Futaba 14MZ - 12Z Futaba 14MZ and 12Z Help and features Support Forum |
05-31-2008, 03:48 AM | #1 (permalink) |
How do I set MZ14 Headspead to display same as GV1
Hi all,
I have tried the links regarding (Programming the GV1) but I get a 401 error with the page. Can anyone help me to get the MZ14 Head speed diplay in Govenor menu to match the actual head speed diplayed on the GV-1? I am flying a Trex 600 Nitro with the standard gear ratio of 8.5:1 which is already set in the GV-1. Is this a case of some little quirky thing I am forgeting to do? Please help. PHIL.
PC RC FLYER |
05-31-2008, 09:00 AM | #2 (permalink) |
Hi again,
By memory, you have 3 speed on the governoer menu 1000 rpm, 1500 rpms and 2000 rpm. You must set your 3 speeds on GV1 to 1000, 1500 and 2000. You can do it by using 3 condition or only one in which you set the GV1 each time you want to set one of these 3 speeds. Change display to rpm by cligking on %. When you have 1000 on the GV1 then click on 1000 rpm on the radio menu. Change to 1500 and click on 1500 rpm and again change to 2000 and click on 2000 rpm. Done! Then you should be able to set rpm you want from the radio menu. Of course check it on the GV1. |
