Like Tree5Likes
Old 04-30-2011, 03:08 PM   #121 (permalink)
Default Now with added beast.....
Really liked how it turned out, Setup took a while, but just done my 250 in about a quarter of the time. Flies really nice.
Just noticed i need to change my avatar!!,
PS just sold my old head and 401 on ebay it almost covered the cost of the beast, if your gona get FBL go quick while the market still gives a good price for gyros before it gets flooded FBL is the future......
ID:	225114   Click image for larger version
ID:	225115   Click image for larger version
ID:	225116   Click image for larger version
So out of date i deleted it......
ipjodan is offline        Reply With Quote Quick reply to this message
Old 05-01-2011, 07:18 PM   #122 (permalink)
Blade 130X
Blade mCP X (Bl)
Blade Nano CP X
Prôtos 700
Xtreme-Production
SYMAWD is offline        Reply With Quote Quick reply to this message
Old 05-01-2011, 07:35 PM   #123 (permalink)
Looks real good. First glance I thought where's all his wiring. Very neat job tucking it all away.
My Favorite: TREX 250SE FBL w/SK-720/DS410M/DS95i, JR 11X
Fun to Fly: TREX 450 Sport FBL w/SK-720
Retired/Sold: Blade mCX2, mSR, 120 SR, mCP X
BigART71 is offline        Reply With Quote Quick reply to this message
Old 05-02-2011, 06:13 PM   #124 (permalink)
Had my maiden voyage yesterday, had a couple very short flights but they went very well. Figured I would share my wiring and say thanks to all on here, don't think it would have went so well if not for all the info on this forum. May make a couple changes to the wiring once I get my 250 built.
Much appreciated
Frank
fchaulk is offline        Reply With Quote Quick reply to this message
Old 05-09-2011, 12:14 AM   #125 (permalink)
Here is my 450 with 3g and telemetry.
AMA#940242
Grumpy1 is offline        Reply With Quote Quick reply to this message
Old 05-09-2011, 12:22 AM   #126 (permalink)
Just Finished re~wire'n my 450
ID:	226794   Click image for larger version
ID:	226795   Click image for larger version
ID:	226796   Click image for larger version
ID:	226797   Click image for larger version
ID:	226799   Click image for larger version
ID:	226800   Click image for larger version
ID:	226801   Click image for larger version
ID:	226802   Click image for larger version
it's not a competition, it's a hobby
EXI 450 + FUTABA t7c Tx =
Phoenix Sim "it's free to crash on a sim"
kevinbattista is offline        Reply With Quote Quick reply to this message
Old 05-09-2011, 04:49 PM   #127 (permalink)
Nice work! Do you find that the gyro/rx strap accidentally pushes the gyro's Set button? Also, what did you use to hold the rx under the shelf? Velcro? Finally, I re: running the front cycle servo wires on the inside, did that make you nervous having them close to the shaft and gears? Does it make changing out servos harder? Thanks for sharing!
matthewcornell is offline        Reply With Quote Quick reply to this message
Old 05-09-2011, 06:06 PM   #128 (permalink)
Hey Matthew, I supposin your talkin about my bird. I used double side servo tape to glue the rx and 3g controller down, was using align velcro straps but changed to zip ties to secure them better. All wires are protected from rubbing (see pics) Yes harnessing wires makes changing servos a PIA. My 3g sensor works better without a strap.
AMA#940242
Old 05-10-2011, 09:33 AM   #129 (permalink)
Originally Posted by DewFuss View Post
Be kind.... it's my first build.
Thanks very much for the pics. Re: ESC placement, on my Sport, putting it like you did would make the capacitors *very* close to the bottom of the motor - within ~1mm! Are you concerned?
