Align 3G FBL System Align 3G FBL Flybarless System Software and Hardware Support |
04-30-2014, 07:08 PM | #1 (permalink) |
Cant get 3GX to power on
I just built a Trex 250 and am using the kits ESC/BEC. I plugged the ESC into the throttle port on the 3GX but it does not light up - nothing. I know I am getting power because I hear a beep from motor but nothing from 3gx. Am I missing something hear or do I have a dead unit?
Paul |
05-01-2014, 08:46 AM | #2 (permalink) |
Have you bound your tx/rx? All connections the correct polarity?
If not, the 3gx will not initialize. |
05-01-2014, 12:28 PM | #3 (permalink) | |
I would suggest to Align that they should show a status light before binding to confrim that the unit is powered. This it would be more user friendly and less misleading in the troubleshooting process.. |
05-01-2014, 02:11 PM | #4 (permalink) | |
If you have any other questions, just ask. Plenty of great help from knowledgeable members here |
05-26-2014, 10:25 PM | #5 (permalink) |
I am having the same issue. I am using my Turnigy 9x (stock firmware) and a Turnigy Rx. I have the Bec/ Throttle control plugged into the 3gx throttle port. Turn it on and nothing. The Tx and Rx are binded. Do I need to somehow bind the 3gx and my Turnigy 9x? Is that even possible? Just so I'm clear, the neg servo wire is toward the bottom of the 3gx right? I have all other wires plugged in but no power to 3gx or Rx with BEC going to 3gx. Not sure what I am missing here.
