Old 12-20-2014, 08:39 AM   #1 (permalink)
Default cellpro 10xp
Hi,I just charged a 4 cell lipo with no probs,,I then tried to charge a 6s and I get an error code 86 bad A123 set voltage,,,any ideas what I am doing wrong?
bill rob is offline        Reply With Quote Quick reply to this message
Old 12-20-2014, 08:52 AM   #2 (permalink)
Also noted firmware version is 2.30,,and when I switch on while holding the mode button,,The only menu choices I get are change amps and change chemistry or exit?,,should I not have a menu with about ten choices instead of three?
No doubt I will be doing something wrong!!
Old 12-20-2014, 11:34 AM   #3 (permalink)
mnc
I am not real familiar with that charger but sounds like you need to change the chemistry to lipo hope this helps
Never enough time, Never enough helies
mnc is offline        Reply With Quote Quick reply to this message
Old 12-20-2014, 11:42 AM   #4 (permalink)
You can press and hold the mode button while the unit is powered on to change chemistries. Pressing and holding the mode button while applying power gives you the preset menu. There are 10 normally. If there are only 3, the others may have been hidden or disabled. This can be done using the PC software and USB connection.
Gregor99 is offline        Reply With Quote Quick reply to this message
Old 12-21-2014, 05:44 PM   #5 (permalink)
Tried to connect to pc today but couldn't make it work, I couldn't find a video for the 10xp so I followed the steps in the revolectrix site video for connecting the ps8,,it all goes ok,I get the download and driver and the pc goes off.
When it restarts I plug in to the pc,and I thought it would pick up the driver and run it but nothing happens.Im no pc wizard so my wife who is, tried it following the steps and again nothing happens,,if I uninstall everything and go through it again I get the same result,,can I just check,when I connect to the charger the black wire is nearest to the chargers middle,is that right?
Thanks for helping
enlighten a dumb-ass
Old 12-21-2014, 08:49 PM   #6 (permalink)
On the three wire cable that goes into the charger, the black wire goes toward the front of the charger and the white wire goes toward the rear of the charger.
Also check to see if you have a FUIM2 or FUIM3. The FUIM2 works with XP and Vista. But the driver is not reliable with W7 or W8.
Pictures and drivers listed here http://www.revolectrix.com/new_appli...re/pc.usb.html
Old 12-22-2014, 03:24 AM   #7 (permalink)
Ah,I had the black wire the other way,,you say its unreliable with 7 or 8,,I think we have 7,,I`ll try later with the black wire the other way and report back,thanks for the help
Old 12-22-2014, 10:32 AM   #8 (permalink)
The FUIM2 does not have W7 drivers. It works on some systems but not others. The FUIM3 is fully supported on W7 and W8.
Old 12-22-2014, 11:37 AM   #9 (permalink)
So I might have to buy the other one!
Old 12-23-2014, 10:30 AM   #10 (permalink)
I have ordered the other cable today,when it comes I`ll let you guys know how it goes
Old 12-24-2014, 10:03 AM   #11 (permalink)
cable came today,but I think I must be jinxed,,,I get as far as the message "searching com3 for data"and I get no further,,,in the help it says to repeat from step 1,,which Ive done 4 times and always the same com 3 message,
any help would be much appreciated!
Old 12-24-2014, 10:49 AM   #12 (permalink)
In the CCS in the COMS section, make sure its set to "AUTO".
If that does not work double check that driver is installed before you connect the FUIM3 http://www.revolectrix.com/new_appli...re/pc.usb.html
Connect the FUIM3 and check device manager. Under "Ports" you should have one labed "USB Serial Port (COMX)" Where X is the assigned COM port. If you see an yellow exclamation, in device manager the driver may not have installed correctly.
Also you can try a different USB cable.
Old 12-24-2014, 01:35 PM   #13 (permalink)
Hi Greg,thanks for your help,,,In the bottom left corner of the screen beside the word auto its flashing in green "com 3 open",,,,and the heading at the page top is "searching com 3 for data"
Old 12-24-2014, 01:47 PM   #14 (permalink)
That's a little better. Does it ever stop saying that its searching for data?
You also try the FUIM3 tester. But note that the FUIM3 must be correctly connected to a powered up charger for the tester to work.
http://www.revolectrix.com/applicati...ster/setup.exe
Old 12-24-2014, 02:39 PM   #15 (permalink)
Hi ,I tried the cable test and it failed,,com port open but failed bps,whatever that is?,,so it seems my new cable just out the packet is junk!
thanks again for helping out Greg,I appreciate it
I hope you and yours have a nice Christmas!
Bill
Old 12-24-2014, 03:30 PM   #16 (permalink)
If it doesn't have a good connection to the charger it will fail. Double check the pin orientation. If is not it, try a different USB cable and possibly a different USB ports. Some USB3 ports on computers don't operate on USB2 or USB1 reliably.
Old 12-25-2014, 12:51 PM   #17 (permalink)
It was the USB cable,,I tried it with a different one and it worked first time
Thanks again for the help
