Flight Stabilization Flight Stabilization |
04-12-2009, 03:20 PM | #1 (permalink) |
Helicommand Rigid settings/ T-Rex700 FBL
Would someone be kind enought to share its Helicommand set-up file (.HCC) for a T-Rex700 flybarless? I know every set-up is different, but I just want to get a rough idea for gain values and others.
Thank you
Logo, Align, E-flite, Air Hogs... |
04-13-2009, 06:00 AM | #2 (permalink) |
I would suggest starting with the default settings. Most of the time these work very well and don't need much tweaking. I just put a rigid on a Mini Joker and changed very little. Most of the changes were limiting excessive control travel which was apparent just by watching the swash without having to fly.
I've installed the Profi with very minimal change in another helicopter. I would suggest doing this yourself and not using someone elses settings which may or may not be correct. Also, if you make adjustments, make them one at a time and then observe the results. This works best if you can take a computer to the flying area Keith |
04-13-2009, 07:18 AM | #3 (permalink) |
[QUOTE=keithm;1246415
Also, if you make adjustments, make them one at a time and then observe the results. This works best if you can take a computer to the flying area Keith[/QUOTE] Totally agree on that. Once you go thru a few test hovers you will have it figured out.
Robert - DJIUSA.com N. A. Dist. for DJI Innovations USA Dist. for Photohigher USA Dist. for Vario (Industrial) |
