Go Back   HeliFreak > R/C Helicopter Support > Electric Micro/Mini Helicopters > X400 and MX400
X400 and MX400 Ark X400 and HeliMax MX400 Helicopters Information
Old 01-04-2008, 05:49 PM   #1 (permalink)
Cool MX tail lowering my RPMs
The tail has some issue where if I apply right rudder, the rpm's drop slightly...Is this a common issue on the hmx450 tail? Anyone have same problems?
Just put in some TrueBlood red dampeners....All I can say is that the blades are tracking super nice!!!!
Trex450v2/cxhead,cc35,65MG,9650/401,2221-8/13T
Trex500ESP-8cell beast ICE100,Scorp 1210kv,510's,spartan/MKS8910
Trex600NSP--Hyper50,Align gov,Align pipe,7703D+8900,Hitec 5965's,s3003 for throttle
7c 2.4
DarkHeli is offline        Reply With Quote Quick reply to this message
Old 01-05-2008, 04:10 AM   #2 (permalink)
sorry I don't have any experience with the MX450 tail. however my mx400 seems fine
I hope this ends up being something simple for you to fix :-)
easy things to check:
-sure your not lowering the throttle stick a little?
-pots in your radio ok? (does the 9chp have an "output view" screen?)
ok more likely
do you have enough RPM to begin with?
try raising the points in your throttle cure up 10 points (except low throttle so you can still arm the ESC)
if that helps ... then keep reading .... but for some people it may be normal to have the ESC running at more than 85% durring hover
harder to check: (I wrote this first)
right rudder stick for most people turns the nose to the right... this would cause the tail rotor to fight against the torque more ... causing more load than turning to the left
However in either direction you should not see a notable spin down or loading.
I would think there may be a power problem in your config ...
too much resistance in the gears or belt (check pinion mesh and belt tension)
battery, ESC, motor, or wiring/connectors not up to the load of your setup
good luck
pam-mo is offline        Reply With Quote Quick reply to this message
Old 01-05-2008, 10:07 AM   #3 (permalink)
when you add tail pitch, there is more load on the motor and hence more load on the rotor, from drag i believe. mine does the same thing, bogs a bit under a hard piro. raise up your throttle curve should take care of it.
AMA# 906249
i'm now down to one heli (align sev2) but have an arsenal of 120+ mph jets. hmm...i think i see a pattern here lol.
istandalone is offline        Reply With Quote Quick reply to this message
Old 01-06-2008, 01:23 PM   #4 (permalink)
Well, the rpm's drop slightly...enough to see it on the gears..(the gear slows down a little and you can see the rpms lower, but there is no binding.) I will go outside later and test this all in a hover. I have recently rebuilt the tail and I thought I may have messed something up....I had to readjust the gyro settings and center the tail servo but thats about it. so the general consensus is that if the heli drops when I turn it, then the RPM issue is not too good...or am I missing something and the heli will "dip" no matter what?
7c 2.4
Old 01-16-2008, 04:57 PM   #5 (permalink)
Sounds to me like you've got the t/r belt way too tight.
AB
AirmanBob is offline        Reply With Quote Quick reply to this message
Old 01-16-2008, 06:36 PM   #6 (permalink)
AB
Yep. It was on there pretty darn tight....I repaired it a while ago and now its all working perfect!
I blew a main gear while in flight the other day though....!!! I was about 10-15 sec into my first nose in flight and I heard the grinding sound of a broken tooth! I hit Throttle hold and it went down from about 15 feet nice and slooooooow....My first auto ever!!!! I haven't even auto'ed on the sim!
7c 2.4
Old 01-16-2008, 09:06 PM   #7 (permalink)
Yup the x400 autos nice. My first out was hard cut off from miss programed esc and a cheep lipo.
Team Outrage
OPM - Fly it like it aint yours!
JR X9303 2.4 Baby. I have felt the difference and I like it!
Don"t make me list 'm all !
Raven_darkcloud is offline        Reply With Quote Quick reply to this message
