Belt CP E-Sky Belt CP |
12-05-2012, 10:25 AM | #1 (permalink) |
Help
Hi guys, I need a little help. Myself I have blades but a friend asked me to repair his Esky belt CP v2. No I could do this ok but I told him that people have put an align trex 450 head on it to make it a little stronger. I'm sure I'll b ok with it as long as it is a straight fit. Please can u guys give me some advice. I.e is it worth doing? What head specifically is best and easy to fit? Do I use the belt cp main shaft and swash? Is it a straight forward fit or do I need to mod things, If so wat? Both me and my friend are still learning so prefer robust options over better performance if a sacrifice must be made. Thanx for any help in advance guys cheers
12-05-2012, 12:06 PM | #2 (permalink) |
check out the sticky
here how I did it and yes I used the belt cp main shaft and swash https://www.helifreak.com/showthread...107467&page=27
| Kraken 700 : Neo | Atom 6HV : Evo | Raw 580 : Neo | vbct | |
12-05-2012, 12:22 PM | #3 (permalink) |
Cheers for posting bk mate I will have a look
12-08-2012, 07:18 AM | #4 (permalink) |
Hello guys I have another problem on my mates belt cp now. I got the up graded parts but I went to centre the servos and the transmitter won't bind. I have looked around and seen there is a common problem. The bind LED in the bottom left is low and doesn't flicker, so I see this means the transmitter has stopped sending the bind code. I know the problem just wondering if you guys new of a solution. Thank you.
12-08-2012, 05:27 PM | #5 (permalink) |
What's the Tx-Rx set on the Belt?
Jerry Trex 700N Pro fbl, 600N Pro x 2, 450SE v1, 250 v2 fbl, Compass 6HV fbl, Blade 450x, 400, 300x, 130x, mCPx, 120SR, mQx, mSR, Rotor Concepts HPQ1, Walkera CB180Q, CB100, Novus FP, CP, Esky Hunter, Big Lama. |
12-08-2012, 06:12 PM | #6 (permalink) |
It is the standard transmitter and 4-1 receiver. I think it's a 4-1. It's the kit that comes with the Cp. the transmitter says its an Esky ET6I
12-09-2012, 05:32 AM | #7 (permalink) |
No, Belt CP had a separate Rx. Both my Belts were 72MHz so I had no binding problem. 4-in-1 was on smaller Esky helis, definitely on Honeybee FP, possibly on King, not sure here. Jack is the expert on rebinding ET6I with their respective RXs, but he's seriously ill and not visiting us here much any more .
Does anyone else remember how to do it? Hasn't Jack put this procedure in the sticky somewhere?
12-09-2012, 06:47 AM | #8 (permalink) |
O hope he gets better soon, you are right they are separate rx my apologise. Erm I'm ok with binding procedure with the hole un-bind the receiver and then take battery out then place it bk in and turn transmitter on. What should happen is a little flicker on the tx bind light in the first 3 seconds. The only thing is, this does not happen so apparently that means the tx has lost the bind code. I need to find out how to get it bk. has anyone else had this problem?
12-09-2012, 07:32 AM | #9 (permalink) |
Hopefully someone will chime in to assist, but the majority of people who frequent this forum have all gone to computer Tx systems now, and were previously on 72MHz, so there are few, if any of us, who actually ever had the 2.4Ghz systems that needed binding from eSky. Jack is one, but for the reasons Jerry explained he doesn't look in now.
I hope someone can assist, sorry that I can't. Cheers Sutty
Regards, Sutty BeltEXI, mCX, mSR, 4G3, FBL Trex250SE µB, FBL Trex450Pro µB, FBL Trex550e VX1 Pro, FBL Trex600ESP VX1e, Parkzone P51D, QRX350Pro |
12-09-2012, 09:58 AM | #10 (permalink) |
I have an ET6 on my workbench, but it belongs to a friend. I was trying to fix his honeybee CP, and tried to do the binding procedure, just to double check it was ok. I didn't get to try it enough times to be really sure I could explain it to someone, but hopefully following the steps in the manual should sort it out.
Incase you don't have a copy of the Belt CP V2 manual (2.4G version), here is a link to the e-sky website where you can download a copy. Un-bind/Re-Bind procedure is on Page 10 Hope it helps...it mentions something about pressing the keystroke button on the RX to unbind, which you didn't mention, so maybe there is something your friend didn't mention or explain properly. http://en.esky-sz.cn/download_detail...ist01-001.html Double check all your batteries are charged too. TX and Heli
COPTERBOY DX6i, mSR (SOLD), BeltCP (SOLD), mCPx w solid boom and Rakon Heli Head T-Rex450V2 w.PRO head, Scorp-8 & 45A V2 ESC, CSM4200/S9257, 3xHS65MG E-Flite CX2 - All Microheli/Extreme CNC CF Upgrades TRex600N, Kasama Head, OS50SX |
12-10-2012, 02:30 AM | #11 (permalink) |
Found Jack's sticky on Esky 4-in-1 Rx binding in coaxial section, think I remember him saying the procedure was pretty much the same for Esky 6ch Rx.
https://www.helifreak.com/showthread.php?t=201927
12-11-2012, 06:24 AM | #12 (permalink) |
Sorry I feel there is a little miss-understanding, I understand how to bind the transmitter and receiver. It's the problem with the transmitter loosing the code for binding. Apparently the transmitter can stop sending the code in the first 3 seconds of it being turned on. I need to find out if this can be reversed or whether I just tell him he needs a new transmitter. Thanks and sorry for the confusion.
