Like Tree1Likes
Old 12-26-2006, 02:45 PM   #161 (permalink)
Team Taco VP
The link to the swash for elevator should be the same length as the other servos! All the geometery is the same. If these 3 links arent the same then go back amd make sure all the servo arms are 90 and the bell cracks are all level.
Bob
Old 12-26-2006, 03:10 PM   #162 (permalink)
Thanks for the quick reply. I did make it the same but was not sure. Now I have to pick out the right servos next. I did pick up a GY401. Once I finish the 600 build and trimmed it out I want to make it into a electric "Airwolf" if I can, something slow and stable.. NON 3D :wink:
Crash-N-Burn is offline        Reply With Quote Quick reply to this message
Old 12-29-2006, 04:09 AM   #163 (permalink)
Finless, My wife got me a 600cf for christmass and being the first choper I have ever built it has been interesting to say the least. I came across your video today and they have been great I am using a Spektrum DX7 with DS821 servos and a GY401. On the Elevator servor do the arms need to be parallel with the side of the frame as well as being 90% to the servo horn?
ozA600cf is offline        Reply With Quote Quick reply to this message
Old 12-29-2006, 04:16 AM   #164 (permalink)
Team Taco VP
Of course! All servos need to be 90 and then all bell cranks need to be 90 and LEVEL to the swash. If you did this right, the 3 links to the swash should all be the same length and the swash should look perfectly level... 1 turn believe it or not is about 2mm and noticable!
Bob
Old 12-29-2006, 04:36 AM   #165 (permalink)
Thanks for the quick reply. Understand in regards to swash plate what I am concerened with is the linkage arms between the elevevator lever and the sevor are not parallel with the side frame to get them parallel i either have to move the elevevator lever closer to the side or put a spacer on the lingage arm to move the ball out further?
Old 12-29-2006, 04:49 AM   #166 (permalink)
Team Taco VP
OK understand... THEY SHOULD BE PARALLEL! Dont forget to see the manual and my video which REQUIRES you to trim 2mm from the links from the servo to the elevator bell crank to allow them to fit!
Bob
Old 12-29-2006, 04:58 AM   #167 (permalink)
Thanks Mate back to the table and on with the build
Old 12-29-2006, 05:04 AM   #168 (permalink)
Team Taco VP
Fair Dinkum!
Bob
Old 12-29-2006, 05:05 AM   #169 (permalink)
As we say here in OZ "what the bloody hell are you doing up at 6.04am"?
Old 12-29-2006, 05:26 AM   #170 (permalink)
Team Taco VP
You didnt do your time calc's right! it is 3:20 AM right now
What am I doing up.... WORKING!
Bob
Old 12-29-2006, 07:08 PM   #171 (permalink)
Bob, I think you dont have your time zone set correctly in your profile. Your post time says 7:26 and you say it's 3:20. Just a thought.
skid is offline        Reply With Quote Quick reply to this message
Old 12-29-2006, 07:35 PM   #172 (permalink)
No, his post time get adjusted to your time zone. For instance, it tells me Bob posted at 6:26 AM.
Helifreak, the place to be!
rdlohr is online now        Reply With Quote Quick reply to this message
Old 12-29-2006, 10:17 PM   #173 (permalink)
OOPS .... I get it now
Old 12-29-2006, 10:37 PM   #174 (permalink)
On step one where you put the bearing and such in the grips, the grips are bowed in so they won't easily slip in. You got any good tricks for spreading the grips?
Old 12-30-2006, 05:10 AM   #175 (permalink)
Need help I am having trouble setting up the rudder. I am using Spectrum DX7 with input select on Gear / Gear the Gyro is a GY401 with a 9254 servo. I have watched Bob excellent video and understand the process. What is happening when I turn the BEC on and the stick is in center the rudder is not centered is it will not go back to center even I move the stick and see it is centered. Also it makes a constant sound I can not tell if it is the servo or the gyro. Any help would be great.
Old 01-02-2007, 08:14 AM   #176 (permalink)
Default Re: Trex 600 Build Videos will be here:
Hello
I am getting the .wvm error when I try to play any video.
What is up?
Tom
Originally Posted by Finless
The Trewx 600 Build videos will be listed here.
Check out the announcement video here:
Trex 600 announcement video
First up:
Kit Contents Overview
What's in the box!! (18 Megs)
VIDEO -> Steps 1 and 2 - Blade grips and head (18 Megs)
VIDEO -> Step 3 - Seesaw and flybar (50 Megs)
VIDEO -> Steps 4, 5 & 6 - Head, washout, and swash plate (20 Megs)
VIDEO -> Steps 7 & 8 - Main gear and frames (25 Megs)
VIDEO -> Step 9 - Tail Drive Assembly (10 Megs)
VIDEO -> Steps 10 & 11 - Trays, Motor mount, and Control arms (20 Megs)
VIDEO -> Steps 12 - Landing Gear (9 Megs)
OK folks. At this point for ease of video purposes I am skipping steps 13 through 16 (tail and tail rotor) and going to 17 servo install and head set up. I will return to these steps near the end.
VIDEO -> Servo Install and linkage setup (44 Megs)
VIDEO -> Head and link setup (30 Megs)
VIDEO -> Installing the motor and setting the pinion (15 Megs)
VIDEO -> Installing the electronics (38 Megs)
OK I will now be going back to page 13 and doing the tail of the heli and this will include setting up the servo.
VIDEO -> Tail boom, tail case, and tail shaft (30 Megs)
VIDEO -> Tail pitch slider and tail hub (22 Megs)
VIDEO -> Boom supports and fins (22 Megs)
VIDEO -> Tail servo and gyro setup (35 Megs)
OK basically that is it! I hope you all enjoy the build vids and please feel free to give feedback!
The below vid is just some final comments nothing big. I moved the ESC to the other side of the heli due to the antenna routing as I did this build without the skids on and after placing the skids I realized it was not good to have the ESC close to the antenna.
VIDEO -> Final comments (6 Megs)
VIDEO -> How to mount the flight power 4900 to the Trex600 (19 Megs)
Well I hope you all enjoyed this as much as I did doing the vids!
Enjoy,
Bob
tomison is offline        Reply With Quote Quick reply to this message
Old 01-02-2007, 08:52 AM   #177 (permalink)
Try updating your windows media player to version 11 may help
Old 01-02-2007, 11:59 AM   #178 (permalink)
I don't know about the DX7, because I don't have one, but it sounds as if your gyro is in HH mode. It will only centre on the bench if it is in normal mode. The gyro channel must be assigned to a switch on the tx to flip from normal to heading hold mode.
Maybe someone with a DX can help you out here......
The constant whining sound is normal for a digital servo, don't worry about it.
Jeroen -
Just fly it!
BarnOwl is offline        Reply With Quote Quick reply to this message
Old 01-02-2007, 05:51 PM   #179 (permalink)
Bob, I just built my 600 with your videos as a guide. What a pleasure! Thanks for the great asset to our hobby.
jgunpilot is offline        Reply With Quote Quick reply to this message
Old 01-02-2007, 10:09 PM   #180 (permalink)
Hello,
I have windos XP multimedia center and for some reason I get a WVM or WMV error each time I try to play a video on your sight. I have never had a video not play before . It does seem to think a Codac is missing where can I get it ?
Tom
