Go Back   HeliFreak > R/C Helicopters > RC Helicopter Flight School
RC Helicopter Flight School Instructional Flying Tips, Tricks, Videos, and Q&A
Old 01-11-2014, 07:12 AM   #1 (permalink)
Default tic tok with a 450
I've watched lots of instructional videos about tik toks and understand how to do them but it doesn't work for me in practice, when I do them I give full cyclic and about half of my collective and they stay in one place, however I feel that as they go on I need more collective, also when I watch the pro's they seem to pivot around the tail whereas mine pivot around the head and the tail moves quite a lot, almost like mini rainbows.
is it different with a 450 than something bigger or any ideas on what i'm doing wrong
thanks
Anthony
Anthony
raw 500, xl power nimbus 550,Tron 5.8 heritage, Tron Dnamic, cgy760-r, futaba
anthony1 is online now        Reply With Quote Quick reply to this message
Old 01-11-2014, 07:20 AM   #2 (permalink)
tick tocks = less collective ( just enough to stop the heli at each movement and keep it suspended ) + more cyclic input to rock it back and forth pivoting it on the tail
rainbows = more collective less cyclic input
hope this helps
Kap'n Krunch is offline        Reply With Quote Quick reply to this message
Old 01-12-2014, 07:50 PM   #3 (permalink)
I think you should ease on the cyclics a little more.
Also, i find tictocs harder on small size helicopters. As the rotor disc size increases, tic tocs become more controllable, easy and fun
Nightsinger is offline        Reply With Quote Quick reply to this message
Old 01-13-2014, 02:49 PM   #4 (permalink)
that's the thing, i'm using full cyclic and about 1/2 to 3/4 collective, I do find them easier with my x4II and when I had the furion 6 they were easy, it just feels like i'm using too much stick movement to get them how I want them.
Anthony
Old 01-13-2014, 04:23 PM   #5 (permalink)
Maybe you need to up the headspeed a bit or change the agility or style in your FBL system if it is a FBL helicopter. 450's do not have as much lift as bigger helicopters, so it will not be as easy. However, it should be possible to do tic tocs, if you have a motor that is strong enough and more important, good lipo's.
Just try to do them slow at first, almost flattening the disc all the way. Focus on doing cyclic and only catching with collective. When you can keep it in the air that way you start working to smaller angles and faster tic tocs.
Good luck!
blade450 is offline        Reply With Quote Quick reply to this message
Old 01-13-2014, 06:36 PM   #6 (permalink)
Tic tocs need loads of collective from my experience...I kind of don't understand when people say use mostly cyclic and only a little collective as I've never been able to do tic tocs with just a little collective and I've had a very overpowered 450 and 550...maybe people have insanely quick cyclic...not sure but I run quite quick cyclic agility...
My old 6S 450X was insane at tic tocs as it had so much pop off centre...so I used about equal cyclic/collective. I can do tic tocs well and can hold them quite still doing diamonds and even the lower half of a big ben.
The 450 was the most agile tic toc machine out of any heli I've personally seen fly...not the most accurate by any means though.
12S 4035-500 Gaui X5 Formula VBar, 6S 2520-1880 Gaui X3 AR7200BX, Phantom 3 Professional
FailureToFly is offline        Reply With Quote Quick reply to this message
Old 01-24-2014, 02:01 AM   #7 (permalink)
To the last poster. I have been working on this in the sim, and when I first tried to learn them I did like you said, loads of collective and very little cyclic to get them to look right. Then as I started doing them more, I discovered that using more cyclic seemed to give a bit of lift.
If you use a lot of collective on a real life heli, you tend to blow the tail out, even when have a great tail.
Old 01-24-2014, 05:32 PM   #8 (permalink)
I try to do tail down tic tocs so the heli pivots from the tail case. Many people doing hard cyclic tic tocs pivot the heli mid way up which is what lots of cyclic does (it wants to flip the heli at the mainshaft). Neither are the 'right' way to do tic tocs but I like the bottom pivot point myself rather than mid way up. IMHO pivoting from the base looks better (less jerky).
I use about equal cyclic/collective IMHO. On a overpowered 700 little collective/lots of cyclic might work great but all my helis have been decently powerful thus far (zero bogging issues to date)...I'll know pretty soon anyway (700 is incoming).
Never have I blown out the tail in tail down or tail up tic tocs. Aileron (tail rotor down) definitely once you get aggressive.
Old 01-25-2014, 09:22 AM   #9 (permalink)
so I tried using around the same amount of collective and cyclic and they look a lot nicer. pivoting around the tail which I also think looks nicer, my heli's aren't over powered and the tik toks are slow but now they look like I want them to, thank you
Anthony
Anthony
