Old 06-25-2010, 07:31 AM   #461 (permalink)
Originally Posted by Altimat View Post
Just read the whole thread. What a lovefest, I gotta have one.
A few questions. V-Bar and SK-720 use with sats will never be a possibility with this radio? It has to be run with its dedicated receiver?
The 10 vs. 7 channel receiver option. Currently using an AR7000, so the smaller 7 channel RX (and lower price) appeal more to me. Is a programmable fail-safe option the only thing I'll be giving up beside the 3 extra channels? It is also LiPo compatible?
Any new full featured RXs smaller than the 10 channel pending release? If so maybe I'll hold off a bit.
Does Airtronics make a tail servo? I always liked their servos, but the servo prices are still high like they always were, unlike the surprising value the SD10G is.
There never will be Sats.
The 10 Channel RX is 2s Lipo compatible, everything else is 6 vollts.
These are coming.
Tail servos are coming as well.
TMoore is offline        Reply With Quote Quick reply to this message
Old 06-25-2010, 09:37 AM   #462 (permalink)
While some people might not consider it fast enough for a tail servo, the 94746 works great on a 50. Spec's are: 89oz-in, .08sec, digital, high resolution and it happens to be low profile. Holds the tail great with my GY520.
http://www.hobbypeople.net/gallery/474136.asp
-Farrell
Farrell is offline        Reply With Quote Quick reply to this message
Old 06-25-2010, 10:39 AM   #463 (permalink)
Default thanks Farrell
I got the plug working, I had to take the whole thing apart and resolder to the proper pins. so much for the ebay esky cable working out of the box.
Ben
skinnydoc is offline        Reply With Quote Quick reply to this message
Old 06-27-2010, 04:58 PM   #464 (permalink)
Talking Stick Stops
Thanks for the info TMoore & Patriot996.
I odered the stops from Hobby People, should have them next week.
Also thanks Bob for the videos.
bwerneth is offline        Reply With Quote Quick reply to this message
Old 06-29-2010, 07:23 AM   #465 (permalink)
Team Taco VP
Terry Moore, I have to personally thank you for getting me one of the new 6 channel 92224 RX... It's freakin awesome!
I put it in my 450Pro this weekend and I am not looking back!
PERSONAL thanks Terry from me to you....... I don't do this often and ask for stuff but I am glad I did!
Again thank you.
Bob
Old 06-29-2010, 10:20 AM   #466 (permalink)
You're welcom Bob, I hope the 450 flies well for you. That is one little RX isn't it?
Old 06-30-2010, 11:52 PM   #467 (permalink)
Where can I find details for this rx? Matt
byHISgrace is offline        Reply With Quote Quick reply to this message
Old 07-01-2010, 12:01 AM   #468 (permalink)
is it ok to use a 6.6 life unregulated with the 7 ch. receiver?
Gotcha007 is offline        Reply With Quote Quick reply to this message
Old 07-01-2010, 12:10 AM   #469 (permalink)
Do a search for 92224 on Hobbypeople.net and it will give you all the specs. You could also search on GlobalHobby.com. Either one should work.
Patriot996 is offline        Reply With Quote Quick reply to this message
Old 07-01-2010, 06:58 AM   #470 (permalink)
Which one?
Old 07-01-2010, 12:24 PM   #471 (permalink)
Originally Posted by TMoore View Post
Which one?
This one
Old 07-01-2010, 01:17 PM   #472 (permalink)
anybody? i've got my radio and ready to install but not sure about this one thing...
Old 07-01-2010, 01:59 PM   #473 (permalink)
Yes, you can use a two-cell LiFe pack. Mike Greenshields is the Airtronics product manager, here is a quote from him:
Remember that 6.0V is the Nominal voltage range. What this means, essentially, is that the receiver is designed to work optimally with a 4-5 cell battery pack (nicd or nimh type cells). The operational voltage range is much larger (consider that a 5 cell nimh comes off the charge at 7 volts typically.)
So, yes, an A123 or Li-Fe 2 cell pack will work.
What we do NOT recommend is a 2 cell LI-PO pack because it comes off the charger at 8.4V and in an application like this will continue to operate at 8.4 volts for an extended period of time. The receiver is NOT designed for this much voltage.
_________________
Mike Greenshields
Product Manager
Global Hobby Distributors
mikegoesflying.wordpress.com
http://globalservices.globalhobby.co...ic.php?t=24385
That post happens to be on a thread about a car receiver but it applies to aircraft receivers as well. There are lots of posts about this on the Global forums, for more info just search over there for "life"
-Farrell
Old 07-01-2010, 02:58 PM   #474 (permalink)
thanks farrell !!!!
Old 07-16-2010, 11:03 AM   #475 (permalink)
-Farrell
It can work direct with 2s lipo:
April 2010 Announcement:
Sanwa Engineers Approve 92104 10CH Receiver's 2S Li-Po Rating
Details: After months of testing and re-testing, Sanwa Engineers have given the OK for the 92104 10CH Receiver to be used with a 2S Li-PO direct.
Originally the receiver was only rated for the 4.8v to 6.6v nominal voltage range (4 cell Ni-MH to 2s Li-FE/A123 cells). However, after testing the receiver in a variety of environments, we're happy to announce that this receiver maintains it's stability even at higher voltage input. 2S Li-PO input voltage does not void the warranty and will not reduce the life, performance, range, or stability of this receiver.
This is a modification of the original voltage range ratings. The receiver was originally designed to be stable in a wide range of voltages. However, Sanwa engineers were originally concerned that this higher voltage range could cause instability of the 2.4GHz section or premature failure of the receiver. The 92104 Receiver is now proven to maintain its performance with 2S Li-PO input.
Please note that many new servos including some Airtronics servos are now designed for 7.4V. These include the new 94910 and 94911 HVS Digital Servos. Please consult your servo manufacturer's specifications before using 2 cell Li-PO packs.
choopi is offline        Reply With Quote Quick reply to this message
Old 08-10-2010, 03:52 AM   #476 (permalink)
Anyone tried which 2s Lipo is fitting into the tx?
Motormike is offline        Reply With Quote Quick reply to this message
Old 08-10-2010, 03:57 AM   #477 (permalink)
I've got a ThunderPower 2050mah in there no problem. 2100mah is the size you're looking for.
nwmtech is offline        Reply With Quote Quick reply to this message
Old 08-12-2010, 07:45 AM   #478 (permalink)
Thank you, i found this one, fitting into the Sd-10 http://www.lrp.cc/de/produkte/vtec-a...y-74v/details/
Old 08-12-2010, 11:41 AM   #479 (permalink)
Nice catch. Glad that one fit. I'll have to do a little more searching for a bigger one here in the states that will fit.
Old 09-13-2010, 10:51 AM   #480 (permalink)
Default FBL Sistems
Hello, my friends, someone to try the Airtronics SD-10G Transmitter with FBL sistems (V Stabi, Aling 3g,)? whats is your felling? i like the transmitter, but i am thinking if good with fbl sistems is easy configuration!. greetings from Venezuela!!.
PD: Sorry for my english:o
* Trex 450 Pro (Stock)+ lainding gear gorilla
* Blade mSR (Fun)
*Outrage V50 (Waiting)
Masterjesb is offline        Reply With Quote Quick reply to this message
