Like Tree1Likes
Old 04-06-2011, 04:30 AM   #1 (permalink)
Default TDRex - Trex based, TDR influences
Hi!
I got a few questions about my modified Trex 700, so I thought I'll take some pictures and post them here...
If you wanna see some more pictures have a look there: http://s795.photobucket.com/albums/y...view=slideshow
My configuration:
Scorpion HK5025-440kv (custom winded 5035 will be tested soon)
Align Mod 1 Slant Thread Main Drive Gear / 13T by Infinity http://www.infinity-hobby.com/main/p...345a319ecf7781
Align Gov Sensor
Western Robotics Hercules SuperBEC
Hawk Fusion 120HV
VStabi 5.1 als Governor
12s 4Ah Turnigy 30c
RJX 90er 12mm Head, mounted on lower position of the Align main shaft
The idea behind this modification was to get the Henseleit TDR style but without some of the things I didn't like about that model. The frame was designed by a German.
The Align geare works quit well and the sound is great. I also tested a hearing bone gear, a in-flight failure of my one-way destroyed it. So I switched back...
Parts I've used are:
Henseleit TDR canopy and landing gear
RJX head and links, everything M3
Mikado servo arms and links
Align 700N main shaft bearing blocks
I'm currently running it using the VBar Governor which is really awesome!
Here's a video of the end of my first VBar Governor test... sorry not a very good quality a cell phone was used, but I like the sound:
-Klaus
SuziLAOS-DNHP-CenturioMax-Protos500-Logo400-500-600SE
worldofmaya is offline        Reply With Quote Quick reply to this message
Old 04-06-2011, 05:26 AM   #2 (permalink)
Ah Klaus das ist sehr toll!
Thank you for sharing the photos.
Why did you not use the shape gear?
With the canopy on it looks like a TDR.
How is the vbar gov with that esc? Do you trust the esc?
helicraze is offline        Reply With Quote Quick reply to this message
Old 04-06-2011, 06:04 AM   #3 (permalink)
Most of people say it's a Henseleit... but things like head, shorter boom and only one piece frame-side makes it easy to differentiate from the genuine
By now there's no real need for the Shape gear, let's see if the Align gear takes the power of a custom 5035
Timo Wendtland used the Fusion Hawk for some time now and it seams to work fine. The only question is if the VBar gov isn't too aggressive and produces too much current. If it fails, I'll replace it with a YGE giving me the option for a higher voltage setup
The VBar gov is really great... activate it and it flies better than without. Tail holds much better with activated Governor, swash seams to be more stable... and it holds really really well... in my opinion at least as good as a Jive, maybe a little bit more aggressive right out of the box. I like it
-Klaus
Old 04-06-2011, 06:30 AM   #4 (permalink)
Very sweet looking bird! How do the electronics stay cool under that fully enclosed canopy? Besides the fan (btw where did you pick that up) on the rx pack, it would seem to me in a warm climate that the motor and esc temps would go through the roof.
Chris_M is offline        Reply With Quote Quick reply to this message
Old 04-06-2011, 06:42 AM   #5 (permalink)
Yes.... cooling is a problem. I used a 4225 first three flights which became really really hot. Outside temperature was around 5°C and you could see the hot air coming out between main shaft and canopy. Like chimney...
Things like vbar, WR Bec and receiver are in the back parts which get's fresh air because the canopy has a opening there. Only real problem is motor and Esc. I already thought about an opening on-top like it's done by Mikado with their Logo 600 canopy and perhaps one in front to get some fresh air in.
The fan is part of the Esc and temperature controlled -> http://www.fusion-rc.com/Default.asp...50-30,b:Fusion
Looks like a PowerJazz and perfectly fits the width of a TRex
-Klaus
Old 04-06-2011, 07:51 AM   #6 (permalink)
just wondering but are you winding the 5035 : ) also what winding and wire are you using
I wound my 5035 with 5+5YY 1.8mm~13Awg 478Kv
so far have gotten 10kW and the align slant gear has taken it just fine with the 14t pinion
using CC + v bar gov
once you cut holes in the canopy you will noticed a huge difference, did that one mine and it dropped the temp of the esc significantly ( have it in the front)
good looking heli i like the direct to swash....... you maybe should have incorporated the 3rd bearing block tho.
