Old 05-31-2015, 07:28 PM   #1 (permalink)
Default Which 6s motor?
Should I go with the Scorpion 6s motor or the Xnova 6s motor? I have heard that Xnova motors don't like low rpm and I like having my 2500 rpm and 3100 rpm so I'm considering the Scorpion but if the smaller Xnova can handle it I will go that route.
Team Lynx Heli Field Rep
XL Protos 380
Jomaba4308 is offline        Reply With Quote Quick reply to this message
Old 06-01-2015, 05:26 AM   #2 (permalink)
I've never heard about Xnova not liking lower rpm.
If you are comparing the Xnova 2618 to the Scorpion 2520 they are very similar, nearly the same size, approx same power output, same weight, etc.
The motor has far less load on it at 2500 rpm than at usual headspeeds so any motor will work fine at that rpm really.
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 06-01-2015, 06:36 AM   #3 (permalink)
Is there even a reason to upgrade. The stock motor does 2500 and 3100rpm fine. I find there isn't a need for more power but I run mine with 325s.
Alex
Fleet: Miniprotos
Flock: cockatiel and congo african grey
dedados is offline        Reply With Quote Quick reply to this message
Old 06-01-2015, 06:59 AM   #4 (permalink)
I have full stretch with
Halo 360/62 blades and bogs bad with my Pulse 65c and sill bogs with my Nano-Tech 65c but not as bad. And that's on vbar gov with precomp.
XL Protos 380
Old 06-01-2015, 08:55 AM   #5 (permalink)
Well if you want something unboggable then either the scorp 2520 or the Xnova 2618 will work fine.
The 2520 is unboggable even running 3500 headspeed and my collective management isn't good.
It comes at the cost of flight time though, I can't really get over 3min flight time with my current setup.
Old 06-01-2015, 09:43 PM   #6 (permalink)
The Scorp/Xnova are night and day compared to the stock motors, especially when running 350's or bigger. Any motor will run any rpm just fine at 10-11 degrees collective. I run my 353's at 13.5 degrees at 3250rpm on my 2520 and get 3:30 flight time on 1300mah 70C TP packs - they come down at 3.75v/cell or so. Unbogable no matter what I throw at it and i've tried my best to bog it.
The Xnova is supposed to be slightly more powerful, but at the expense of having to modify the frame a bit. I just wanted to drop it in so I went Scorpion and it has been excellent. I swapped in BOCA Abec7 bearings to keep from having to oil it all the time and the thing comes down very cool on 6S. I hit it with an infrared gun right after I land and the highest i've seen is 126 degrees on an 85 degree humid day.
OXY5 MEG / 12S
RAW KSE / 14S
TDSF / 6S
OXY rep
DCflyer is offline        Reply With Quote Quick reply to this message
Old 06-07-2015, 03:19 PM   #7 (permalink)
i went with xnova ... plenty of power for anything
here all the pictures
https://www.dropbox.com/sh/pbo8r1s8x...ATrTC1KZa?dl=0
here one of today flights
my Prôtos twins & Acrobat Shark
urgno is offline        Reply With Quote Quick reply to this message
