SR Blade Helicopters (eFlite) SR |
08-17-2012, 08:38 PM | #1 (permalink) |
SR HELP!!
I've had my sr for a couple of months now but all it wants to do is keep spinning, any help on how to possibly fix this, I've put a brand new tail motor, I'm a newbie so it could be anything im not sure
08-17-2012, 08:50 PM | #2 (permalink) |
Which way is it spinning?
Are you using the original factory radio? Have you connected the yellow wire from the gyro to the 5th channel bank on the RX? Are you at full throttle when it is spinning? Some questions to get this started.
OXY Heli and Lynx Heli Innovations Team Pilot SilentDRC.net -The Order of Brushless Witnesses |
08-17-2012, 09:19 PM | #3 (permalink) |
I fOrget what way I'll check tomorrow, it use to spin one way then if I moved the trim one click over its would spin really fast the other way, yes factory radio, I'm probably getting a dx8 next week though, not recently but I thought it might so I tried it with it plugged in but no help, it doesn't matter how much throttle
08-17-2012, 09:25 PM | #4 (permalink) |
Tail motor wired backwards?
Trex 450 Pro V2 3GX - Super combo w/ Tarot ZYX |
08-18-2012, 08:12 AM | #5 (permalink) |
Nope just tried reversing it just incase made its spin even faster, it spins counter clockwise, it doesnt matter how far my trim is over
08-18-2012, 10:12 PM | #6 (permalink) |
Try screwing the pot in the bottom of the ESC clockwise, quarter of a turn and see if it changes anything. Also wheres ur gyro set? Make sure its around 60% at least.
08-19-2012, 09:00 AM | #7 (permalink) |
Maybe the new tail motor is bad? Rather it be that than the esc....
7hvu, 6hv,,Prôtos,450Pro, DT520E some planks |
08-19-2012, 09:39 PM | #8 (permalink) |
Ive already put a brand new tail motor in, I'll try playing around with the pot and gyro abit, it didn't seem to help at all today
08-23-2012, 10:00 PM | #9 (permalink) |
Is it continuously spinning or are you spooling, seeing it spin like 90-180 degrees and killing throttle? Can you hear the tail motor engage at first? Definitely would go over setting up the 2-in-1 and gyro, would take the gyro out of the equation and get the tail working against main motor torque first. If it doesn't matter how much throttle, have you had it up to midstick?
Danno Blade 500x, Trex 500xt, just back after some time off. You don't ever really QUIT helis do you?? |
