Old 03-05-2014, 01:31 PM   #1 (permalink)
Default lights flasing on 3gx after hover test
HI all,
I went out today to get a few hover tests in on my new 700e dfc pro.
was great hoverd perfect moves perfect slight tail wag on hard pump no big i will adjust gain..
my real issue is after i landed ,flying with out canopy on,i noticed the 5 lights under stat light and gov light are all flashing- that stat light and gov light are not flashing but the 5 under them are. i tryed to look this up to see what this means and cant find anything....HELP
kronik is offline        Reply With Quote Quick reply to this message
Old 03-07-2014, 11:08 AM   #2 (permalink)
Default Found the issue
Ok this may sound stupid and it kinda was on my part,
Guys don't put any dir or expo in your transmitter,
as a matter of fact don't change anything input wise in the transmitter after setup.The 3gx will see this as an input and compensate for it,you will know this is happening if the 5 lights below the stat and gov lights start flashing.
lesson learned. i thank god it was not an expensive lesson....no crash
Old 03-13-2014, 11:55 PM   #3 (permalink)
I put D/R and Expo in my Tx after set-up, but no flashing at all on 3gx.
enerko is offline        Reply With Quote Quick reply to this message
Old 03-14-2014, 04:14 AM   #4 (permalink)
I would suggest it may actually be a power issue to the 3gx. Are you running a bec or a 2s lipo?
Bonkievan is offline        Reply With Quote Quick reply to this message
Old 04-02-2014, 09:51 PM   #5 (permalink)
Same here, the 3gx doesn't offer bank switching so I use d/r on my iu1 setting and expo on iu2 never had any issues. I agree with the post above about the power interruption.
Goblin 630 Comp / Spartan VX1 N Fbl
Goblin 700 Comp / Spartan VX1 N Fbl
TRex 550 DFC Pro stock w/Spartan VX1 N Fbl
TRex 450l Dominator stock w/Spartan VX1 E Fbl
SRJay is offline        Reply With Quote Quick reply to this message
Old 04-10-2014, 02:10 AM   #6 (permalink)
All 5 lights flashing = loss of signal
Made some fail-safe and rx/servo power tests yesterday. I got all 5 lights flashing when I turned off my tx and then turned it back on. Measure your voltage drop under load, remove main gear, attach a voltmeter and give fast cyclic input, see what it does.
Align T-Rex 600EFL Pro DFC, 3GX v4.0, TM1000; Align T-Rex 600N Pro DFC, 3GX v5.0; DX9
Riff is offline        Reply With Quote Quick reply to this message
Old 04-11-2014, 06:46 AM   #7 (permalink)
[QUOTE=Riff;5771304]All 5 lights flashing = loss of signal
[QUOTE]
+1 You likely had a power dip. It may not have been enough to cause you to loose signal at the Sats.
I would also check the cables to the Sats just to make sure there isn't a break in the wires.
Thunder Tiger X50 TT FBL (OS 50 SX Hyper | Align 3GX Gyro\Gov | Align DS610 x 4 | Align DS650 x 1 | 2 Spektrum Sats)
Align Trex 450Pro V2 (HS5065MG x3 | DS520 x 1| Castle ICE 50 | MiniV 5.3 Pro)
Align Trex 150 DFC (Lynx Metal Swash | Spektrum Sat)
Taxus812 is offline        Reply With Quote Quick reply to this message
