700 Class Electric Helicopters 700 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
12-27-2010, 10:59 PM | #141 (permalink) |
Make sure those cycles on the batteries are similar when running them in parallel or in series. Something to do with damaging the lipos
ALIGN TREX 250SE 450SE V2 500ESP 550E 600ESP 700E NOVUS CP BLADE MSR BLADE SR 120 BLADE SR |
12-29-2010, 02:57 AM | #142 (permalink) |
rctazz, only thing is, you will end up taking off all those other flybars pretty quick. You'll see
...Once upon a time there were Nitros, flybars & frequency pins...Shawn |
12-29-2010, 12:01 PM | #143 (permalink) |
Finally it's done
Some pics of my 700E.
/Mats Voltage indicator for the RX pack |
01-02-2011, 11:10 PM | #144 (permalink) |
Here's my first ever align heli bigger than a 450.
Latest 700e kit with : -kde thrusted bearing blocks -kde elevator bellcrank -kde reciever mount -kde motor mount -third mainshaft bearing block mod -quick uk hub and grips -quick uk magnetic canopy mounts -align carbon tail pushrod -align's newest headblock with the integrated swash driver mount -align alloy elevator servo mount -115mm edge tails -690mm sab fbl wide chord blades -pyro 700-45 with a 14 tooth -jive 80hv -8717's on cyclic -mks ds760 on the tail -v-bar 4.925 kg ready to fly with 12s 40c 4000mah, a full kg heavier than my logo 600se with the exact same components ! I built this 700e to use for short duration, pop and lock style smack though, something the 600se isn't as good at with it's lower headspeeds. |
01-02-2011, 11:12 PM | #145 (permalink) |
Color co ordinated or what? !!! Wow looks great Nathan!!
01-03-2011, 04:31 PM | #146 (permalink) |
Very nice!
Question about the Align head. I purchased one and on mine they only threaded the outside where the swash driver arms bolt to. That doesn't seem right to me, as there are slots cut in the bottom or the head which looks like that was meant to clamp down on the mainshaft when the bolts are tightened. Is yours that way?
Just another crappy day in Paradise.... Aloha! |
01-03-2011, 06:12 PM | #147 (permalink) |
Mine was that way too.
One would presume they would have intended those swash driver bolts to act as pinch bolts. Looks like a fail to me. It still is just as tight as the older head assembly, but they missed the mark they were aiming for, clearly. I'll probably throw the kde one on there instead. |
01-04-2011, 12:54 PM | #148 (permalink) | |
Either they did this on purpose, which doesn't make a whole lot of sense, or they screwed the pooch. I went ahead and ran a tap through and threaded the other side and then drilled out the original threads. With longer bolts, it now clams like I think it was designed to do. There's plenty of thread as long as I don't go gorilla on the bolts. They only need to be snug anyway.
01-04-2011, 04:06 PM | #149 (permalink) |
Can someone post a picture of what you guys are talking about?
Jim Trex 250 ---- Trex 450 Pro ---- Trex550 FBL ---- Trex 700E FBL ---- Avant Aurora 90E ---- Goblin 700 Keep it off the Ground....but just barely
01-06-2011, 04:57 AM | #150 (permalink) | |
01-07-2011, 06:17 PM | #151 (permalink) |
beautiful color scheme!!!!!!!
oh btw your cyclic servo links on the servo horns are incorrect. They should be 21mm apart and that ends up skewing the link rods towards each other not parallel like yours.
GOBLIN 700 SPEED-KOSMIK200-700XF-NEO-BK CYCLIC AND TAIL TREX 700E-NEU KDE 1917-12 PINION-NEO -JR 8717 HV CYCLIC-MKS990 TAIL-ICE 160-KDE UNIVERSAL MOUNT W/PINION SUPPORT |
01-07-2011, 06:54 PM | #152 (permalink) |
Thanks !
Those are quick uk's fbl specific wheels. 24.4 is recommended for fbl with the 700e, those are 24.4mm . The bellcrank end is roughly 29mm apart, so they're not really paralell. |
01-08-2011, 10:29 PM | #153 (permalink) |
Welcomed a new addition to the family today and also my first 700. Thanks united737pilot!
01-12-2011, 01:41 PM | #154 (permalink) |
700E (red)
Stock 700E
Sab blade main and tail |
01-12-2011, 09:55 PM | #155 (permalink) | |
nice thank for the heads up
01-16-2011, 10:27 AM | #156 (permalink) |
My Fleet
My fleet of helis in the past year.
01-27-2011, 01:41 PM | #158 (permalink) |
trex 700e
my trex 700e castl 160hv
01-28-2011, 09:10 AM | #159 (permalink) |
Whats that flybar looking thing doin on your 700?...
1NV3RT3D YOUTUBE HelloHeli |
02-01-2011, 04:38 PM | #160 (permalink) |
A few updated pictures
I got this scheme idea from Kyle Stacys vibrant green one, with my own colors and twist. This cano was done by "Sick Canopy" I also since last pics posting amd running the F3C front landing bow, elevating the tail nicely and a better agressive look as well IMO.
