Mikado Logo Helicopters Mikado Logo Helicopters Discussion |
10-20-2011, 11:01 AM | #21 (permalink) |
We have made those yes, and could make more if that's what your after. I'll see if I can get a pic or 2 of those up here as well.
10-20-2011, 01:22 PM | #23 (permalink) |
Once a few reviews come in I may jump on this. Im hard pressed to drop a benji if there is no perceivable performance increase.
Logo 600se |
10-20-2011, 01:32 PM | #24 (permalink) |
FYI, I have had the I2 RC head on my Logo for over a year now which appears to be about the same height as this setup. The risk of a boom strike is fairly low with 623s but it becomes significant when you stretch to a 600se and 693s. If you run a lowered head, I suggest running your blades a bit tighter than normal, especially if you have a 600se.
What I don't understand is why your main shaft must be cut and redrilled when my I2 head does not. My I2 head appears to be at approximately the same height as yours. |
10-20-2011, 02:20 PM | #25 (permalink) |
Hi
Id like to try it. How do I proceed D |
10-20-2011, 02:36 PM | #26 (permalink) |
After seeing the logo400 i want one !! please let me know how / where i can order this kit
Will look great next to my fai-fa lowrider !!
Srimok FAI-FA Vbar | Logo400 SE Vbar |
10-20-2011, 03:46 PM | #27 (permalink) |
[QUOTE=BennyTRD;3335505]Ken has a set right now that he is putting on his 600. I would imagine that he will take a few sets to have in stock, but not 100% at this point.
I doubt the swash would go up that high to get the arms so that they wouldn't bind on the negative side. You could make up some links I suppose to accomplish this though. Is your concern more that you have an abundance of main shafts around? I do have a few Main Shafts but more worry about future source, running out, not doing them anymore or whatever the case. I still crash more than I would like to admit so may need a shaft or two per month. If you can do a version with swash driver incorporated using stock shaft/links I am in for an order right away. I hate messing with getting phasing right.
10-20-2011, 03:47 PM | #28 (permalink) | |
PM PP and In can send funds.
10-20-2011, 05:26 PM | #29 (permalink) |
Looks nice Benny! Price is fair considering whats involved. I just can see the performance gain though. Didn't we go through a lowered head phase already on Logos and the conclusion was no real advantage. Could be wrong though.
Either way looks nice Perhaps if I ever have that bad crash .....
yardbirdhelicopters.com #yardbirdheli |
10-20-2011, 06:12 PM | #30 (permalink) | |
Also on thier website they seem to Include a mainshaft with their head. I'd be interested to see the actual length of it compared to the stock 4075 Mikado shafts.
10-20-2011, 06:27 PM | #31 (permalink) | |
I'm going to send a kit to one of the best pilots I know who is interested. I'll see if he can fly his 500 stock first, then swap the head parts and try it again. If anyone can tell a difference it will be Greg for sure.
To be honest, I never noticed a performance gain, but I do like the way the heli's look afterwards and never having to worry about my phasing being slightly off. Im also no pro pilot either that can usually pick these slight differences out. Quote:
10-20-2011, 07:09 PM | #32 (permalink) |
Hrmm.... I just pulled out a stock mast and it is cut down. I could have sworn it used stock ones. Oh well.
10-20-2011, 10:50 PM | #34 (permalink) |
Could a few fellas that are interested in the stock height head with swash built in take an accurate measurement from the bottom of the stock headblock to the top of the swash driver on a 500/600 setup... All the logo's here have been converted
If a couple of guys can take a good measurement I will work up a version for stock height and stock parts... Chris... |
10-20-2011, 11:19 PM | #35 (permalink) |
L600 / Mines looks about 24mm (0.944879 inch), i think
mCPX BL |
10-20-2011, 11:26 PM | #36 (permalink) | |
MSH Protos 500, SAB 630 |
10-20-2011, 11:36 PM | #37 (permalink) |
Chris, I'm also interested in a stock head with built-in swash driver.
I measured 25mm on my Logo 500 head. -Dave
10-21-2011, 01:11 AM | #38 (permalink) |
I’m also interested in a head that can take stock main shafts. I’m always paranoid that my phasing is not 100% with the v-bar head, this should solve the problem and simplify things a lot.
10-21-2011, 01:30 AM | #39 (permalink) |
I'd also be interested in the stock height head as I can continue to use the hardened mainshafts. I noticed you're using the non-hardened shafts with the c-clip. Is that because they're easier to machine?
Perhap Mikado couls make a scaled down Xxtreme head for my Logo 400.
Regards, Jayson Logo 800Xx Silverline, Pyro 850-40L, Kosmik 200, 14S, 157 & 256 @ 8v Logo 400SE Silverline, Pyro 600-09, Jive 80+HV, 8S, 9660A+ 8900G @ 6v |
