Old 04-26-2010, 11:13 PM   #21 (permalink)
Originally Posted by rotaryguy View Post
Thank You...I have a request..Battery compartment dimensions please
Ok the frame is 60mm wide by 76mm tall by as long as you want to go, the front and back are open both ways
I hope that helps
David
rcman is offline        Reply With Quote Quick reply to this message
Old 04-27-2010, 06:47 AM   #22 (permalink)
The pic only shows -2- holes to mount the motor? Am I missing something?
[COLOR=Navy] #FutabaUSA , #XLP, #SpinBlades
MarkFlysHelis is offline        Reply With Quote Quick reply to this message
Old 04-27-2010, 07:38 AM   #23 (permalink)
I hope that helps
David
Thank You!
rotaryguy is offline        Reply With Quote Quick reply to this message
Old 04-27-2010, 07:44 AM   #24 (permalink)
Nope - there is no adjustment on the motor mount or in the frames
Edvard R is offline        Reply With Quote Quick reply to this message
Old 04-27-2010, 08:36 AM   #25 (permalink)
just out of curiosity, is the canopy the same 700N canopy? Im planing on buying the frames/parts to convert my current 700E over. I like the way align designed these frames.
In Thrust We Trust.
jetblue2135 is offline        Reply With Quote Quick reply to this message
Old 04-27-2010, 09:02 AM   #26 (permalink)
Not the same - see this post:
https://www.helifreak.com/showpost.p...8&postcount=48
Old 04-27-2010, 09:14 AM   #27 (permalink)
Mark you are correct, the motor mount only has two mounting holes for the motor, the motor has 4 mounting holes
David Olsen
Old 04-27-2010, 09:31 AM   #28 (permalink)
Ya know, I thought Align had a real winner here...until I see this motor setup...
Why would they not make this adjustable?
Marshall Scalisi
Team-MAYHEM is offline        Reply With Quote Quick reply to this message
Old 04-27-2010, 09:39 AM   #29 (permalink)
Originally Posted by Team-MAYHEM View Post
Ya know, I thought Align had a real winner here...until I see this motor setup...WTF?
Why would they not make this adjustable...come on Align!
Really it wouldn't be that hard to slot the frames and make it adjustable, the only concern I have is the elev servo is very close so you may only be able to go 1 or 2 teeth larger on the pinion.
Really most all of us now know that the 700E's helis work pretty well around the 500KV range. I personally like the lower KV setups with larger pinions.
Oh well we will see how well the stock motor works. The make the changes needed to get the thing flying the way I want.
David Olsen
Old 04-27-2010, 11:49 AM   #30 (permalink)
David Olsen
Actually, you could go bigger pinion all you want (if you were able to adjust the mount in the frame) as you would be moving the motor forward and away from the elevator servo. Smaller, no.
Old 04-27-2010, 11:56 AM   #31 (permalink)
Red face
You are right I was thinking of it backwards (kind of got a red face)
David Olsen
Old 04-27-2010, 12:03 PM   #32 (permalink)
I don't see any problems slotting the frame slightly to adjust the motor if needed. My heli-chris has a slightly slotted frame and it's very easy to adjust and hasn't moved since day-1.
On the other hand, it does have 3 motor mount bolts on either side of the frame. Then again, no big deal. I'm sure other alum. motor mounts will work just fine on the 700E frame-set.
Old 04-27-2010, 12:13 PM   #33 (permalink)
David Olsen
No worries, David.
Looking at it, I am actually thinking you could go 11T on it, and still clear the servo, but I don't think it is possible to do a 11T for a 6 mm axle anyway? Not that this is what you wanted to do, of course.
Old 04-28-2010, 11:16 AM   #34 (permalink)
Edvard,
Did I read correctly you pulled out your Jive 120 and replaced it with a CC 160?
I was going to run a Jive 120 until my CC 160 showed up but maybe I better wait.
David Olsen
Old 04-28-2010, 11:42 AM   #35 (permalink)
Hi David,
Yes - that is correct.
I am wanting to go back to the Jive though. I do like the idea of the built in BEC. You can run the Jive, but you will need to use Mode 10.
Old 05-02-2010, 05:59 PM   #36 (permalink)
I hope that helps
David
That helps thank you!!
Yardape is offline        Reply With Quote Quick reply to this message
