Old 02-23-2014, 03:20 AM   #1 (permalink)
Default Lynx tail pitch lever issue
I went to install my black Lynx tail pitch lever today. It fit in the tail case fine but could not get the tail pitch slider to work with it. I noticed the two forks on the lever are not the same distance away from the tail shaft. Of course this means a major binding issue. I have always had very good luck with Lynx parts and find this strange. Has anyone else had this issue?
LOGO 200, DIABOLO 550, DIABOLO 800, SOXOS 7.1
VCONTROL*NEO*TRIBUNUS*MKS*VTX*DPL8 W/BUMP CONTROL*MEANWELL
Corvette & Copter Guy is online now        Reply With Quote Quick reply to this message
Old 02-23-2014, 05:53 AM   #2 (permalink)
I haven't had this issue with mine but some others have : https://www.helifreak.com/showthread...=579148&page=6
"Beater" Mini Prôtos stretch 6S : Scorpion 2520-1360kv, Edge 353SE
"Princess" Goblin 570 stretch 12S : Xnova 4025-560kv, Cyclone 615
FrSky Taranis - Heli-X 5 - MKS, YGE, SK540 - Yamaha XJ6F
Aryemis is offline        Reply With Quote Quick reply to this message
Old 02-23-2014, 12:39 PM   #3 (permalink)
I had this problem. Lynx put it down to the plastic tail case being warped. Strange that both stock parts included with the kit fitted fine. Lynx took it as a marketing opportunity to say I should wait for the lynx metal tail case. Anyway I bent the lynx part to fit and it is a good improvement as the stock part can bend under load.
pgleesonuk is offline        Reply With Quote Quick reply to this message
Old 02-23-2014, 12:55 PM   #4 (permalink)
Not sure I can bend mine. Its the bottom fork that is out of wack. If it was the top bending would not be an issue.
Old 02-24-2014, 05:07 PM   #5 (permalink)
you can do it...I did it to mine also. I used two adjustable wrenches, closed one up on the upper arm sticking straight out, then did the same to the bottom arm. Then gently give it a twist in the direction they need to go. Just a really little bit at first, it probably wouldn't take too much to go too far.
waygone is offline        Reply With Quote Quick reply to this message