Old 05-10-2011, 12:38 PM   #130 (permalink)
When I was using the se v2 frame it was a very tight fit, but if you secure it down with sticky back velcro or servo tape and then strap it down it will not move. I would not mount it with caps within 1mm motor thou! My frame was modified with microheli 450 Pro lower frame to allow more room for components. The main reason I did it this way is the ballance of the heli and I dont like components outside of frame. As you can see the V2 Scorp commander 55 is is a monster and fills the se v2 frame. Ithink I had like 5 or 6mm clearance between motor and esc caps with the stock frame.
(note) Mounting the gyro so close to esc is not recomended by align but I have not had any problems from doing so.... Might be because CF tray blocks RF???
AMA#940242
Old 05-10-2011, 12:52 PM   #131 (permalink)
*is it bad to do this? and why? what problems does it cause ?
I havent had any problems yet but only got a few flights in with it since set up (mostly hovering )
Old 05-10-2011, 01:42 PM   #132 (permalink)
If the outside of motor can spins you could possibly hit the caps against the motor and destroy your esc in a crash. Push up on the esc see if it hits. IMO
AMA#940242
Old 05-10-2011, 01:54 PM   #133 (permalink)
Be careful the motor doesn't dig into those capacitors. My friend had that happen, it was a on a 500, but still.
Lincoln
#HIGHONHELIS ):>
Pull Hard
RCHO Flying Field, Knightdale NC
lazor 22 is offline        Reply With Quote Quick reply to this message
Old 05-11-2011, 12:27 AM   #134 (permalink)
so the "rub factor" is the only reason for concern ? cool, my motor spins internaly
just making sure it's not a "feed back" issue .
thanx
Old 05-11-2011, 04:02 PM   #135 (permalink)
I attempted running wiring inside the frames, but ape-sized paws, 50+ year old vision, and limited patience all added up to insurmountable frustration... I figure external wiring runs will be easier for inspection and maintenance anyways
Tony
MSH Protos, Gaui X3, Shendrones Tweaker 180, T-Rex 450 Sport, X-Cell 60 Custom, Kavan Jet Ranger...
prillernut is offline        Reply With Quote Quick reply to this message
Old 05-11-2011, 04:52 PM   #136 (permalink)
Man,that is one neat wiring job,soft landings Bro. Tom
tommcg46 is offline        Reply With Quote Quick reply to this message
Old 05-18-2011, 04:05 AM   #137 (permalink)
Here is my PRO, you can't see wire outside.
ID:	228430   Click image for larger version
THANK YOU ALL DRONE OP
RC IS NOT MY BUSINESS FROM NOW ON
Hawk208 is offline        Reply With Quote Quick reply to this message
Old 05-18-2011, 07:19 AM   #138 (permalink)
Nice work! I'm 49 in Oct, and I totally understand working with "maturing" vision. Here's to trying something new and challenging.
Old 05-18-2011, 07:47 AM   #139 (permalink)
Default newbie wiring for first time T-Rex 450 Sport build
Hi Guys. Attached are annotated pics of my first ever build. I've only been flying for ~2 months. Building was very satisfying. I literally know every single part in the bird, which is paying off on my first crash yesterday. I was surprised that deciding electronics placement and wiring was one of the hardest things to decide. I did a lot of research here on HF and came up with this solution. I was a bit amazed that Align didn't specify these in detail. Part of the art of the craft, it seems. All in all, I'm happy with the choices and work I did.
ID:	228446   Click image for larger version
ID:	228447   Click image for larger version
ID:	228448   Click image for larger version
Old 05-18-2011, 10:33 AM   #140 (permalink)
I'm starting to see a lot more thought being put in to component placement and wiring.
NICE WORK YOU GUYS!
You can get away with a lot with todays electronics but it's nice to see and it may help you avoid annoying costly glitches!
For you guys with Futaba Receivers with the long antenna's, I'm a little concerned about running them parallel to CF. If you have no issues then don't worry about it. If you do, consider moving them a bit away from the CF and try not to be right parallel to it.
Rick
Helifreak, the place to be!
rdlohr is offline        Reply With Quote Quick reply to this message
