Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum |
04-27-2008, 05:20 PM | #1 (permalink) |
Mode2 on 14MZ with inverted throttle...
Hi guys,
A friend of mine just bought a 14MZ and we've been trying to program it for his current heli... The problem is that he's mode 2 but his using his throttle in a inverted way meaning that he would like to have his engine at idle when his throttle stick is a the top and his engine at full speed when his stick is at the bottom. I did it by creating an inverted throttle curve that's going down when moving right, I did also invert throttle trim settings... The problem is the throttle cut, I haven't manage to set it up..., as we can't reverse it (the red zone is always above the green one... and you know we can't engage the throttle cut while being in the red zone)... so can someone help me with that one?
Miniature Aircraft Stratus 2*Hirobo Turbulence D3 EX Henseleit TDR Mikado Logo 600 3D |
04-27-2008, 06:23 PM | #2 (permalink) |
Page 37 of the manual. Hardware reverse. Simple to do what you want to do.
http://manuals.hobbico.com/fut/14mz-comp-manual-v1.pdf Just reverse J3 and T3 in the menu Then it will operate with low throttle at stick up and trim will operate the same. Then the throttle cut will operate properly also. David |
