can and the top plate 180 apart (e.g. one on each side of the motor). The distance from the top of the can should be 1mm which will allow it to go through the "center" of the top plates flange. To low and you will miss the top plate flange. 2) Cut 2 pins from music wire the size of the hole you drilled. I used a 1/32nd drill bit and music wire. I cut the pins long so they would stick out and allow me to get on them with pliers should I want to remove them to service the bearings again. 3) Glue the top plate on (I used epoxy) and make sure the holes are aligned. Insert the pins being sure to go through the top plate hole but not to far as to stick into the motor enough to interfere with the motors fan blades. Glue the pins in place (I used epoxy). Here are pictures: I now use screws instead of pins! Bob
"Don't Taco My Pack Dude!" NEW Video Link -> Safety Video #1 Video Link -> CAUTION using powerful tools! Video Link -> How to CRASH TWICE in one flight! Video Link -> Don't Taco! |
05-18-2006, 04:15 PM | #2 (permalink) |
Hey Bob. Glad to see you here.
I'm doing a new build on an SE. I'll do this mod as well as the 35g ESC mod before the first flight. Question: When you drill the four holes in the 430L, how do you keep metal particles from getting inside the motor and onto the armature and elsewhere? I have canned air to blow it all out afterwards, and although that should take care of the aluminum particles I'm concerned about steel particles from the can getting to places that the canned air won't blow clear. Also, is there a trick to separating the ends from the can? Thanks
op-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwop-thwo |
05-18-2006, 04:26 PM | #3 (permalink) | |
Team Taco VP
Bob
05-18-2006, 04:38 PM | #4 (permalink) |
Is there a slick Finless Bob trick to removing the ends from the main can?
05-18-2006, 05:00 PM | #5 (permalink) | |
Team Taco VP
BTW you know you dont have to do this fix to the silver end cap nmotors right? As for a slick way yes I kind of do... screw bolts into the end cap to use hand "handles" to pull the end cap off. You can heat the blue can a little to loosen the locktite... Bob
05-18-2006, 05:09 PM | #6 (permalink) | ||
Thanks again.
05-18-2006, 05:24 PM | #7 (permalink) | |||
Team Taco VP
Wow that was close! Yes the silver end cap motors the cap SCREWS on and the blue can is threaded so no worries about those coming apart! I will update my sticky post to say that! Bob
05-18-2006, 06:28 PM | #8 (permalink) |
Does the 420L have this separating problem too?
05-18-2006, 06:37 PM | #9 (permalink) | |
Team Taco VP
I have NOT seen a Silver capped 420 yet... Would you like me to ask Align? I can find out if you like but I bet the answer is no... Bob
05-18-2006, 07:32 PM | #10 (permalink) | ||
I was referring to the older 420L wth the gold endcaps: http://www.align.com.tw/shop/product...roducts_id=853 |
05-18-2006, 08:18 PM | #11 (permalink) | |
Team Taco VP
COOL! Man I gotta see that! GOOD for you! Yes I was also talking about the 420LF.. I do NOT think they have changed the design for that motor like they have for the 430L for the SE. I bet it is not screwed on like the 430..... Bob
05-18-2006, 09:00 PM | #12 (permalink) | ||
So you're saying... the 420L is not screwed in, and therefore it is susceptible to separating, right? |
05-18-2006, 09:15 PM | #13 (permalink) | |
Team Taco VP
Bob
05-18-2006, 09:26 PM | #14 (permalink) | ||
05-26-2006, 02:20 PM | #15 (permalink) |
the used rex I got that is a month old still had the gold end caps....when did they update? Or did I just get old stock.
05-27-2006, 07:15 AM | #16 (permalink) |
Team Taco VP
You probabaly got old stock! Was it an SE you bought? If not they have NOT updated the XL kits yet.....
Bob
06-05-2006, 03:26 AM | #17 (permalink) |
Bob the screws you used on the end caps were they self tappers or machine screw?
06-05-2006, 11:06 AM | #18 (permalink) |
Team Taco VP
They were self tappers.
Bob
