Jeti Duplex Radio Systems Jeti Duplex Radio Systems Support |
04-24-2014, 01:35 PM | #1 (permalink) |
V-Bar governor autorotation bailout + Mezon
I'm using a V-Bar plus Jeti Mezon ESCs on my helicopters. I have enabled the autorotation bailout on the V-Bars.
I'm a bit in doubt whether I should also enable autorotation on the Mezon. The V-Bar bailout kinda works with Mezon bailout disabled; spoolup is faster than without, but it's still a bit slow to my taste. I suspect that the Mezon still spools up slowly, even if the V-Bar tries to spool up faster. However, I'm not convinced that I should enable the Mezon bailout. The Mezon requires a bailout throttle hold signal slightly above 0%, but the V-Bar obviously doesn't know anything about this. Perhaps I should enable Mezon bailout and re-adjust the throttle range from the V-Bar so that the minimum value matches the Mezon "bailout" throttle value. On the other hand, then I don't know if the Mezon will arm as it will never see it's true 0 value. Any thoughts...? |
04-25-2014, 02:48 AM | #2 (permalink) |
Re: V-Bar governor autorotation bailout + Mezon
Buildin mezon bailout can not work with vbar because you can never get the required % thr output to trigger it.
On my X7 mezon bailout is fine, a flying buddy also uses the mezon and bailout works fine on his machine also. Did you set acceleration to 9s? Also do you have idle on bailout on?
-TT E700 V2-vbar-mks950-980-Kosmik 160HV-Pyro 700 rewound by PD / Voodoo 600 -PD-MX700-470kv--BLS255hv-VBAR 5.3+- Gaui X3+Spirit Pro |
04-25-2014, 05:52 AM | #3 (permalink) | |
The combination Mezon and Vbar gov is very reliable and the bailout is very consistent, (as apposed to the YGE 160Hv where the spool-up time was quite variable). In this vid you can see the Bailout at work:
Raptor E700: PowerDekker Pyro650, JR DS8925HV & SPG01, 12s, Vortex VX1, Kosmik160, Jeti DS-16 |
04-25-2014, 01:44 PM | #4 (permalink) | |
Sv: V-Bar governor autorotation bailout + Mezon
Idle on bailout is off. That's cheating If I enable it, spoolup is super quick. Mine is a bit slower than that. It's faster than initial spoolup, but still a bit slow. Sent fra min GT-I9505 via Tapatalk |
04-25-2014, 05:17 PM | #5 (permalink) |
I checked now. My acceleration is 3.1s. Given that the V-Bar takes care of the initial soft spoolup, perhaps I should decrease this?
04-26-2014, 04:43 AM | #6 (permalink) |
The idle is the problem. It's not cheating. It's very hard on the esc to have it off.