TRex-800E /Scorp 5035-478 5+5YY 1.8mm/VBar Blue Full 5.2Pro /CC Hv160/WR-Herc Super BEC/RJX 810mm 3D /RotoTech 115 + QuickUk Tail/ Hitec 7940th HV/TP 5000 65c
f22warzone is offline        Reply With Quote Quick reply to this message
Old 04-06-2011, 08:22 AM   #7 (permalink)
I only did a test winding by now, but I read you're postings and it sounds like a good starting point for me. Only problem is time now... that's why I bought the 5025
About the third bearing... I already bought one, but the frame doesn't have enough material left, this will be part of the next upgrade session for sure!
-klaus
Old 04-06-2011, 12:22 PM   #8 (permalink)
Like it alot
someday i will own one too
Horizon Hobby / Blade / Spektrum / Lynx / Dryfluid
https://www.youtube.com/stefanfinster92
think positive, fly negative
4DPILOT is offline        Reply With Quote Quick reply to this message
Old 04-06-2011, 08:38 PM   #9 (permalink)
It looks really good.
NO FLYBARS
504Rone is offline        Reply With Quote Quick reply to this message
Old 04-06-2011, 09:29 PM   #10 (permalink)
FREAKIN SWEET!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Synergy N5C sitting in Box...
Mystic3D is offline        Reply With Quote Quick reply to this message
Old 07-19-2011, 07:26 PM   #11 (permalink)
Klaus, where did you buy these frames?
Felipe
T-REX 700E / VBAR 5 / DS610 / BLS251 / CC160HV / KDE-NEU1917H / WR BEC
T-REX 600 ESP / VBAR 5 / DS610 / BLS251 / CC ICE 100 / NEU1515 / CC BEC PRO
T-REX 550 / VBAR 5 / DS610 / BLS251 / CC ICE 100 / 4025-1100 / CC BEC PRO
DX8 / DX7
fmalzoni is offline        Reply With Quote Quick reply to this message
Old 07-20-2011, 02:47 AM   #12 (permalink)
RC.
^x2
Also is there a list of parts to convert my 700e to a poor mans TDR lol
RC. is offline        Reply With Quote Quick reply to this message
Old 07-20-2011, 02:48 AM   #13 (permalink)
RC.
Sweet looking heli by the way.
Old 07-20-2011, 03:54 AM   #14 (permalink)
I think it was all custom done for him!
Old 07-20-2011, 07:16 AM   #15 (permalink)
Looks like the Suzi Hans frames
DX8 / DX7
Old 07-20-2011, 11:07 AM   #16 (permalink)
No Suzi Hans use the Original Canopy and landing skits from the T 700.
This one is made from a german guy.
sorry to high jack the thread
Here are some pictures of an other version - called Suzi Janis TGD (Janis after my name)....
This one use 3 115 teeth maingear. Two for the motor so gearstripping should never be a problem again.
The 3rd one for an higher tail ratio of 4,79:1...
ID:	241337   Click image for larger version
ID:	241338   Click image for larger version
ID:	241339   Click image for larger version
.....happy flying....
Regards Janis
Vom Feinsten is offline        Reply With Quote Quick reply to this message
Old 07-20-2011, 11:12 AM   #17 (permalink)
Are you going to sell these frames?
Felipe
DX8 / DX7
Old 07-20-2011, 11:18 AM   #18 (permalink)
Felipe
No these are prototypes (5 are made as I am informed) and if you are lucky you can buy them end of 2011.
But I realy dont know.
Regards Janis
Old 07-20-2011, 08:12 PM   #19 (permalink)
Looks Super Cool
Blade mCPX Hoped Up / DX8
Phoenix v3.0s
RichMaty2010 is offline        Reply With Quote Quick reply to this message
Old 07-20-2011, 08:27 PM   #20 (permalink)
Very nice!!
John 3:16
Trex 500-scorpion,CC,hitec,3500G(tail)
450 Pro-scorpion,CC,hitec,9650(tail)
Mcpx V2
DX7
Liposition is offline        Reply With Quote Quick reply to this message
